AMPF-MB1
AMPF-MB1
    CARLOGAVAZZI
    AMPF-MB1
AMPF-MB1 数据手册
Photoelectrics Through-beam System, Relay Output Type MPF.RSL • • • • • • • • • • • • Product Description The MPFRS.. is a family of inexpensive general purpose photoelectric sensors in 3 different types of housings with separate amplifier. They are designed to meet the requirements for industrial doors and gates. The “Snap-ON” photo switch can be mounted in material with a thickness from 0.6 mm and up to 2.25 mm. The sensor set is easy to use and no adjustments are necessary. The amplifier has a Industrial doors and gates Range: 15 m Modulated infrared light Option with individually adjustable channel sensitivity Amplifier with “Snap-ON” photoelectric switches Supply voltage: 12-24 VAC/DC Output: SPST relay (low voltage) LED indications for light ON and supply ON Ø12 mm “Snap-ON”, Ø18 or M14 photoelectric housing 1, 2 or 3 multiplexed channels With make or break test input CE, UL325 and UL508 approved Ordering Key test input designed to disable the emitters and therefore evaluate the sensor function. Multiplexed channels prevent cross-talk between each set of photosensors. The amplifier is available with the following voltage: 12-24 VAC/DC. The output is made as positive security e.g. power lost, short-circuit or broken sensor cable makes the relay go to off state. Type Selection, Amplifier Housing WxHxD Ordering no. Supply: 12-24 VAC/DC 70 x 57 x 86 mm MPF1-912 RSL MPF2-912 RSL MPF3-912 RSL MPF1-912 RSLI *) MPF2-912 RSLI *) MPF3-912 RSLI *) MPF1-912 RSLA *) MPF2-912 RSLA *) MPF3-912 RSLA *) MPF1-912 RSLAI *) MPF2-912 RSLAI *) MPF3-912 RSLAI *) Amplifier MPF 3 912 RSL AI Type Number of channels Voltage supply Output relay Safety Low voltage Adjustable sensitivity Inverted test input (break) Sensor MPF T 15 M14 4C Type Emitter Range Housing diameter Optical angle Connectors on cable *) Products available on request Type Selection, Photoelectric Switch Housing diameter Rated operational distance (Sn) Optical angle Ordering no. Emitter Ordering no. Receiver Ø12 mm M14 D11 D18 Ø12 mm M14 D11 D18 Fitting for Ø12 15 m 15 m 15 m 15 m 15 m 15 m 15 m 15 m 4° 4° 4° 4° 4° 4° 4° 4° MPFT 15-4 MPFT 15-M14-4 MPF 15-D11-4 MPFT 15-D18-4 MPFT 15-4C MPFT 15-M14-4C MPF 15-D11-4C MPFT 15-D18-4C MPFR-4 MPFR-M14-4 MPFR-D11-4 MPFR-D18-4 MPFR-4C MPFR-M14-4C MPFR-D11-4C MPFR-D18-4C Specifications are subject to change without notice (11.02.2010) Ordering no. Fitting AMPF-MB1 1 MPFRSL Specifications, Amplifier Rated operational volt. AC types (UB) Terminals 1 & 3 MPF.- 912 RSL. Dielectric voltage Rated impulse withstand volt. Rated operational power AC supply DC supply Output Specifications Resistive load MPF.-912 RSL, RSLA, RSLI, RSLAI 600.000 switching 100.000 switching Rated insulation volt. (Ui) Operating frequency (f) Light/dark ratio 1:1 Contact output Response time OFF-ON (tON) ON-OFF (tOFF) Power ON delay (tv) Output function MPF1+2 MPF3 Indication function Supply ON Beam ON (no object present) 12-24 VAC/DC ± 15%, 50 to 60 Hz 4 kVAC (rms) 4 kV (1.2/50 µs) 3 VA 2W Environment Overvoltage category Degree of protection Pollution degree Temperature Operating Storage Connection -20° to +60°C (-4° to +140°F) -30° to +80°C (-22° to +176°F) Screw terminals (max. 2.5 mm2) Reverse output, transients, short-circuit Protection output Test input MPF.- 912 RSL. Testfunction activated Testfunction deactivated 0.5 A@50 VAC/30 VDC 0.5 A@125 VAC/1 A@30 VDC (UL) 50 VAC (rms), 50 VDC 10 Hz ≤ 50 ms ≤ 40 ms ≤ 300 ms Relay 2 x SPST Relay 2 x SPST + 2 x SPST MPF.