BOARDS / BREAKOUT BOARDS
Adafruit HUZZAH ESP8266 Breakout
PRODUCT ID: 2471
DESCRIPTION
Add Internet to your next project with an adorable, bite-sized WiFi microcontroller,
at a price you like! The ESP8266 processor from Espressif is an 80 MHz
microcontroller with a full WiFi front-end (both as client and access point) and
TCP/IP stack with DNS support as well. While this chip has been very popular, its
also been very difficult to use. Most of the low cost modules are not breadboard
friendly, don't have an onboard 500mA 3.3V regulator or level shifting, and aren't
CE or FCC emitter certified....UNTIL NOW!
The Adafruit HUZZAH ESP8266 breakout is what we designed to make working with
this chip super easy and a lot of fun. We took a certified module with an onboard
antenna, and plenty of pins, and soldered it onto our designed breakout PCBs. We
added in:
• Reset button,
• User button that can also put the chip into bootloading mode,
• Red LED you can blink,
• Level shifting on the UART and reset pin,
• 3.3V out, 500mA regulator (you'll want to assume the ESP8266 can draw up to
250mA so budget accordingly)
• Two diode-protected power inputs (one for a USB cable, another for a battery)
Two parallel, breadboard-friendly breakouts on either side give you access to:
1
9
2
2
x
x
x
x
Analog input (1.8V max)
GPIO (3.3V logic), which can also be used for I2C or SPI
UART pins
3-12V power inputs, reset, enable, LDO-disable, 3.3V output
One breakout at the end has an "FTDI" pinout so you can plug in an FTDI or console
cable to upload software and read/write debugging information via the UART.
When you're done with your coding, remove the cable, and this little module can be
embeded into your project box.
Each module comes pre-loaded with NodeMCU's Lua interpreter (NodeMCU 0.9.5
build 20150318 / Lua 5.1.4 to be specific), you can run commands, and 'save' Lua
programs directly to the module's Flash using a USB-Serial converter cable. But, if
you'd like, you can skip Lua and go direct to using the Arduino IDE. Once you
download the ESP8266 core, you can treat it just like a microcontroller+WiFi board,
no other processors needed!
Each order comes with one assembled and tested HUZZAH ESP8266 breakout
board, and a stick of 0.1" header that you can solder on and plug the breakout into
a breadboard. A soldering iron and solder are required for that, and aren't
included. Solderless breadboard also not included. You'll really want a USB-serial
cable such as a USB console cable, FTDI Friend, or FTDI cable (3 or 5V power/logic
is fine) to upload software to the HUZZAH ESP8266! Our essential tutorial has
wiring, pinouts, assembly, downloads, and more!
http://www.adafruit.com/product/2471
7/16/2015
很抱歉,暂时无法提供与“2471”相匹配的价格&库存,您可以联系我们找货
