SK7-019M03
SK7-019M03
    ANDERSON
    SK7-019M03
SK7-019M03 数据手册
3 Position Mini PL SPEC Pak® is a rugged and environmentally sealed (IP68) connector with a manually operated release latch. The 3 Position Mini PL leverages PowerMod ® pin and socket contact technology, delivering capabilities up to 22 amps at 600 volts while handling wires from 24 to 12 AWG (0.5 to 2.5 mm²). The 30µ gold plated pins are available in 3 lengths, enabling sequenced contact mating options. These contacts sit inside a UV and flame resistant shells that are touch safe on both sides. Features Manual Release Latch • Prevents accidental un-mating Pin & Socket Contact Technology • Gold plated for greater conductivity 3 Pin Lengths Available • Offers sequencing capabilities Touch Safe per UL 1977 Sec. 10.2 • Touch safe on both pin & socket sides Mechanical Rugged & Environmentally Sealed Shells • F1 weatherability rating per UL 746C • V0 flammability rating per UL 94 • IP68, exceeds industry standards Environmental Seal IEC UL Wire Size Materials Shell PC Latch PC Flammability UL 94 V-0 Electrical Current Rating (Amperes) UL 1977 CSA (30°C Rise) Voltage Rating UL 1977 (AC/DC) Dielectric Withstanding (AC) Contact Resistance (average) 22 16 600 2200 3 Milliohms Weatherability Contacts Socket Body Copper Alloy, 200 µ inch Sn over Ni Socket Contact Copper Alloy, 30 µ inch Au over Ni Pin Copper Alloy, 30 µ inch Au over Ni NOTE: Sn = tin All Data Subject To Change Without Notice UL764C / 12 mm, F1 UL Pending Ni = nickel Au = Gold IP 68 50E 24 to 12 AWG 0.5 to 2.5 mm² Sealing Options Sealing Gland Operating Temperature -20 to 105°C -4 to 221°F” Mating Cycles (no load) 500 Contact Retention Force 10 lbf 44 N Mating Force (nominal) 5 lb 22 N Touch Safe (UL 1977 Sec 10.2) Pass Latch Strength (nominal) 24 lb 107 N | ORDERING INFORMATION | Step 2 - Select Sealing Gland SPEC Pak® Mini PL Series is a highly configurable environmentally sealed connector that can be purchased as component in bulk for volume production, or pre-packaged as a kit. Configuring a connector is an easy three step process. Step 1 - Select Shell Step 3 - Select Contacts Step 1: Select Shell SPEC Pak® Shell Kits (sealing glands & contacts sold separately) Description - Part Numbers - Minimum Quantity ............... Male, Receptacle Shell Female, Plug Female, Jam Nut Female, Cover Male, Cover 25 ... SK1-019M03 SK6-019M03 SK7-019M03 SK9F-019 SK9M-019 Mates With: SK1-019M03 Male Receptacle OR SK6-019M03 Female Plug SK7-019M03 Female Panel, Jam Nut Step 2: Select Sealing Gland FAQ Q: Do I need a sealing gland? A: For IP68 rating, sealing glands are required with SK1-019M03 & SK6-019M03. A: For splash resistance in the unmated condition, use optional wire sealing grommets with SK7-019M03. (See accessories on page 4). Q: How do I select the appropriate sealing gland? A: Identify the number of wires that will be used. Number of wires: ___________ Identify the outer diameter (OD) of those wire(s). OD of the wires: ___________ Material Bundled Cable Shell PC Sealing Grommet EPDM Flammability UL94 V0 Color Black Torque Requirements Hand tighten until snug, using a wrench tighten an additional 1/4 to 1/2 turn. Wrench Size 22 Mechanical Operating Temperature -20° to 105°C -4° to 221°F www.andersonpower.com Number of Wires Cable Range Wire Outer Part Diameter (OD) - Numbers mm (in) Minimum Quantity .............. 25 Discrete Wires Connector Kit Designation ............................. Number of Wires Cable Range Wire Outer Diameter (OD) mm (in) Minimum Quantity .............. Part - Numbers - Connector Kit Designation 25 ............................. PS2T20-2X 2 0.75 to 1.5 PM 21 3.0 to 4.5 PS 01 PS1T20-5X (0.03 to 0.06) (0.12 to 0.18) .......................................................................................................... .......................................................................................................... 2 1.5 to 2.6 PM 22 PS2T20-3X PS1T20-7X 1 4.5 to 6.5 PS 02 (0.06 to 0.10) (0.18 to 0.26) .......................................................................................................... .......................................................................................................... 