6100UH 877U1000
6100UH 877U1000
    BELDEN
    6100UH 877U1000
6100UH 877U1000 数据手册
Product: 6100UH Security & Sound, 2 Conductor 14 AWG TC, Plenum Product Description Security & Commercial Audio Cable, 2 Conductor 14 AWG stranded (19x27) tinned copper conductors with Flamarrest® insulation, Plenum, Flamarrest® jacket with ripcord. Technical Specifications Product Overview Suitable Applications: Intercom/PA Systems, Sound/Audio Systems Construction Details Conductor Element Number of Element Pair(s) 1 Size Stranding 14 AWG 19x26 Material TC - Tinned Copper Insulation Element Pair(s) Material Nom. Thickness Nom. Insulation Diameter PVC - Polyvinyl Chloride 0.011 in (0.28 mm) 0.098 in (2.5 mm) Color Code Black & White Outer Shield Material No Shield Outer Jacket Material Nom. Thickness Nom. Diameter Ripcord PVC - Polyvinyl Chloride 0.015 in (0.38 mm) 0.226 in Yes Overall Cable Diameter (Nominal): 0.226 in Electrical Characteristics Electricals Nom. Conductor DCR Nom. Capacitance Cond-to-Cond 2.53 Ohm/1000ft 36 pF/ft (120 pF/m) Voltage UL Voltage Rating 300 V Mechanical Characteristics Temperature UL Temperature 75°C Operating Bend Radius Stationary Min. Installation -20°C To +75°C 0°C To +75 Installation Min. 2.26 in (57.4 mm) 2.26 in Max. Current 8 Amps per Conductor at 25ºC Max. Pull Tension: 95 lbs (43 kg) Bulk Cable Weight: 38 lbs/1000ft Standards and Compliance Environmental Suitability: Indoor - Plenum, Indoor Flammability / Reaction to Fire: NFPA 262 (UL 910) NEC / UL Compliance: Article 725, CL2P European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE) APAC Compliance: China RoHS II (GB/T 26572-2011) Non-Plenum Number: 5100UH History Update and Revision: Revision Number: 0.161 Revision Date: 04-08-2022 Part Numbers Variants Item # Color Putup Type Length UPC 6100UH 010U1000 Black UnReel 1,000 ft 612825173472 6100UH 008U1000 Gray UnReel 1,000 ft 612825173441 6100UH 8771000 Natural Reel 1,000 ft 612825173465 6100UH 877U1000 Natural UnReel 1,000 ft 612825173540 6100UH 009U1000 White 1,000 ft 612825173458 UnReel © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
6100UH 877U1000 价格&库存
很抱歉,暂时无法提供与“6100UH 877U1000”相匹配的价格&库存,您可以联系我们找货
