PHV12-350S10P
PHV12-350S10P
    BELLNIX
    插件,60x40mm
PHV12-350S10P 数据手册
High efficiency, ultra small size adjustable output type high voltage power supply High efficiency, I type resonance PWM formula 3.5W high voltage DC-DC converter 0V to 350V PHV Series The PHV series was built using Bellnixs independent technology, the I type resonance PWM formula. With the use of I type resonance PWM formula, high efficiency (68% typ.) has been achieved with the high voltage power supply. As a result, the dimensions are 1/5 of the normal product size with the existing power of 3.5W. The PHV series is also using the 5 sided metallic shield case, and is expected to have high reliability and long life for an high voltage DC-DC converter with adjustable output voltage. ■ Features ・High efficiency 68%typ. ・5 sided metallic shield ・PCB mount type ・High reliability ・ON/OFF control (option) ・MTBF anticipated value 400、000H ・Max output capacity 3.5W ・Adjustable voltage with external voltage ・Over current protection ・Low price/long life ・Ultra small size ・Low ripple noise ■ Model name/Rating Model name PHV Series PHV12-350S10P PHV12-350S10N Input voltage (Vdc) Output voltage (Vdc) Adjustable output voltage range (Vdc)(Note1) 10.8 to 16.5 10.8 to 16.5 +350 -350 0 to +350 Output current (mA) 0 to 10 0 to 10 0 to -350 Output capacity (W) 3.5 3.5 Input current (mA) typ Ripple noise (mVp-p) typ Case 430 100 100 PH-15 PH-15 430 ■ Specifications Line Regulation 0.01% typ.(Input voltage +12V±1V) Load Regulation 0.01% typ.(Load current varying from 0% to 100%) Temp Regulation Over current protection ±0.01%/℃ typ.(Temp varying from -10℃ to +50℃) Drooping type characteristic, auto restart circuit which operates at 105% or greater Output voltage acc. Below ±5%(Rated output, rated load, Vcont=6V) Output voltage control ON/OFF control (note2) External voltage 0V to +6V or an external resistor 5KΩ to adjust Available (Between 2pin-5pin : When open, the output will turn on, when short, the output will turn off) -10℃ to +50℃(Dearting required for temp +40℃ and higher) Usage temp range Storage temp range Usage humidity range -25℃ to +85℃ 20% to 95%RH(No dewing) Isolation between input/output Non-isolated type (2pin-6pin and case are internally connected) Note1: The output voltage will be controlled by applying the Vcont voltage. Using an adjustable resistor or an external voltage, voltage should be applied on the Vcont pin in order to control the output voltage. When Vcont voltage=0V the output voltage (output residual voltage) should be less than 2.0% of the max output voltage. Note2: The ON/OFF control is optional. When ordering, add a suffix "R" to the end of the product name. Ex) PHV12-350S10PR. (R=Remote control) ■ Test circuit ■ Block diagram 1 H.V Out (+ or -) +Vin 0∼350V (0∼-350V) +Vin 7 1 + 12V SW1 Open=ON Short=OFF PHV C1 2 SW1 DC-AC Switching circuit C2 Load Vin Com Vout Com 6 Vref ON/OFF Vcont C1=47μF C2=4700pF 3 5 4 (OPEN) + Output voltage control (Apply 0V∼6V) High voltage oscillating transistor H.V Out (+ or -) high voltage rectification 7 Control IC + 12V Vin Com Load Output voltage control Over current protection Standard voltage generating part 6 Vout (Com) 2 Voltage detection circuit SW1 Open=ON Short=OFF Warning 1: The input-output ground line and case are internally connected. SW1 Case ON/OFF control part ON/OFF 5 Vref 4 Vcont External voltage (0∼6V) or VR (5KΩ) 3 + Warning 2: Vref is 6V±0.3V (When external VR=5KΩ) Warning 3: The ON/OFF can be controlled with a transistor. 