9.00
NO
T
FO R
R N EC
O
EW MM
DE EN
SIG DE
D
NS
0.10
5.08
8.94+0.15
-0
Section A-A
(9.54)
C2
5.08
7.15
10.60
C1
Plating:
Contact Terminal:
Contact Area: 15µ” Gold
Solder area: Gold Flash
Underplating: Ni overall 50µ" min.
Cover : Ni overall 50µ" min.
Recommended PCB Layout
As viewed from component side General Tolerance ±0.05
Locating peg holes only applicable to locating peg version
Solder Area
2.54 2.54
Keep Out Area
Component Outline
Electrical:
Voltage Rating: 30V max.
Current Rating: 0.5A max.
Dielectric Withstanding Voltage: 100V AC (60 Sec min. 60)
Insulation Resistance: 1000 MΩ min.
Contact Resistance: 100 mΩ max.
0.40
0.28
0.65
C
Ø0.60
0.12
0.30
4.60
0.70
1.95
8.30±0.10
Mechanical & Environmental
Operating Temperature: -40°C to +85°C
Durability: 5000 cycles
9.00±0.10
10.8
-Y-
0.75 For NanoSIM
1.10
D
C3
Ø0.90+0.10
-0.00
A
0.37±0.05
E
C1
C2
C3
Material:
Plastic Housing: LCP 30%GF, UL94V-0, Black
Contact Terminal: Phosphor Bronze,T=0.12mm
Cover: SUS301-H,T=0.15mm
2x 1.00
1.25
0.35
Specification:
-X-
1.35
F
6x 1.20
8.30
1.45
4.85
0.70
12.20
10.70
GCT
-Y-
1.4
Pick/Place
area
G
C7 C6 C5
2x 3.00
C5
4.15
C6
Ø0.70+0.10
-0.00
1.65
A
C7
6x 1.00
2.54
4.60
6x 1.00
6x 1.10
0.10
H
Ordering Grid
SIM8050
B
XX
14
-X-
3
4
Locating Peg
01 = With (Standard)
00 = Without
Product Description
Nano SIM Card Connector
Push-Pull Type, 6 Pin, SMT, Profile 1.35mm
By
CC
Detail
SIM8050
F PCN
Revision
Date
5
F5
22/01/21
Tolerances (Except as Noted)
Length
Angle
X. ± 0.35
X.X ± 0.25
X.XX ± 0.15
X.XXX ± 0.10
All ± 2°
Units:
Metric (mm)
C
3rd Angle Projection
6
Request Samples
and Quotation
(1500 per Reel)
SIM8050
3rd June 2013
A
Packing Options
A = Tape & Reel
Part Number
Drawing Date
2
No. of Contacts
6=6
Switch
0 = Without
Profile Height (H)
14 = 1.35mm
A
1
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/3
NO
T
FO R
R N EC
O
EW MM
DE EN
SIG DE
D
NS
H
25.00mm Mini
G
15.00mm Micro
15.00mm Mini
E
D
8.80mm Nano
F
12.00mm Micro
12.30mm Nano
C1----->VCC
C2----->RST
Nano SIM
C3----->CLK
C5----->GND
C6----->Vpp
C7----->I/O
Micro SIM
C
Mini SIM
Reference
B
Part Number
Product Description
SIM8050
Drawing Date
A
3rd June 2013
By
CC
Detail
SIM8050
F PCN
Revision
Date
1
2
3
4
5
F5
22/01/21
Length
X. ± 0.35
X.X ± 0.25
X.XX ± 0.15
X.XXX ± 0.10
Angle
Units:
Metric (mm)
All ± 2°
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
2/3
NO
T
FO R
R N EC
O
EW MM
DE EN
SIG DE
D
NS
Reel Label
Peeling Angle
4 00
Min. 165°~18
0°
RoHS Label
1500Pcs/Reel
Ø330
H
G
Desiccant
Vacuum Bag
44cmX45cm
160mm
Product Loading
Section
F
Unloaded
Section
128mm
Unloaded Section
24.5
Inner Carton Label
28.5
11.50±0.15
E
C
RoHS Label
13500Pcs/carton
2.00
4.00
Ø
24.00±0.3
D
1.75
Direction of Unreeling
1.
Inner Carton:340mmX340mmX285mm
50
2.60
GCT
Box label
RoHS Label
16.00
B
Box: 355mmX355mmX305mm
Notes:
Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown)
Products P/N
Pcs / Reel Reels/Carton
SIM8050
A
Materials:
Carrier Tape: Polystyrene (PS)
Top Tape: PE
Reel Tape: Polystyrene (PS)
Vacuum Bag: PE
2
Product Description
SIM8050
Drawing Date
3rd June 2013
3
4
9
Part Number
By
CC
Detail
SIM8050
F PCN
Revision
Date
1
1500
5
Length
Angle
F5
22/01/21
Units:
Metric (mm)
C
6
Reels/Carton
7
consent. E & OE
13500
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
3/3
SIM8050-6-0-14-01-A 价格&库存
很抱歉,暂时无法提供与“SIM8050-6-0-14-01-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.678741+1.38301
- 10+9.0956010+1.17798
- 25+8.5255025+1.10414
- 50+8.1179850+1.05136
- 100+7.72987100+1.00110
- 250+7.24576250+0.93840
- 500+6.89956500+0.89357
- 国内价格
- 1+12.88440
- 10+10.94040
- 30+9.72000
