5100UH 0101000
5100UH 0101000
    BELDEN
    5100UH 0101000
5100UH 0101000 数据手册
Product: 5100UH Security & Sound, 2 Conductor 14 AWG, TC, CMR Product Description Security & Commercial Audio Cable, Riser-CL3R-FPLR 2-14 AWG stranded tinned copper conductors with polyolefin insulation, PVC jacket with ripcord Technical Specifications Product Overview Suitable Applications: Intercom/PA Systems, Sound/Audio Systems, Fire Alarm (For color Red only)(Dual Rated) Construction Details Conductor Element Number of Element Conductor(s) 2 Size Stranding 14 AWG 19x26 Material TC - Tinned Copper Insulation Element Material Nom. Thickness Nom. Insulation Diameter Color Code Conductor(s) PP - Polypropylene 0.011 in (0.28 mm) 0.098 in (2.5 mm) Black, White Outer Shield Material No Shield Outer Jacket Material Nom. Thickness Nom. Diameter Ripcord PVC - Polyvinyl Chloride 0.017 in (0.43 mm) 0.230 in Yes Overall Cable Diameter (Nominal): 0.230 in Electrical Characteristics Electricals Nom. Conductor DCR Nom. Capacitance Cond-to-Cond 2.53 Ohm/1000ft 22 pF/ft (72 pF/m) Voltage UL Voltage Rating 300 V Mechanical Characteristics Temperature UL Temperature Operating 75°C 0°C To +75°C Bend Radius Stationary Min. Installation Min. 2.3 in (58 mm) 2.3 in Max. Pull Tension: 95 lbs (43 kg) Max. Current 8 Amps per Conductor at 25ºC Bulk Cable Weight: 37 lbs/1000ft Standards and Compliance Environmental Suitability: Indoor - Riser, Indoor Flammability / Reaction to Fire: UL1666 Riser, FT4 NEC / UL Compliance: Article 725, Article 760, CL3R, FPLR European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE) APAC Compliance: China RoHS II (GB/T 26572-2011) Plenum Number: 6100UH History Update and Revision: Revision Number: 0.169 Revision Date: 04-08-2022 Part Numbers Variants Item # Color Putup Type Length UPC 5100UH 0101000 Black Reel 1,000 ft 612825156437 5100UH 008500 Gray Reel 500 ft 5100UH 0081000 Gray Reel 1,000 ft 612825156376 UnReel 1,000 ft 612825156383 5100UH 008U1000 Gray 612825156352 © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
5100UH 0101000 价格&库存
很抱歉,暂时无法提供与“5100UH 0101000”相匹配的价格&库存,您可以联系我们找货
