FIT0646
FIT0646
    DFROBOT
    FIT0646
FIT0646 数据手册
          Metal Case with Heatsink & Fan For Raspberry Pi 4 Model B SKU:FIT0646   INTRODUCTION Get the most out of your Raspberry Pi 4B with this high-quality aluminium case! Designed for Raspberry Pi 4 Model B, these cases are lightweight, durable and strong. Besides, the product offers a high heat conductivity and excellent corrosion resistance, which is able to better protect your Pi board. The anodizing process performed on the surface of the metal greatly improves the quality of the case visually and tactually. All ports and slots of the case can match with Raspberry Pi 4 Model B perfectly. Meanwhile, there are mounting holes on the bottom designed for conveniently fixing the device on the wall.     Ports and Slots of the Case Four cooling fan holes and heat vent are reserved on the case, so users can install one fan inside the case to provide better heat dissipation for your board. Note: Raspberry Pi 4 Model B board is not included, but it can be purchased on our Product Dimension     SPECIFICATION  Compatible with Raspberry Pi 4B 1G/2G/4G  Material: aluminium alloy  Dimension: 90×60×30mm/3.54×2.63×1.18” DOCUMENTS  Installation Steps DFRobot/DFRobot/raw/master/Metal%20Case%20For%20Raspberry%20Pi%204%20Model%20B%20Installation%20Steps.pdf SHIPPING LIST  Metal Case For Raspberry Pi 4 Model B x1  Fan (30mm*30mm) x1  Aluminum Heatsink x3  Screw Pack x1   https://www.dfrobot.com/product‐1936.html?search=FIT0646&description=true/12‐5‐19
FIT0646 价格&库存
很抱歉,暂时无法提供与“FIT0646”相匹配的价格&库存,您可以联系我们找货