1 BHV20081113 ■ Model/Dimensions/Pin configuration (PH-15 case) Pin configuration with the optional ON/OFF control 15 15 Dimensions and pin configuration for standard products 6 Standard product (9.84) 7 1 2 3 4 5 20.32 (12.38) 5.08×4=20.32 20.32 (9.68) 40.64 40±0.7 (12.38) 5.08×3=15.24 7 1 2 3 4 60±0.7 (9.84) (9.68) 40.64 Function Pin +Vin 1 Vin Com 2 Vcont 3 Vref 4 ON/OFF 5 Vout Com 6 H.V Out (+ or -) 7 ON/OFF is optional 40±0.7 (11±2.5) 60±0.7 (11±2.5) 0.8 0.8 6 Optional pin (Add a suffix-R) Weight : 72g typ. Units : mm Margin of error:±0.5 ■ Controlling the output voltage using an adjustable resistor 1 +Vin H.V Out (+ or -) 0∼350V (0∼-350V) 7 80% PHV C1 SW1 Open=ON Short=OFF 2 SW1 Vout Com Vref ON/OFF Vcont 5 4 3 Vin Com C2 Load 6 C1=47μF C2=4700pF Output voltage + 12V Output voltage−VR resistance value 100% 60% 40% 20% 0% R1 R2 VR (5KΩ) R1 5KΩ R2 0KΩ 0KΩ 5KΩ VR resistance value ■ Controlling the output voltage using an external voltage 7 H.V Out (+ or -) +Vin Output voltage−Output control voltage 0∼350V (0∼-350V) 100% + 12V SW1 Open=ON Short=OFF PHV C1 2 SW1 C2 Vout Com 6 Vref ON/OFF Vcont C1=47μF C2=4700pF 3 5 4 (OPEN) + Output voltage control (Apply 0V∼6V) Vin Com Load Output voltage 1 80% 60% 40% 20% 0% 0V 1V 2V 3V 4V 5V 6V Output control voltage 2 BHV20081113 ■ ■ Setting/Adjusting the output voltage Standard usage information PHV series The PHV series output voltage can be set or adjusted using an external voltage or external adjustable resistor. 1 +Vin Vout (+or−) 7 + 12V C2 C1 1 Load +Vin Vout (+ or -) 7 + Vin Com SW1 Open=ON Short=OFF SW1 Vout Com 6 2 Vref ON/OFF Vcont C1=47μF C2=4700pF 3 5 4 (OPEN) + Output voltage control (Apply 0V to 6V) 12V C1 C2 PHV 2 Vin Com Vout Com Vref 4 6 Vcont 3 + ■ ON/OFF control (optional) By opening and closing between the ON/OFF pin and Vin Com R1 100% Output voltage The PHV series does not require any external parts, however when the input impedance is high, for example: the distance between the power supply and converter is long, the input line is thin, or the input side has a filter then connecting a capacitor C1 to the input side is recommended. Place the capacitor as close as possible to the converter pin side, to lower the lead inductance. (2) (2) Vin Com Vin Com Non-isolated type 40% 100% VR resistance value 0KΩ 5KΩ Output voltageーOutput control voltage Characteristic 80% 60% 40% 20% Since the chattering to the ON/OFF pin will affect the output voltage, 0% choose one without any chattering. When the output is turned 0V 1V 2V 3V 4V 5V 6V off by the ON/OFF control, the residual output voltage should be Output control voltage within 0.5%. (at Input/Output rating) ● The above characteristics (Output voltage -VR resistor value characteristic) graph is an indication of the resistance value Over current protection R1 and R2. When setting the voltage to a set rate using The PHV series has a over load and load short a stable resistor, first decide the adjustable resistor R1 and R2. protection installed. When the ● Do not apply voltage higher than 6V+5% on the Vcont. product status is in over load or load short mode, the ● Use an adjustable resistor appliance with good temperature output voltage will decrease, and once the problem characteristics. has been removed, the voltage will automatically recover. ● When the resistance value is 5.0KΩ(R1=0Ω, R2=5KΩ), 100 Output voltage set value ■ Isolated type 60% 0% Output voltage (5) Output voltage−VR resistance value Characteristic 80% R1 5KΩ R2 0KΩ ON/OFF ON/OFF R2 Output voltage control (0V∼6V)    or VR(5KΩ) 20% pin the output voltage can be externally turned on and off. Between the ON/OFF pin (5) and -Vin pin (2)     ①Open will turn the output ON          ②Short(0 to 1.0V,1mA max) will turn the output OFF      The ON/OFF pin is internally pulled up to the 5V, so be careful      of the