SHT20 I2C Temperature %26 Humidity
Sensor Waterproof Probe SKU SEN0227
Introduction
This is a SHT20 I2C temperature & humidity sensor with waterproof probe. It comes with
the 4C CMOSens® SHT20 temperature & humidity sensor chip, and the probe has gone
through dual waterproof protection. The SHT20 I2C temperature & humidity sensor
adopt Sensirion new technique. Besides the capacitive type humidity sensor and the
band gap temperature sensor, the chip contains an amplifier, A/D converter, OTP
memory and a digital processing unit. To compare with early SHT1x series and SHT7x
series, SHT20 shows better reliability and long-term stability. It can measure surrounding
environment temperature and relative air humidity precisely. The Arduino SHT20
waterproof temperature & humidity sensor adopts dual waterproof protection. The
inner PCB has perfusion and encapsulation protection, and the probe enclosure is made
of PE waterproof materials. This is a special waterproof breathable material that allows
water molecules to seep in, blocking water droplets from seeping in. The sensor won't
be damaged even if it is submerged in water for a long time. There is a built-in 10k Pullup resistor and 0.1uf filter capacitor, so It can be used directly with the microcontroller
such as Arduino. Recommend DFRobot Gravity 4Pin Sensor Adapter, it is quite
convenient.’
Specification
Operating Voltage: 3.3V/5V
Communication Interface: I2C / IIC
Protection Class: waterproof anti-condensation
RH Response Time: 8s (tau63%)
Accuracy: ±3% RH / ±0.3 ℃
Measuring Range: 0-100% RH / -40-125 ℃
Dimension: 73mm * 17mm / 2.87 * 0.67 inches
Weight: 44g
Board Overview
Num
Label
Description
1
Red
VCC
2
Green
GND
3
Black (Blue)
SDA
4
White (Yellow)
SCL
Tutorial
In this section, we'll use Arduino to drive SHT20 I2C Temperature & Humidity Sensor
(Waterproof Probe)
Requirements
Hardware
o DFRduino UNO (or similar) x 1
o
o
M-M/F-M/F-F Jumper wires
Software
o Arduino IDE, [https://www.arduino.cc/en/Main/Software| Click to Download
Arduino IDE from Arduino®]
Connection Diagram
Sample Code
Download the DFRobot Arduino SHT20 library
How to install Libraries in Arduino IDE
* @file DFRobot_SHT20_test.ino
* @brief DFRobot's SHT20 Humidity And Temperature Sensor Module
* @n
This example demonstrates how to read the user registers to display
resolution and other settings.
Uses the SHT20 library to display the current humidity and temperature.
Open serial monitor at 9600 baud to see readings.
Errors 998 if not sensor is detected. Error 999 if CRC is bad.
* Hardware Connections:
* -VCC = 3.3V
* -GND = GND
* -SDA = A4 (use inline 330 ohm resistor if your board is 5V)
* -SCL = A5 (use inline 330 ohm resistor if your board is 5V)
#include
#include "DFRobot_SHT20.h"
DFRobot_SHT20
sht20;
void setup()
Serial.begin(9600);
Serial.println("SHT20 Example!");
sht20.initSHT20();
delay(100);
sht20.checkSHT20();
void loop()
float humd = sht20.readHumidity();
float temp = sht20.readTemperature();
Serial.print("Time:");
Serial.print(millis());
Serial.print(" Temperature:");
Serial.print(temp, 1);
Serial.print("C");
Serial.print(" Humidity:");
Serial.print(humd, 1);
Serial.print("%");
Serial.println();
delay(1000);
// Init SHT20 Sensor
// Check SHT20 Sensor
// Read Humidity
// Read Temperature
Expected Results
FAQ
Q1. How to measure the soil moisture?.
** A.** Soil moisture is defined as: Get 1 kg soil samples, thoroughly dry it, the ratio between
reduced weight (water weight) and 1 kg weight is soil moisture. It totally different to the air
humidity.
For any questions, advice or cool ideas to share, please visit the DFRobot Forum.
https://wiki.dfrobot.com/SHT20_I2C_Temperature_%26_Humidity_Sensor__Waterproof_Probe__SKU__SEN0227/12-10-20
很抱歉,暂时无法提供与“SEN0227”相匹配的价格&库存,您可以联系我们找货