0.75 to 1.5 PM 31 PS3T20-2X 3 PS1T20-9X 1 6.5 to 8.5 PS 03 (0.03 to 0.06) (0.26 to 0.33) .......................................................................................................... .......................................................................................................... PS3T20-3X 3 1.6 to 2.6 PM 32 PS1T20-10X 8.5 to 10.0 PS 04 1 (0.06 to 0.10) (0.33 to 0.39) .......................................................................................................... .......................................................................................................... PS3T20-5X 3 4.0 to 4.8 PM 35 1 PS 05 PS1T20-12X 10.0 to 11.5 (0.16 to 0.19) (0.39 to 0.45) 1 All Data Subject To Change Without Notice Step 3: Select Contacts FAQ Q: What should I consider when selecting the contacts? A: Determine the number of amps (continuous and peak). See temperature charts. Amps (continuous) _______ at ______ volts & Peak Amps ________ for ________ seconds Q: Which contacts are used in each shell? A: Pins are used in SK1-019M03 (male receptacle). Sockets are used in SK6-019M03 (female plug) & SK7-019M03 (female panel mount, jam nut) Pin Contacts (PowerMod® Series) - (For pre-mate and post-mate contacts for sequencing, contact the factory) Connector Kit Type AWG mm² ---------------- Part Numbers ---------------- Designation Minimum Quantity ............................. 500 50 Standard Length 7.7 Pin 24 to 20 0.25 to 0.50 PM16P2024S30 PM16P2024S30-50 P46 Pin 20 to 16 0.50 to 1.30 PM16P1620S30 PM16P1620S30-50 P45 Pin 16 to 14 1.30 to 2.10 PM16P1416S30 PM16P1416S30-50 P44 Pin 12 2.5 PM16P12S30 PM16P12S30-50 P47 Hand Tool Pneumatic Tool Tool Die Locator PM1000G1 TM0001 N/A TL0001 Insertion Tool Extraction Tool PM1002G1 PM1003G1 Socket Contacts (PowerMod® Series) Type AWG mm² ---------------- Part Numbers ---------------- Minimum Quantity .............................. Socket 24 to 20 0.25 to 0.50 Socket 20 to 16 0.50 to 1.30 Socket 16 to 14 1.30 to 2.10 Socket 12 2.5 500 50 PM16S2024S32 PM16S2024S32-50 S46 PM16S1620S32 PM16S1620S32-50 S45 PM16S1416S32 PM16S1416S32-50 S44 PM16S12S32 PM16S12S32-50 S47 Hand Tool Pneumatic Tool Tool Die Locator PM1000G1 TM0001 N/A TL0002 Insertion Tool Extraction Tool PM1002G1 PM1003G1 NOTE: APP tooling is required for UL & CSA compliance. Use of unapproved tools will void the connectors warranty. | TEMPERATURE CHARTS | 3 Pole Mini PL SPEC Pak® Temperature Rise VS. Current All Contacts Energized 60 3 Pole Mini PL SPEC Pak® Derating VS. Ambient Temperature All Contacts Energized 125 Ambient Temperature (°C) Temperature (°C) 50 40 30 20 10 0 01 3 5 7 9 11 13 15 17 19 21 23 25 100 75 50 25 0 5 Amperes Applied 12 AWG 18 AWG All Data Subject To Change Without Notice 14 AWG 20 AWG 16 AWG 12 AWG 18 AWG 10 15 Amperes Applied 14 AWG 20 AWG 20 25 16 AWG www.andersonpower.com | CONNECTOR KIT - PART NUMBER CONFIGURATOR | Step 1 Select Shell Series Color S Shell Style 1 K 1 Shell Size - Step 2 Select Sealing Gland Wire Insert Arrangement 019 Step 3 Select contact Housing & Protection 1 M03 PS Contacts Arrangement 2 01 - P46 1 = Male, Receptacle (Pins) P46 = 20 - 24 AWG Pin 6 = Female Plug (Sockets) P45 = 16 - 20 AWG Pin 7 = Female Panel Mount Jam Nut (Sockets) P44 = 14 -16 AWG Pin P47 = 12 AWG Pin 019 M03 00 = No Wire Protection S46 = 20 - 24 AWG Socket PS = Plastic Single Hole S45 = 16 - 20 AWG Socket PM = Plastic Multi-Hole S44 = 14 - 16 AWG Socket 00 = No Wire Protection S47 = 12 AWG Socket 01 thru 99 = See page 3 for selection 1 See page 2 for more informaton | 2 See page 3 for more information | ACCESSORIES (optional) | Wire Seal Accessories for use with SK7-021M03 Description Minimum Quantity Wire Seal Retainer Grommet, wire range 1.2 - 1.9mm (0.047”- 0.075”) OD, Orange Grommet, wire range 1.9 - 2.4mm (0.75”- 0.090”) OD, Yellow Grommet, wire range 2.5 - 3.2mm (0.100”- 0.130”) OD, Tan Sealing Plug Covers -------- Part Numbers -------- Description 1 2-8702P1 114916P1 114916P2 114916P3 114916P4 Minimum Quantity ........... Female Cover Male Cover 50 114916P1-50 114916P2-50 114916P3-50 114916P4-50 - Part Numbers 25 SK9F-019 SK9M-019 | DIMENSIONS | Male Receptacle SK1-019M03 Female Plug SK6-019M03 Female Panel Mount SK7-019M03 [ 0.71 ] Ø 18.2 [ 0.71 ] Ø 18.2 [ 1.68 ] 42.7 [ 0.89 ] Ø 22.6 [ 1.54 ] 39.2 PANEL [ 0.94 ] 23.8 Male Cover Female Cover SK9M-019 SK9F-019 [ 3.6 ] 91 [ 0.43 ] 10.9 SK1-019M03 & SK7-019M03 (mated) [ 0.81 ] 20.5 [ 0.70 ] Ø 17.9 SK1-019M03 & SK6-019M03 (mated) PANEL [ 0.71 ] Ø 18 [ 0.91 ] 23.1 All Data Subject To Change Without Notice [ 2.5 ] 64 2018-0182 DS-MINI3PL REV 05 © 2018 Anderson Power Products, Inc. All rights reserved. APP®, Anderson Power Products®, PowerMod®, SPEC Pak® and the APP Logo are registered trademarks of Anderson Power Products, Inc. HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 • EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 • ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 • CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 • TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 • www.andersonpower.com
SK7-019M03 价格&库存
很抱歉,暂时无法提供与“SK7-019M03”相匹配的价格&库存,您可以联系我们找货