voltage from the switching element of the ON/OFF pin (photo couplers, transistors, etc) Keep open when not using the ON/OFF control. (5) Load 80 The PHV series Over current protection characteristic the max.voltage 6.0V will impress to Vcont pin. Therefore, 100% output affect the max output voltage, so use the resistance 60 40 2 (%) 0 0 0 the margin of error for the resistance value will largely 50% output value as 5.0KΩ±5%. Output current (lo) 100% 3 BHV20081113 PHV Series ■ Recommended pattern ■ Lowering the output noise even farther ① The PHV series uses a metallic case. When mounting to to a double-sided PCB, the wiring for the converter be should be on the soldering side. AlsAlso, this converter will generate high voltages so the crecreepage distance should also be taken in when whdesigning. ② When mounting to a double-sided PCB, the land of ou the parts side of the high voltage output pin should ③ The metallic case does not need to be connect to ground. HoHowever, when using and gound with the metallic case, ca make the impedance lower as possible between the ground. The PHV series output voltage can be adjusted by using an external voltage or external adjustable resistor. 1 Vout (+ or -) +Vin 7 + 12V SW1 Open=ON Short=OFF C1 PHV 2 SW1 Vin Com Load C2 Vout Com 6 ON/OFF Vref Vcont C1=22 to 47μF C2=0.047 to 0.1μF 4 3 5 (OPEN) + Output voltage control (Apply 0V to 6V) ■ Vref pin (Standard voltage output) When controlling the output voltage with an adjustable resistor, this pin is used. Vref has a standard output voltage of 6V. In this case, the external adjustable resistor is 5KΩ. Since the resistance value from the external adjustable resistor will decide the output voltage with the effect of the specified value, use a resistance value with an accuracy of 5KΩ±5%. The type of resistor does not matter, as long as it is 5KΩ, however one with a good temp coefficient is recommended. Standard voltage generation circuit Vref 4 PHV series When lowering the output noise, the wiring of the input and output should be as short as possible. Place C2 closest to the load, paying attention to creepage and clearance distances. Point! ① Choose a capacitor with a high-frequency when adding to the input. ② Earth (COMMON) line should be thick and short in the pattern design to lower the common impedance. Vout Com 6 ③ The capacitor which is connected to the output side should be able to withstand the pressure, when connected to the load side. At this time, the capacitor lead should be shortened. Also when the load response time is a problem, Vcont 3 External adjustable resistor (5.0KΩ) ■ Prevention of inverse input connection please be aware of the time constant. The converter may break if the polarities are reversed. If there is a possibility in which the connections maybe reversed, connect a diode and fuse like below. ■ Guarantee This product shall be guaranteed for a year. During this period, if there should be any failure definitely due to our designing or manufacturing, we will repair or replace it with a new one at our expense. However, in any case that the product is modified and/or has made any interal remodlling by the buyer, the product can no longer be guaranteed. This guarantee shall cover only the PHV series. Fuse +Vin + 12V PHV Vin Com ■ Recommended soldering conditions Soldering conditions for each part are as follows: ① Using a soldering iron 340 to 360°C ② Using a soldering tub 230 to 260°C ■ If you have any further technical questions for this product, please contact to us. 5 sec. 10 sec. E-mail: info@bellnix.com http://www.bellnix.com 4 BHV20081113
PHV12-350S10P 价格&库存
很抱歉,暂时无法提供与“PHV12-350S10P”相匹配的价格&库存,您可以联系我们找货
