USB4065-30-A
USB4065-30-A
    GCT
    SMD
    USB连接器 SMD
USB4065-30-A 数据手册
0 Ø2.5 0.50±0.15 F 4.45±0.10 (3.2) 4.70±0.20 XXXXX 3.76 2xC 0.3±0.05 x 0.75±0.05 1.35±0.10 Place Pick 0.50 1.75 B First B12 GND First Second B11 SSRXp1 Second A3 SSTXn1 Second B10 SSRXn1 Second A4 VBUS First B9 VBUS First A5 CC1 Second B8 SBU2 Second A6 Dp1 Second B7 Dn2 Second A7 Dn1 Second B6 Dp2 Second A8 SBU1 Second B5 CC2 Second A9 VBUS First B4 VBUS First A10 SSRXn2 Second B3 SSTXn2 Second A11 SSRXp2 Second B2 SSTXp2 Second A12 GND First B1 GND 1.37 H 3.46 CL 1.75 12x 0.70±0.05 +0.05 -0.10 2x 1.00 0.75 4.10 3.40±0.05 2x 0.80 Section A-A 1.50 6.40 0.05 1.20 B1 A 1.62+0.05 -0.10 0.15 0.70 0.08 B12 T=0.20 GND SSTXp1 1.20 3.42 B D 9.00±0.10 GND First SHELL GND Material Insulator: High Temp. Plastic UL 94V-0, Black Contact: High Grade Copper Alloy (T=0.15mm) Shell: Stainless steel (T=0.20mm) Cover Shell: Iron (T=0.20mm) Inner Ground Cover Shell: Stainless Steel (T=0.10mm) Mid Plate:Stainless Steel (T=0.10mm) Plating Contact: 30µ" Gold over 50µ" min. Nickel Solder Tails: 80µ" min. Matte Tin over 50µ" min. Nickel Shell: 50µ" min. Nickel Cover Shell: 80µ" min. Nickel Inner Ground Cover Shell: 50µ" min. Nickel Electrical Current Rating: C 6.10 4.80 Ordering Grid 3.20 USB4065 2.40 Detail A 0.80 Ø0.60 B B8 B11 B10 B3 B5 30 A Contact Plating 30 = 30µ" Gold 1.60 12x 0.25 5.00A collectively for VBUS pins 6.25A collectively for GND pins 1.25A for B5 pin 0.25A per pin for all other pins Voltage Rating: 20V DC Contact Resistance: 40mΩ max initial. 50mΩ max after test Dielectric Withstanding Voltage: 100V AC Insulation Resistance 100MΩ min Request Samples and Quotation Packing Options A = Tape & Reel (700 per reel) Mechanical & Environmental Operating Temperature: -40°C to 85°C Mating Force: 5 to 20 N. Unmated Force: 8 to 20 N after test Durability: 10,000 cycles B2 B12 B9 2.06 7.45 9.00 A1 12x 0.25 B7 B6 B4 0.50 B1 A12 5.50 Part Number Product Description USB4065 USB Type C Receptacle Hybrid type, PCB Top Mount Drawing Date Detail A A 21th April 2016 By Detail 1 Mating Sequence Specifications 4.70+0.35 -0.05 0.60 A12 A 2.56±0.04 1.20±0.05 Section B-B CL 1.75 R0 .85 Signal 2x 0.25±0.025 8.34+0.06 -0.02 4x Pin A1 SHELL 6.69+0.045 -0.055 A1 Mating Sequence A2 24x 0.25±0.04 9.20 E 3.20±0.10 1.70±0.10 GCT USB4065 is designed and manufactured to be compatible with USB Type C specification latest release. Compliance testing for products conforming to the USB type-C cable and connector specification are currently under development by the USB-IF. Date Code 8.65±0.30 G Signal Pin 9.65+0.25 -0.10 3.50±0.15 H 2 3 4 Revision Date 5 CC USB4065 B PCN B 04/09/17 Tolerances (Except as Noted) Length Angle X. ± 0.50 X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/3 9.00 H 7.45 5.50 0.50 1.00 G A1 F B12 E 0.70 4.10 B11 B9 B10 B7 B8 B6 B5 A12 B1 B4 B3 B2 0.95 0.90 1.15 .65 Ø0 C 2x 1.30 (1.15) D 2x 1.80 0.80 0.65 0.35 1.10 1.60 Ø0.40 Ø0 .65 0.70 1.50 2.16 0.50 PCB Edge 1.60 2.40 4x 0.50 3.20 4x 1.00 4.80 6.10 9.00 (1.95) Recommended PCB Layout Mating View As viewed from component side Recommended PCB Thickness: 1.20mm Tolerance:±0.05mm B Solder Area Component Outline Part Number Product Description USB4065 USB Type C Receptacle Hybrid type, PCB Top Mount Drawing Date 21th April 2016 A By Detail Revision Date 1 2 3 4 5 CC USB4065 B PCN B 04/09/17 Tolerances (Except as Noted) Length X. ± 0.50 X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 Angle Units: Metric (mm) ± 2° C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/3 38.4 32.4 LABEL 4 00 Tape & Reel min. Peeling Angle 165° ~ 180° Ø330 G Vacuum Bag F About 160mm long Void filler 2.00±0.10 4.00±0.10 10 +0. 0 -0.00 5.34±0.10 .5 Ø1 16.00±0.10 C Detail 1 Part Number Product Description USB4065 USB Type C Receptacle Hybrid type, PCB Top Mount Drawing Date 21th April 2016 A By Detail Revision Date 2 3 4 700 Detail 1 4:1 B Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) Bag: PE Box dimensions 355mm x 355mm x 305mm Pcs / Reel Reels / Carton Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) 1 Inner carton dimensions 340mm x 340mm x 285mm R0 .7 5± 0. 05 32.00±0.3 D Unloaded Section 28.40±0.15 E About 160mm long Product Loaded Section User Direction of Unreeling 1.75±0.10 14.20±0.15 Unloaded Section 0.2±0.05 H 5 CC USB4065 B PCN B 04/09/17 Tolerances (Except as Noted) Length X. ± 0.20 X.X ± 0.15 X.XX ± 0.10 X.XXX ± 0.05 Angle Units: Metric (mm) ± 1° C 3rd Angle Projection 6 7 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE Total Qualtity 4,900 pcs www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 3/3
USB4065-30-A
物料型号:USB4065
器件简介:该插座设计用于与USB Type C规范兼容,并且正在由USB-IF开发符合USB Type-C电缆和连接器规范的产品的合规性测试。
引脚分配:文档详细列出了引脚分配,包括信号、配对序列,以及A和B端的GND、VBUS、CC1、CC2、SSRXp1、SSRXn1等信号。
参数特性:包括尺寸、电气电流额定值、电压额定值、接触电阻、绝缘耐压等。
功能详解:文档提供了插座的详细功能描述,包括电气特性和环境特性。
应用信息:文档提供了订购网格、取样和报价信息,以及包装选项。
封装信息:提供了插座的详细尺寸、材料和镀层信息,包括绝缘体、接触材料、外壳、盖壳等。
USB4065-30-A 价格&库存
很抱歉,暂时无法提供与“USB4065-30-A”相匹配的价格&库存,您可以联系我们找货
USB4065-30-A
    USB4065-30-A
    • 1+27.472921+3.56459
    • 10+23.3530510+3.03004
    库存:13
