2521
2521
    ADAFRUIT
2521 数据手册
Adafruit FONA - uFL Version Starter Pack PRODUCT ID: 2521        Description Build your own cellular project and get off the grid with FONA. This pack comes with an uFL‐ antenna type FONA and paired with hand‐picked accessories. It's the Adafruit FONA ‐ uFL  Starter Pack.  The FONA miniGSM is an adorable all‐in‐one cellular phone module that lets you add voice, text,  SMS and data to your project in an adorable little package.  This module measures only 1.75"x1.25" but packs a surprising amount of technology into its  little frame. At the heart is a GSM cellular module (we use the latest SIM800) the size of a  postage stamp. This module can do just about everything. This starter pack has a uFL connector.  For the SMA version, click here! And for the Adafruit FONA 800 uFL Shield version click here!  o o o o o o o Quad‐band 850/900/1800/1900MHz ‐ connect onto any global GSM network with any  2G SIM (in the USA, T‐Mobile is suggested)  Make and receive voice calls using a headset OR an external 8Ω speaker + electret  microphone  Send and receive SMS messages  Send and receive GPRS data (TCP/IP, HTTP, etc.)  Scan and receive FM radio broadcasts (yeah, we don't exactly know why this was  included but it works really well)  PWM/Buzzer vibrational motor control  AT command interface with "auto baud" detection  Sounds delicious, right? So we plated this fine module onto a little breakout with all the extras  you need to make your next project shine:  o o o o o o o o Onboard LiPoly battery charging circuitry so you can take your project on the go. Use  any 500mAh+ LiPoly or LiIon battery and recharge over the MicroUSB when necessary.  Two LEDs let you know when its charging and done  Standard 4‐pole TRRS headphone jack. Use any 'Android' or 'iPhone'‐compatible headset  with mic  Breakouts for external 8Ω speaker and electret mic if you don't want to use a  headphone  Level shifting circuitry so you can run it with 2.8V to 5V logic.  Vibrational motor (buzzer) driver so you can have noiseless notifications  uFL connections for external antenna  Indicator LEDs for power and network connectivity  Standard SIM slides into the back  On its own, this module can't do anything. It requires a microcontroller to drive it! We suggest  and use an Arduino but any 3‐5V microcontroller with a UART can send and receive commands  over the RX/TX pins.  Microcontroller not included! We recommend an Arduino UNO to go along SIM card not  included! If you are in the USA, we recommend TING  This Pack Contains:  o o o o o o o 1x Adafruit FONA ‐ Mini Cellular GSM Breakout uFL Version ‐ v1  1x Slim Sticker‐type GSM/Cellular Quad‐Band Antenna ‐ 3dBi uFL  1x Lithium Ion Polymer Battery ‐ 3.7v 1200mAh  1x Mini Metal Speaker w/ Wires ‐ 8 ohm 0.5W  1x Wired Miniature Electret Microphone  1x Cell‐phone TRRS Headset ‐ Earbud Headphones w/ Microphone  1x Vibrating Mini Motor Disc   Technical Details   This Pack Contains:  o o o o o o o 1x Slim Sticker‐type GSM/Cellular Quad‐Band Antenna ‐ 3dBi uFL  1x Mini Metal Speaker w/ Wires ‐ 8 ohm 0.5W  1x Vibrating Mini Motor Disc  1x Adafruit FONA ‐ Mini Cellular GSM Breakout uFL Version ‐ v1  1x Lithium Ion Polymer Battery ‐ 3.7v 1200mAh  1x Wired Miniature Electret Microphone  1x Cell‐phone TRRS Headset ‐ Earbud Headphones w/ Microphone     Datasheets: o o o o o o o o o o o o FCC TCB BT  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_TCB_BT.pdf  R&TTE Statement of Opinion  https://cdn‐shop.adafruit.com/datasheets/SIM800_CE.pdf  FCC Part 15B Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Part15.pdf  FCC Part 15C Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Part15_BT.pdf  FCC RF Test Report  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_Report.pdf  FCC TCB  https://cdn‐shop.adafruit.com/datasheets/SIM800_FCC_TCB.pdf        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2521”相匹配的价格&库存,您可以联系我们找货