- 912 RSLI. Testfunction deactivated Testfunction activated Housing material Weight MPF.- 912 RSL. CE-marking UL-Approval cus  TÛV-Approval III (IEC 66064) IP 40 (IEC 60529/60947-5-2) 3 (IEC 60664/60664A, 60947-1) Max. 28 V@15 mA AC/DC ≥ 3.5 V AC/DC ≤ 1.0 V AC/DC Max. 28 V@15 mA AC/DC ≥ 3.5 V AC/DC ≤ 1.0 V AC/DC PC 126 g Yes UL325, CSA-C22.2 No.247 UL508 Yes (EN 12453) LED, green LED, yellow Specifications, Photoelectric Switches Rated operation dist. (Sn) Light source Light type Ambient light Housing material MPFT15-4/C MPFT15-D18-4/C MPFR-4/C MPFR-D11-4/C MPFR-D18-4/C Housing Backpart MPFT15-M14-4/C MPFR15-M14-4/C House Backpart Connection MPFT15-XXX-4 MPFR15-XXX-4 Cable 15 m - 8 m (UL 325) LED 880 nm Infrared modulated > 20.000 lux PA6 Glass filled PC ABS Stainless steel/PC PTE Max. 10 m cable length Max. 25 m cable length PVC, grey, 10 m, Ø 2.9 mm2 MPFT15-XXX-4C Red connector pair MPFR15-XXX-4C White connector pair Connector is placed 15 cm from sensorhead Cable PVC, grey, 10 m, Ø 2.9 mm2 Degree of protection IP 67 (IEC 60529/60947-5-2) Mounting “Snap-ON” Ø12 mm or fitting MPFT15-4/C MPFR-4/C Rubber profile D11 MPFT15-D11-4/C MPFR-D11-4/C Rubber profile D18 MPFT15-D18-4/C MPFR-D18-4/C Threaded barrel M14 MPFT15-M14-4/C MPFR-M14-4/C CE-marking Yes UL325, CSA-C22.2 No.247 UL-Approval cus  UL508 TÛV-Approval Yes (EN 12453) Operation Diagram Power supply Object present Output contact closed 2 Tv Toff Ton Ton Specifications are subject to change without notice (11.02.2010) MPFRSL Wiring Diagrams Fig. 1 Fig. 2 AC/DC AC/DC AC/DC AC/DC 23 24 23 TEST 23 24 24 24 23 TEST TEST TEST DC DC DC 23 24 23 DC 23 24 TEST TEST 24 TEST RX3 Test input break, shown for 912 version RX2 RX1 TX1 TX2 23 TEST Test input make, shown for 912 version TX3 24 See Fig. 1 and 2 13 14 15 16 17 18 19 20 21 22 23 24 3 2 1 1 2 3 EMITTER Class 2 SUPPLY 12-24 V 1 2 + 3 OUT 3 50 VAC 5 Delivery Contents OUT 1+2 30 VDC Max 0.5 A TP TP 4 TEST RECEIVER 6 7 8 9 • Amplifier, MPF.. • Installation instruction • Packaging: cardboard box 10 11 12 Detection Diagram Excess Gain Emitter Y X 1000 (feet) (cm) 0 9.5 26.2 39.4 52.5 65.6 23.8 40 15.7 20 7.9 0 0 -20 -7.9 -40 -15.7 -60 (inch) 60 -23.8 0 4 8 12 Sensing Range (m) 16 Excess gain Receiver 100 10 1 1000 10000 100000 Range [mm] 20 Specifications are subject to change without notice (11.02.2010) Max. Rating ------ Potentiometer in min. 3 MPFRSL Ø2.9 Dimensions Ø15 3 2 1 1 2 3 TEST RECEIVER EMITTER 86 CH1 MPF3-912RSL CH2 PHOTOELECTRIC AMPLIFIER _ Ø11.8 - CH3 OUT 3 50 VAC CLASS 2 SUPPLY 12-24 V 30 VDC MAX0,5A + OUT 1+2 2.6 17.3 48 57 70 Amplifier 3 2 1 1 2 3 TEST RECEIVER EMITTER 86 CH1 MPF3-912RSL CH2 PHOTOELECTRIC AMPLIFIER _ - 30 VDC MAX0,5A + OUT 1+2 0.6 - 2.25 mm Ø12 Ø12 CH3 OUT 3 50 VAC CLASS 2 SUPPLY 12-24 V To be mounted in material with a thickness of 0.6-2.25 mm Amplifier, adjustable 48 57 70 5 Ø 15.1 2.6 Ø10 Ø2.9 24.5 20 Ø12.8 Ø 2.9 M14 x 1 27.6 19 M14 D11 5 8. 1 Ø17.5 Ø6 33.2 R6 24 Ø2.9 28.3 Ø22 D18 Fitting for Ø12 Installation Hints To avoid interference from inductive voltage/ Relief of cable strain current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 4 Specifications are subject to change without notice (11.02.2010)
AMPF-MB1 价格&库存
很抱歉,暂时无法提供与“AMPF-MB1”相匹配的价格&库存,您可以联系我们找货
AMPF-MB1
    库存:2000
    AMPF-MB1
      • 1+118.501261+15.37930
      • 5+110.577965+14.35100
      • 10+102.6546610+13.32270
      AMPF-MB1
      • 1+176.879041+22.95567
      库存:1
