SCD30S12-DN
SCD30S12-DN
    SOLAHD
    SCD30S12-DN
SCD30S12-DN 数据手册
Power Supplies SCD Series, Encapsulated, Industrial DC to DC Converter The SolaHD SCD Series compact, rugged DC to DC converters are power supplies designed to power industrial control instrumentation devices and equipment where AC power is not convenient or accessible. With high reliability and wide input range, these units can operate through the most difficult factory floor conditions around the globe. “User friendly” applies to these unique power supplies that feature easy-to-install DIN rail and chassis mounting. Terminations are also easy to access and simple to wire. Encapsulated design meets IP20 specifications for use in harsh environments. Applications These units regulate voltage for sensitive electronic equipment run from battery power. For example, a 24 Vdc battery system where the battery voltage can be 30 volts, sometimes higher during charging, and dip below 22 volts under heavy load. The SCD can be used to stabilize the voltage for those devices not designed to handle wider voltage swings. They are also a convenient and inexpensive alternative to running AC power through a large industrial machine. The SCD can use 24 Vdc commonly available on many parts of the machine to create other voltages needed to run sensors, transducers and other devices that the machine requires to work properly. E61379 E137632 Options and Accessories • SCP-MDC – Pair of metal DIN clips • SCP-PDC – 1 plastic DIN clip with lever for removal from rail Certifications and Compliances • Listed, Ind. Control Equip., E61379 - UL 508/CSA C22.2 No. 107.1 • Industrial - Encoders, special sensors, communications and instrumentation • • Telecommunications systems • • Remote Site/Harsh Environment • IP20 Recognized Component, ITE, E137632 - UL 60950/CSA C22.2 No. 234-M90 UL 60950 E137632 CUL/CSA-C22.2 No. 234-M90 -IEC/EN60950-1 • RoHS Compliant Features • DIN Rail or Chassis Mount by removing DIN clips • Rugged, encapsulated design to resist environment • IP20 protection • Wide 20 to 72 Vdc input range • M3 screw clamp terminations • Simple snap-on for DIN Rail TS35/7.5 or TS35/15 • Galvanic isolation • Five year limited warranty Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © December 2018 151 Power Supplies SCD Series, Encapsulated, Industrial DC to DC Converter Selection Table Specifications Output Voltages Low Profile Catalog Number Description V1 Min Load V1 A V2 Vdc A Vdc A 30 Watts; Switching DC Power Supply SCD 30S5-DN 5V 5 5 - - 0 SCD 30S12-DN 12 V 12 2.5 - - 0 SCD 30S15-DN 15 V 15 2 - - 0 SCD 30S24-DN 24 V 24 1.3 - - 0 SCD 30S48-DN 48 V 48 0.6 - - 0 SCD 30D15-DN Dual O/P+15 V 15 0.8 -15 0.8 0.15 Parameter Condition Value Input Input Voltage - 20 - 72 Vdc Filtering EMI/RFI - EN 55011/B, 55022/B Switching Frequency - Typ. 100 kHz Output Output Voltage Accuracy Ripple Noise Line Regulation Load Regulation Vin = 48V, Iout = max, 25°C V1 ≤ ±1%, V2 ≤ ±4% Vin= min, Iout=max, 25°C Vin= min, Iout= max, 25°C Vin=min/max 25°C Iout = max, 25°C Iout = 10 to 90 to 10%, 25°C, Vin = 48 V, 25°C D= .16 (4.2) ≤2%, Vout ≤+0.5%, Vout ≤+0.5%, Vout 105 to 130% Inom Overcurrent Protection Dimensions - in (mm) ≤1%, Vout Load Regulation Timing 10 to 90 to 10%, 25°C 50°C Holdup Time Vin = 48 V 5%/K max General >10 ms -25 to +65°C Operating Temperature Storage Temperature Case Temperature Rise at Full Load 4.51 (115.0) 4.71 (120.0) 2.26 (57.5) 4.16 (106.0) MTBF at 25°C (input/output) 45 to +85°C acc. MIL-STD-217F 45 K max 800,000 hrs Transient Protection - EN61000-4-2, 3, 4, 5 Cooling - Convection Weight - lbs (kg) - 0.8 (.39) Case Material/Potting - UL94-VO Protection - IP20 .24 (6.0) (4.5) Note: No input protection against reverse voltage. .18 1.29 (33.0) TA = 25°C 2.08 (53.0) 2.55 (65.0) Pin-Out SCD 30 1 2 Single +V1 -V1 Dual V1 COM 152 3 V2 6 7 +IN -IN +IN -IN Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © December 2018
SCD30S12-DN 价格&库存
很抱歉,暂时无法提供与“SCD30S12-DN”相匹配的价格&库存,您可以联系我们找货
