SMD Multilayer Ferrite Chip Beads
Chilisin offers a wide range of multi-layered ferrite chip beads with various
sizes, frequency characteristics, and impedance values for EMI solutions.
These ferrite formulas are used to compose seven types of EMI
suppression chip beads: BBSY, BBBK, BBSJ, BBGK, BBPY, BBUP,
BBNQ, BBFY, BBFJ and BBHV series.
Product Identification
Shape and Dimensions
Recommended Pattern
Dimensions in mm
Dimensions in mm
TYPE
A
B
C
D
TYPE
A
B
C
060303
0.60.03
0.300.03
0.30.03
0.150.05
060303
0.2 ~ 0.3
0.75 ~ 1.05
0.3
100505
1.00.10
0.500.10
0.50.10
0.250.10
100505
0.4
1.2 ~ 1.4
0.5
160805
1.60.15
0.800.15
0.50.15
0.30.2
160805
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
160808
1.60.15
0.800.15
0.80.15
0.30.2
160808
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
201209
2.00.20
1.250.20
0.90.20
0.50.3
201209
1.0 ~ 1.2
2.6 ~ 4.0
1.0 ~ 1.4
321611
3.20.20
1.600.20
1.10.20
0.50.3
321611
2.0 ~ 2.4
4.2 ~ 5.2
1.3 ~ 1.9
453215
4.50.25
3.200.20
1.50.20
0.50.3
453215
3.0
5.5 ~ 6.5
2.4
:BBSY / BBSJ / BBNQ / BBPY
* Don’t apply narrower pattern than listed above to BBPY and BBUP
:BBSY / BBSJ / BBNQ / BBPY / BBUP / BBFY / BBFJ
Narrow pattern might cause excessive heat or open circuit.
:BBUP :BBBK / BBSJ / BBGK / BBPY / BBNQ / BBUP / BBHV
:BBBK / BBGK / BBPY / BBUP :BBSY / BBBK / BBPY / BBUP
:BBPY / BBUP
Dimension Conversion
Code
Dimension in mm
(AxBxC)
EIA
060303
0.6X0.3X0.3
0201
100505
1.0X0.5X0.5
0402
160805
1.6x0.8x0.5
0603
160808
1.6x0.8x0.8
0603
201209
2.0x1.2x0.9
0805
321611
3.2x1.6x.1.1
1206
453215
4.5x3.2x1.5
1812
SMD Multilayer Chip Beads
Electrical Characteristics
Impedance
Test Frequency
RDC
Rated current
(Ω±25%)
(MHz)
(Ω) Max
(mA) Max
BBHV00160808100Y00
10
100
0.010
6000
BBHV00160808300Y00
30
100
0.015
4000
BBHV00160808600Y00
60
100
0.030
3000
BBHV00160808121Y00
120
100
0.040
3000
BBHV00160808201Y00
200
100
0.050
2500
BBHV00160808221Y00
220
100
0.080
2000
BBHV00160808301Y00
300
100
0.080
2000
BBHV00160808331Y00
330
100
0.080
2000
BBHV00160808471Y00
470
100
0.100
2000
BBHV00160808601Y00
600
100
0.100
2000
Part Number
Note: When ordering, please specify tolerance code. Tolerance : Y=±25%
Operating temperature range-55℃~125℃(Including self - temperature rise)
Rate Current:Applied the current to coils, the temperature rise shall not be more than 30℃
Measure Equipment:
Z:HP4291A
RDC:HP4338B or CHEN HWA 502
Test Instruments:Agilent E4991A Impedance / Material Analyzer
BBHV00160808100Y00
BBHV00160808300Y00
18
Z
12
10
8
X
6
4
R
30
IMPEDANCE(Ω)
IMPEDANCE(Ω)
Z
25
X
10
R
5
10
100
80
FREQUENCY(MHZ)
RDC
很抱歉,暂时无法提供与“BBHV00160808121Y00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09720
- 200+0.03770
- 500+0.03640
