FFC2B28-24-G
FFC2B28-24-G
    GCT
    SMD,P=0.5mm,卧贴
    FPC/FFC连接器 间距:0.50mm 24Pin 翻盖式 卧贴
FFC2B28-24-G 数据手册
0.80±0.05 0.50 Pin 1 E 0.15 E 1.95 3.25 G B±0.10 0.50 0.30±0.05 0.95 0.80±0.05 A±0.15 B±0.10 0.15±0.05 3.30±0.05 H Pin 1 No. of Contacts 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 * * * * * * * * * 0.40±0.05 F Recommended PCB Layout As viewed from component side Solder Area 3.80 ref. 2.90 A Specifications E 0.15±0.05 0.50 C±0.10 D±0.10 0.10 0.38 1.00±0.10 1.75 ref. A 2.90 D 0.28 +0.05 -0.02 B Section A-A 0.30±0.02 2.50 Min. 1.50±0.30 20 0. R Ordering Grid FFC2B28 No. of Contacts 04 - 40 XX G * * * * Electrical Voltage Rating: 30V AC/DC Current Rating : 0.4A AC/DC (40 contacts powered) Dielectric Strength: 250V AC for 1 minute Insulation Resistance: 50 MΩ Min. Contact Resistance: 40 mΩ Max. (B+1) ± 0.05 B ± 0.05 0.50±0.05 0.50±0.02 0.30±0.03 Material Housing: High Temperature Thermoplastic, UL 94V-0, Natural Actuator: High Temperature Thermoplastic, UL 94V-0, Black Contact: Copper Alloy Fitting Nail: Copper Alloy Plating Contact: Gold Flash over all Fitting Nail: Matte Tin Plating over Nickel 1.30±0.15 C Component Outline Request samples and quotation Mechanical & Environmental Durability: 20 Cycles Operating Temperature: -25°C to +85°C Solder Profile: Peak Temp 260°C (+0/-5°C) max. (5 seconds) * Contact Plating G = Gold Flash over all Part Number Product Description FFC2B28 FPC 0.5mm Pitch, Side Entry, Dual Contact, SMT,Height=1.0mm, Back Flip Drawing Date A 12th September 2019 By Detail 1 2 3 4 D 3.39 3.89 4.39 4.89 5.39 5.89 6.39 6.89 7.39 7.89 8.39 8.89 9.39 9.89 10.39 10.89 11.39 11.89 12.39 12.89 13.39 13.89 14.39 14.89 15.39 15.89 16.39 16.89 17.39 17.89 18.39 18.89 19.39 19.89 20.39 20.89 21.39 = Tooled Parts *Please contact GCT for non-tooled parts (see dimension table) Recommended FFC/FPC Dimensions Dimensions A B C 4.00 1.50 2.57 4.50 2.00 3.07 5.00 2.50 3.57 5.50 3.00 4.07 4.57 6.00 3.50 6.50 4.00 5.07 7.00 4.50 5.57 7.50 5.00 6.07 8.00 5.50 6.57 8.50 6.00 7.07 9.00 6.50 7.57 9.50 7.00 8.07 10.00 7.50 8.57 10.50 8.00 9.07 11.00 8.50 9.57 11.50 9.00 10.07 12.00 9.50 10.57 12.50 10.00 11.07 13.00 10.50 11.57 13.50 11.00 12.07 14.00 11.50 12.57 14.50 12.00 13.07 15.00 12.50 13.57 15.50 13.00 14.07 16.00 13.50 14.57 16.50 14.00 15.07 17.00 14.50 15.57 17.50 15.00 16.07 18.00 15.50 16.57 18.50 16.00 17.07 19.00 16.50 17.57 19.50 17.00 18.07 20.00 17.50 18.57 20.50 18.00 19.07 21.00 18.50 19.57 21.50 19.00 20.07 22.00 19.50 20.57 Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A4 11/03/22 X.X° ± 5° X.X ± 0.30 X.XX ± 0.20 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/2 Direction of Unreeling H G 165° Cover Tape Reel Ø13 ~180 ° Peeling angle Upper EPS Carrier Tape PE Bag Desiccant Ø330 Air Bladder Bag F Rivet Mast W+4 E Label Green Product Label Carton Empty 16pcs Ø1 .50 + 4.00±0.10 0 -0 .10 D Ø1 .50 + 0 -0 .10 8.00±0.10 2.00 Empty 16pcs 4000pcs 4.00±0.10 8.00±0.10 2.00 S0±0.10 1.75±0.10 W±0.3 C 1.75±0.10 W±0.3 Down EPS Green Product Label Label 300 Direction of Unreeling Direction of Unreeling 16mm,24mm Carrier 32mm,44mm Carrier B No. of Contacts 4 ~ 14 16 ~ 27 28 ~ 39 40 A W S0 16 24 32 44 / / 28.4 40.4 2 0 36 Pcs/Reel Reel/Carton Pcs/Carton 4000 4000 4000 4000 14 10 8 6 56000 40000 32000 24000 Part Number Product Description FFC2B28 FPC 0.5mm Pitch, Side Entry, Dual Contact, SMT,Height=1.0mm, Back Flip Drawing Date 12th September 2019 By Detail 1 36 0 3 4 Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A4 11/03/22 X.X° ± 5° X.X ± 0.30 X.XX ± 0.20 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 2/2
FFC2B28-24-G 价格&库存
很抱歉,暂时无法提供与“FFC2B28-24-G”相匹配的价格&库存,您可以联系我们找货
FFC2B28-24-G
  • 4000+2.971164000+0.38459
  • 8000+2.829398000+0.36624
  • 12000+2.7496412000+0.35592
  • 20000+2.6523920000+0.34333
  • 28000+2.5902328000+0.33528
库存:11617
FFC2B28-24-G
    • 1+4.01760
    • 10+3.93120
    • 30+3.86640
    库存:10
    FFC2B28-24-G
      FFC2B28-24-G
        FFC2B28-24-G
