8D511K04AN
8D511K04AN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D511K04AN
8D511K04AN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 25 Max Z 31 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D511K04AN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours -Mass : 37.95 g ± 10% A 16-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 11 K 04 A SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : K = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : PIN(500 Matings) Passivated CONTACT LAYOUT : 11-04 FORMAT A3 SOURIAU DRG N° 8D511K04AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D511K04AN A 16-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D511K04AN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D511K04AN
- 物料型号: 8D511K04AN - 器件简介: 这是SOURIAU的8D系列不锈钢插头,具有RFI屏蔽功能的插头,使用标准压接接触件,适用于500次插拔。 - 引脚分配: 该插头具有11个接触件布局,具体布局为11-04。 - 参数特性: 包括镀金铜合金最小厚度0.8微米,硅橡胶密封件,不锈钢壳体材料,热塑性绝缘体,镀金接触件,耐500次插拔,最大尺寸为25mm,螺纹为M15x1-6g。 - 功能详解: 该插头设计用于极端温度范围,从-65°C到+200°C,并且能够承受500小时的盐雾测试。 - 应用信息: 适用于需要高耐久性和极端环境条件下的应用场合。 - 封装信息: 重量为37.95克,正负10%的公差,附带SOURIAU接触件和配件。
该文档还提到,SOURIAU不对由于产品使用不符合双方或第三方(专业推荐、技术通知)发布的规格而造成的任何不符合性或损坏负责。产品不在美国的管辖和控制列表上。
8D511K04AN 价格&库存
很抱歉,暂时无法提供与“8D511K04AN”相匹配的价格&库存,您可以联系我们找货
8D511K04AN
库存:29
