8D511K35BN
8D511K35BN
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    8D511K35BN
8D511K35BN 数据手册
LAYOUT SHOWN AS EXAMPLE Keying Shown as example CHARACTERISTICS Connector dimension Dim Nominal ØS 25 Max Z 31 Max VV THREAD M15x1-6g -Standard : Based on MIL-DTL-38999 Series III -Shell Material : Stainless Steel -Shell Plating : Passivated -Insulator : Thermoplastic -Contacts : Copper Alloy -Seals & Grommet : Silicon Elastomer -Contact Plating : Gold over copper Alloy 0.8µm minimum -Durability : 500 Mating cycles SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR PN: 8D511K35BN -Delivered with Souriau contacts and Accessories -Temperature Range -Salt Spray : -65°C to +200°C : 500 hours -Mass : 41.35 g ± 10% A 16-10-2016 First Release ISS DATE Designed By: TITLE BASIC SERIES: 8D 5 - 11 K 35 B SCALE N NA SHELL TYPE : Plug with RFI Shielding CONTACT TYPE : Standard Crimp Contact SHELL SIZE : 11 PLATING : K = Jurisdiction & Control List Not Listed ORIENTATION : N SOURIAU Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM CONTACT TYPE : SOCKET(500 Matings) Passivated CONTACT LAYOUT : 11-35 FORMAT A3 SOURIAU DRG N° 8D511K35BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 1/2 Contact Layout SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) Country FR Jurisdiction & Control List Not Listed PN: 8D511K35BN A 16-10-2016 First Release ISS DATE Designed By: TITLE SCALE NA SOURIAU FORMAT A3 Latest modification - by MOD N° CUSTOMER DRAWING Date: Stainless Steel Plug 8D series General linear Tolerances: ±-- WWW.SOURIAU.COM SOURIAU DRG N° 8D511K35BN-C NPRDS / PROJECT 859 This document is the property of SOURIAU it must not be reproduced or communicated without permission SHEET 2/2
8D511K35BN
- 物料型号: 8D511K35BN - 器件简介: 这是一个带有射频屏蔽的插头,使用标准压接接触。 - 引脚分配: 11个接触点,布局为11-35 SOURIAU DRG N°。 - 参数特性: - 接触镀层:铜合金上镀金,最小厚度0.8微米。 - 标准:基于MIL-DTL-38999系列III。 - 密封和垫圈:硅橡胶。 - 壳体材料:不锈钢。 - 绝缘体:热塑性塑料,钝化处理。 - 耐用性:500次配对周期。 - 连接器尺寸:as最大25mm,Z最大31mm,螺纹M15x1-6g。 - 质量:41.35克±10%。 - 温度范围:-65°C至+200°C。 - 盐雾测试:500小时。 - 功能详解: 该插头设计用于符合特定规格的电气连接,并且有500次的耐用性配对周期。 - 应用信息: 适用于需要射频屏蔽和高耐用性的电气连接。 - 封装信息: 该插头为不锈钢材质,设计用于SOURIAU的接触和配件,具有特定的尺寸和螺纹标准。
8D511K35BN 价格&库存
很抱歉,暂时无法提供与“8D511K35BN”相匹配的价格&库存,您可以联系我们找货
