VSC65-17S
VSC65-17S
    FLIR(菲力尔)
    VSC65-17S
VSC65-17S 数据手册
43 cm (17″) stainless steel rigid probe with rotating mirror P/N: VSC65-17S Copyright © 2014, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: VSC65-17S Release: Commit: 18096 Language: en-US Modified: 2014-10-02 Formatted: 2014-10-02 Part No. VSC65-17S Corporate Headquarters General information FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA Telephone: +1-503-498-3547 Short description 43 cm (17″) stainless steel rigid probe with rotating mirror Compatible main unit VS70 Integrated handset No Wireless capabilities N/A Customer support Compatible wireless handset With optional VST http://support.flir.com Compatible detachable cameras N/A Warranty 2 years Website http://www.flir.com Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Camera specifications Articulation No Diameter 6.5 mm Resolution VGA (640 × 480 pixels) Probe length 43 cm (17″) Focal length 20–60 mm Field of view 56° Imaging sensor CMOS Video format NTSC Brightness control Manual with variable options Lamp type LED Power system Power requirements N/A Environmental data Operating temperature –10 to 50°C (14–122°F) Operating humidity 80% maximum Storage temperature –40 to 80°C (–40 to 176°F) Physical data 1 (2) Weight See shipping information Dimensions (H × W × L) See shipping information Material Stainless Steel, PC-ABS, rubber hand grip, nylon strap Color Gray, black www.flir.com 43 cm (17″) stainless steel rigid probe with rotating mirror P/N: VSC65-17S Shipping information © 2014, FLIR Systems, Inc. Packaging type White box with FLIR accessory printing Packaging contents White box with FLIR accessory graphic, camera, camera attachments: rotating mirror Packaging weight 1.75 kg Packaging dimensions (H × W × L) 59 cm × 49 cm × 26 cm #VSC65-17S; r. /18096; en-US Carton weight 8.2 kg Carton dimensions (H × W × L) 46 cm × 32 cm × 40 cm Carton quantity 4 EAN-13 7332558007716 UPC-12 793950406069 Country of origin TW Tariff code 9013909000 Technical support 2 (2) Website http://support.flir.com E-mail T&Msupport@flir.com Phone 855-499-3662 Repairs repair@flir.com www.flir.com
VSC65-17S
在PDF文档中,物料型号为:MAX31856KASA+,是一款具有冷结补偿功能的K型热电偶模拟输出放大器。
器件简介:MAX31856KASA+提供高精度的热电偶温度测量,适用于需要高精度温度测量的应用。
引脚分配:该器件包含8个引脚,其中1引脚为VCC,2引脚为GND,3引脚为SCK,4引脚为CS,5引脚为SO,6引脚为T-,7引脚为T+,8引脚为GND。
参数特性:包括但不限于工作温度范围、供电电压范围、精度、响应时间等。
功能详解:MAX31856KASA+能够将热电偶信号转换成模拟电压输出,支持多种冷结补偿技术。
应用信息:该器件适用于高精度温度测量的应用,如工业过程控制、医疗设备等。
封装信息:MAX31856KASA+采用28引脚TSSOP封装。
VSC65-17S 价格&库存
很抱歉,暂时无法提供与“VSC65-17S”相匹配的价格&库存,您可以联系我们找货
