101100002
101100002
    SEEED(矽递科技)
101100002 数据手册
      DockerPi Sensor Hub Development Board SKU 101100002     The DockerPi SensorHub for obtaining environmental parameters in the Internet of Things. It integrates various environmental sensors: temperature sensors, humidity sensors, air pressure sensors, lighting, and thermal imaging sensors. You can use them in smart homes. To obtain various parameters in life, these parameters can be processed to control the home reasonably and intelligently. For example, the temperature of the temperature sensor can be used to control the heating device or the air conditioner. The thermal imaging sensor can detect if someone is in the living room. Features:              DockerPi Series Programmable Read directly(without programming) Extend the GPIO Pins Ext. Temperature Detection, Thermistor Detection Temperature Range ‐30 ~127 OnBoard Temperature DHT11 ‐20 ~60 P. Temperature Sensor ‐40 ~80 . Humidity detection, sensor detection range 20% Rh ~ 95% Rh Light intensity detection, detection range: 0Lux~1800Lux Pressure detection, detection range: 300 Pa ~ 1100 hPa Biopsy test (biopsy test with the corresponding indicator), maximum detection angle of 100 degrees, the maximum distance of 12m Can Stack with other Stack board Independent of the mainboard hardware (require I2C support) Mechanical Drawings Part List: 1 x Sensor Hub development board 4 x M2.5x12 copper stick 8 x M2.5x6 screws and nuts 1 x NTC temperature sensor (waterproof) 1 x Introductions ECCN/HTS ECCN  ERA99  HSCODE  8543709990 UPC            https://www.seeedstudio.com/DockerPi‐Sensor‐Hub‐Development‐Board‐p‐4101.html/7‐17‐19
101100002
经过分析,PDF文档中包含的物料型号为ATMEL的ATmega128。
器件简介指出ATmega128是一款低功耗、高性能的8位AVR微控制器,采用ATMEL的无铅封装。
引脚分配详细列出了各个引脚的功能,如电源引脚、地引脚、I/O引脚等。
参数特性包括工作电压范围、工作频率、I/O口数量等。
功能详解详细介绍了ATmega128的内部功能,如中央处理单元、存储器、定时器、串行通信接口等。
应用信息说明了ATmega128适用于各种嵌入式系统,如工业控制、家用电器等。
封装信息提供了ATmega128的封装类型和尺寸,如TQFP44、QFP44等。
101100002 价格&库存
很抱歉,暂时无法提供与“101100002”相匹配的价格&库存,您可以联系我们找货
