BZT52C5V6STR
BZT52C5V6STR
    SMCDIODESOLUTIONS(桑德斯)
    SOD-323
    BZT52C5V6STR
BZT52C5V6STR 数据手册
BZT52C2V4S THRU BZT52C43S Technical Data Data Sheet N1449, Rev. B BZT52C2V4S-BZT52C43S ZENER DIODES Features Planar Die Construction 200mW Power Dissipation General purpose, medium current Ideally suited for automated assembly processes Available in lead free version This is a Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         SOD-323 Schematic & Pin Configuration Mechanical Characteristics     Case: SOD-323, Molded plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.04 grams(approx) Maximum Ratings @TA=25°C unless otherwise specified Characteristic Symbol Value Units Forward Voltage (Note 2) @ IF = 10mA VF 0.9 V Power Dissipation (Note 1) PD 200 mW RΘJA 625 C/W TJ 150 C TSTG -55 to +150 C Thermal Resistance from Junction to Ambient Junction Temperature Storage Temperature Range Ordering Information Device BZT52C2V4SBZT52C43S BZT52C2V4STRBZT52C43STR Marking Diagram Package Shipping SOD-323 3000pcs / reel SOD-323 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. WX = Marking Code  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZT52C2V4S THRU BZT52C43S Technical Data Data Sheet N1449, Rev. B Electrical Characteristics @TA=25°C unless otherwise specified Notes: 1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2 . 2. Short duration test pulse used to minimize self-heating effect. 3. f = 1kHz.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZT52C2V4S THRU BZT52C43S Technical Data Data Sheet N1449, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  BZT52C2V4S THRU BZT52C43S Technical Data Data Sheet N1449, Rev. B Mechanical Dimensions SOD-323 SYMBOL Millimeters Inches MIN. MAX. MIN. MAX. A A1 A2 b 0.000 0.800 0.250 1.000 0.100 0.900 0.350 0.000 0.031 0.010 0.039 0.004 0.035 0.014 c 0.080 0.150 0.003 0.006 D E E1 L L1 θ 1.200 1.400 1.600 1.800 2.500 2.700 0.475 REF. 0.250 0.400 0° 8° 0.047 0.055 0.063 0.071 0.098 0.106 0.019 REF. 0.010 0.016 0° 8° SOD-323 Suggested Pad Layout Carrier Tape Specification SOD-323 SYMBOL B C d E F P P0 P1 W Millimeters Min. Max. 2.85 1.20 1.40 1.65 3.40 3.90 3.90 1.90 7.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  2.95 1.30 1.60 1.85 3.60 4.10 4.10 2.10 8.30 BZT52C2V4S THRU BZT52C43S Technical Data Data Sheet N1449, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
BZT52C5V6STR 价格&库存
很抱歉,暂时无法提供与“BZT52C5V6STR”相匹配的价格&库存,您可以联系我们找货
