FD-A
FD-A
    COSEL
    FD-A
FD-A 数据手册
Optional Parts Din rail Attachment Plate APPLICABLE TO MODEL Plate model Din rail width : 35mm screws for installation Type Qty Model FD-A R50A RMB30A, RMC30A M3 2pcs FD-B MMC8A R10A, R15A, R25A RMB15A, RMC15A M3 2pcs 18 4 70 86 EXTERNAL VIEW L1 L2 50 L3 Material : SPCC Thickness : 1.6 Tolerance : 1 Weight : FD-A 290g max FD-B 240g max (Unit : mm) Model FD-A FD-B L1 165 115 L2 174.5 124.5 L3 178.6 128.6 DIN RAIL ATTACHMENT MODEL : FD-SP 4- 3.5 15 4 8 Power Supply 40 70 54 86 MOUNTING EXAMPLE 38 50 6 9.5 13.6 1 Material : SPCC Thickness : 1.6 Tolerance : 1 Weight : 85g max August 12, 2015 Option-17 Option Optional Parts MMC Series PMC Series Harness Mating harness Model MMC8A MMC50A MMC75B MMC100B Harness model # Input Output H-IN-2 or H-IN-9 H-OU-2 H-IN-1 or H-IN-8 H-OU-4 H-IN-1 or H-IN-8 H-OU-4 H-IN-1 or H-IN-8 H-OU-4 Model number 2 3 4 +50 -0 Type 2 3 4 Housing : 10-63-3044 (Molex) Pin : 08-70-1030 or Pin : 08-70-1031 Pin : (Molex) Weight : 25g max 2 3 4 +50 -0 Type 2 3 4 Housing : 10-63-3044 (Molex) Pin : 08-70-1030 or Pin : 08-70-1031 Pin : (Molex) Weight : 25g max 2 3 4 5 6 +50 -0 Type 2 3 4 5 Housing : 09-50-1053 (Molex) Pin : 08-70-1030 or 08-70-1031 (Molex) Weight : 40g max Model number H-OU-4 Housing : 09-50-1103 (Molex) Pin : 08-70-1030 or Pin : 08-70-1031 Pin : (Molex) Weight : 100g max +50 -0 Type Powered by TCPDF (www.tcpdf.org) 500 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 20 20 Color green white Length (mm) 500 500 UL1015 20 black 500 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 20 20 Color green/yellow black Length (mm) 500 500 UL1015 20 white 500 Pin # Wire AWG 1 2 3 4 UL1015 UL1015 20 20 Color green/yellow white Length (mm) 500 500 UL1015 20 black 500 Pin # Wire AWG Color Length (mm) 1 2 3 4 5 6 UL1015 UL1015 UL1015 UL1015 UL1015 20 20 20 20 20 black red purple gray orange 500 500 500 500 500 Pin # Wire AWG 1 2 3 4 5 UL1015 UL1015 UL1015 UL1015 UL1015 20 20 20 20 20 Color red black orange gray purple Length (mm) 500 500 500 500 500 Pin # Wire AWG 1 2 3 4 5 6 7 8 9 10 UL1015 UL1015 UL1015 UL1015 UL1015 UL1015 UL1015 UL1015 UL1015 UL1015 18 18 18 18 18 18 18 18 18 18 Color red red black black orange orange gray gray purple purple Length (mm) 500 500 500 500 500 500 500 500 500 500 Wire 1 2 3 4 5 6 7 8 9 10 +50 -0 Option Option-24 white UL1015 UL1015 Wire 1 H-OU-2 20 1 2 3 4 Wire 1 Housing : 10-63-3064 (Molex) Pin : 08-70-1030 or 08-70-1031 (Molex) Weight : 40g max Model number +50 -0 Type H-OU-1 UL1015 AWG Wire 1 H-IN-9 Length (mm) 500 500 Wire Wire 1 Housing : 10-63-3044 (Molex) Pin : 08-70-1030 or Pin : 08-70-1031 Pin : (Molex) Weight : 25g max Model number +50 -0 Type H-IN-8 20 20 Color green black Pin # Wire 1 H-IN-2 Model number Wire 1 Housing : 10-63-3044 (Molex) Pin : 08-70-1030 or 08-70-1031 (Molex) Weight : 25g max Model number PMC15 PMC30 PMC50 PMC75 PMC100 Type H-IN-1 Model number Harness model # Output Input H-OU-1 H-IN-1 or H-IN-8 H-OU-1 H-IN-2 or H-IN-9 H-OU-4 H-IN-2 or H-IN-9 H-OU-4 H-IN-1 or H-IN-8 H-OU-4 H-IN-1 or H-IN-8 Model August 12, 2015
FD-A
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1mm x 3.6mm。
很抱歉,暂时无法提供与“FD-A”相匹配的价格&库存,您可以联系我们找货
FD-A
