1.85
14.00
6.85
2.08
1.90
2.00
2.65
P7 P6 P5 P4 P3 P2 P1
Ground
Ground
12.90
Plating 电镀
Contact Terminal 接触端子:
Under-plating 底层电镀: 60µ" min. Nickel
Solder Tail 焊接区: 100µ" Tin
Contact Area 接触区: 3µ" Gold
Metallic Shell 金属外壳:
Solder Tail 焊接区: 60µ" min. Nickel
Card Detect Pin 开关: Gold Flash over 60µ" min. Ni
Recommended PCB Layout
As viewed from component side General Tolerance: ±0.05
Component Outline
Solder Area
Keep Out Area
Connector Center Line
11.30
15.45
1.88
0.75
Specifications 规格
Material 物料
Plastic Housing 塑胶外壳: LCP, UL94V-0, Black
Contact Terminal 接触端子: Phosphor Bronze
Metallic Shell 金属外壳: Stainless Steel
Coil Spring 弹簧: SWP
Latch 拉杆: Stainless Steel
Slider 滑块: LCP, UL94V-0, Black
Card Detect Pin 开关: Brass
13.60
1.10
P8
2.75
1.73
0.80
7.70
1.40
Card Center Line
Card Detect
10.37
0.84
0.25
E
1.80
Card Detect
1.40
1.10
9.95
5.60 (Location of card ejected)
F
1.70 (Location of card inserted)
14.45
0.70 (Location of card pushed)
G
1.80
2.55
1.15
0.40
5.70
1.20
0.20
H
D
0.10
Ordering Grid
7.70
1.94
0.40
C
1.30
P8
MEM2061
9.55
11.10
A
1
2
188
00
Name
Description
P1
DAT2
Data Bit 2
P2
CD/DAT3
Card Detect/Data Bit 3
P3
CMD
Command Line
P4
VDD
Supply Voltage 2.7v/3.6v
P5
CLK
Clock
(Quantity per Reel: 1000 pcs)
Card Detect Switch Circuit:
VSS
Ground
P7
DAT0
Data Bit 0
P8
DAT1
Data Bit 1
3
Card
Detect
Ground
Card
Detect
Without Card
(Normally Closed)
4
Mechanical & Environmental 机械 & 环境
Operating Temperature 工作温度: -25°C to +85°C
Durabillity 耐久性: 5,000 cycles
Lock/Release Force 锁/发布力: 10N (1.02 kgF) max.
Ground
Card Inserted
Part Number
Product Description
MEM2061
Micro SD Memory Card Connector, 1.88mm Profile
SMT, Push-Push, with Normally Closed Switch
Drawing Date
P6
Electrical 电气
Voltage rating 电压额定值: 100V max.
Current Rating 电流额定值: 0.5 Amp
Contact Resistance 接触电阻值:100 mΩ max.
Insulation Resistance 绝缘电阻值: 1000 MΩ min.
Dielectric Withstand Voltage 耐电压: 500 V AC
Request Samples
and Quotation
A
Packing Options
A = Tape & Reel
Micro SD Card Pin Out
Pin
B
01
Switch
01 = With Switch, Normally Closed
Locating Peg
00 = Without
1.30
0.06 X
1.10
0.95
25th June 2015
By
Detail
Revision
Date
5
AJO
Drawing
Release
A
25/06/15
Tolerances (Except as Noted)
Length
X.X ± 0.38
X.XX ± 0.25
X.XXX ± 0.10
Angle
Units:
Metric (mm)
± 1°
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/2
2.0
G
PULL OUT DIRECTION
4.00±0.10Pitch
2.00±0.10
Ø
1.
5
.0
±0
24.0±0.30
Ø100
E
20.00±0.10
0.30
24.00±0.20
50
F
1.75±0.10
12.00±0.10
H
PULL OUT DIRECTION
Note:
1.10 sprocket hole pitch cumulateve tolerance±0.2
2.Carrier camber is within 1 mm in 250mm.
3.Material:Black Conductive Polystyrene Alloy 100% Recyclable
4.All dimensions meet EIA-481-B requirements.
5.Thickness:0.3±0.05mm.
6.Component load per 13" reel: 1000 pcs.
7. A box of 5 volumes, 5000PCS
D
C
8.Product Weight:0.46g; Reel Weight:860g; Full Carton Weight: 4500g.
9.Dry Carton Weight: 200g (Dimensions: 345x345x155)
Ø330
B
Part Number
Product Description
MEM2061
Drawing Date
A
25th June 2015
By
Detail
1
2
3
4
Revision
Date
5
AJO
Drawing
Release
A
25/06/15
Length
X.X ± 0.38
X.XX ± 0.25
X.XXX ± 0.10
Angle
Units:
Metric (mm)
± 1°
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
2/2
MEM2061-01-188-00-A 价格&库存
很抱歉,暂时无法提供与“MEM2061-01-188-00-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.93160
- 10+7.36560
- 30+6.51240
- 100+5.54040
- 500+5.10840
- 国内价格 香港价格
- 1+10.060871+1.30636
- 10+8.5320010+1.10784
- 25+7.9970625+1.03838
- 50+7.6140450+0.98865
- 100+7.24969100+0.94134
- 250+6.79564250+0.88238
- 500+6.47096500+0.84023
