NOW PART OF
1M-Series
Miniature Rockers & Paddles
PROD UC T WE BP A GE
request sample, configure part
The 1M family of miniature rocker & paddle switches is
composed of two switch series; the 1M1-Series miniature
rocker and paddle switch, and the 1MS-Series sealed
miniature rocker and paddle switch. Both products
feature PC mounting and offer a variety of ratings,
circuits, contact materials, terminal platings, rocker and
paddle actuator styles and colors.
1-3
Poles
.4-5 125, 250
Amps
Typical Applications
∙ Instrumentation
∙ Test Equipment
www.carlingtech.com
∙ Telecommunications
∙ Networking
860.793.9281
sales@carlingtech.com
VAC
28
VDC
∙ Handheld Appliances
∙ Medical Equipment
Tech Specs
1MS-Series
1M1-Series
Sealed
Miniature Rocker
& Rocker Switch
Electrical
Material
Contact Rating
refer to ordering scheme
Case
1MS-Series: Glass filled nylon
6/6,flame retardant, heat
stabilized
(UL 94V-0)
1M1-Series: Dially phthalate (DAP)
(UL 94V-0)
Electrical Life
1MS-Series: 30,000 make &
break cycles @ full load
1M1-Series: 50,000 make &
breakcycles @ full load
Contact Resistance
10 mΩ max. initial @ 2-4 VDC
100mA for both silver & gold
plated contacts
Rocker/Paddle
1MS-Series: Nylon, black
standard,internal o-ring sealed
1M1-Series: Nylon (UL 94V-0)
Insulation Resistance
1000 MΩ min.
Bushing
Dielectric Strength
1500 Volts RMS @ sea level
stabilized (UL 94V-0)
1M1-Series: Brass, nickel plated
Housing
1MS-Series: Spring Steel
1M1-Series: Stainless Steel
Actuator Pivot &
Mounting
Bracket
1MS-Series: Nylon (UL 94V-0)
Actuator Pivot Retainer
1MS-Series: Stainless Steel
Switch Support
Brass, tin plated
Terminal Seal
Epoxy
Physical
2.
Miniature Rocker
& Rocker Switch
Operating Temperature
-30°C to +85°C
Index of Protection
1MS-Series: IP67
Solder Heat Resistance
MIL-STD-202, Method 210
Actuator Travel
25°
*Manufacturer reserves the right to change product specification without prior notice.
Ordering Schemes
Sample
Part Number
1MS - SP 1 - R6 / 2 M6 G E
1
Selection
2
3
4
1. SERIES
1MS
Single pole - uses terminals 1, 2 & 3
Double pole uses terminals 1,2, 3, 4, 5 & 6
Three pole uses terminals 1,2, 3, 4, 5, 6, 7, 8 & 9
3. CIRCUIT
2
3
Connected Terminals 2-1, 5-4, 8-7
NONE
ON
NONE
(ON)
OFF
ON
OFF
(ON)
OFF
(ON)
ON
ON
ON
(ON)
ON
(ON)
ON
(ON)
Contact Material
G silver 1
5. ACTUATOR COLOR
2 Black
3 Red
without Epoxy Seal
Browse Standard Parts >
1M1 - SP 1 - R8 / 2 - 2 M6 Q E
1
2
3
4
2. POLES
Four pole uses terminals 1,2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12
3. CIRCUIT
6
7
8
9
M1 Solder Lug
VS3 PC Mount, U bracket
M2 PCB
VS4 PC Mount, U bracket
M3 Quick Connect
VS5 PC Mount, U bracket
M51 Wire Wrap
M61 Snap-In, U bracket, 90° horizontal
M52 Wire Wrap
M71 Snap-In, U bracket, 90° vertical
M53 Wire Wrap
VS21 Snap-In, U bracket
M54 Wire Wrap
VS31 Snap-In, U bracket
M6 PC Mount, 90˚ horizontal VS41 Snap-In, U bracket
M7 PC Mount, 90˚ vertical VS51 Snap-In, U bracket
VS2 PC Mount, U bracket
U4 Snap-In, U bracket, 3-Pole
See dimensional specifications.
( ) - momentary
Position: 1
2
2-3, 5-6, 8-9, 11-12 Connected Terminals
1
ON
NONE
2
ON
NONE
3
ON
OFF
4
(ON)
OFF
5
ON
OFF
1
6
ON
ON
7 1
(ON)
ON
1
8
ON
ON
9 2 NONE
ON
4. ACTUATOR STYLE
R6
R7
R8
R9
Standard Rocker
Standard Paddle
Medium Rocker
Large Paddle
Large rocker
2 Black
3 Red
3
2-1, 5-4, 8-7, 11-10
ON
(ON)
ON
(ON)
(ON)
ON
(ON)
(ON)
(ON)
Rocker & frame
Paddle & frame
Rocker without frame
Paddle without frame
5. ACTUATOR COLOR / 6 FRAME COLOR
No Frame*
1 White
5
7. TERMINATION
1M1 Miniature Rocker Switch
3.
Approvals
Epoxy Seal
Configure Complete Part Number >
1. SERIES
R1
R2
R3
R4
R5
Rating
Notes:
Tin option not available with M1 and M3 terminals.
1
Movable contact and terminal platings: silver over copper alloy
2 Movable contact platings: gold over nickel over copper alloy
3 Terminal platings: gold over nickel over copper alloy
4 Terminal platings: tin over copper alloy
5 Terminal contact platings: gold over nickel alloy
6 Terminal contact platings: silver over nickel alloy
Black is standard. Other colors available, consult factory.
SP
DP
3P
4P
PC Mount, U bracket
PC Mount, U bracket
PC Mount, U bracket
PC Mount, U bracket
Snap-In, U bracket
Snap-In, U bracket
Snap-In, U bracket
Snap-In, U bracket
Vertical Mount, 3-Pole
gold over silver 5A 125VAC or 28VDC,
, IP67
2A
250VAC
4
tin
0.4VA max 20V max (AC/DC) IP67
tin 4
5A 125VAC or 28VDC,
, IP67
2A
250VAC
gold 3
8. EPOXY SEAL
R5 Large Rocker
R6 Small Rocker
R7 Medium Paddle
Standard Rocker
Standard Paddle
Medium Rocker
Large Paddle
Terminal Plating
K gold 2,5
P silver 1,6
R gold 2
E
4. ACTUATOR STYLE
Selection
VS2
VS3
VS4
VS5
VS21
VS31
VS41
VS51
U2
U4
7. CONTACTS / TERMINALS
*Center Position Connects 2-3, 5-4, 8-9
Sample
Part Number
8
( ) - momentary
Position: 1
2-3, 5-6, 8-9
1 ON
2 ON
3 ON
4 (ON)
5 ON
6 * ON
7 * (ON)
8 * ON
9 * OFF
1 White
7
M1
Solder Lug
M2
PCB
M3
Quick Connect
M51 Wire Wrap
M52 Wire Wrap
M53 Wire Wrap
M54 Wire Wrap
M6
M7
2. POLES
R1
R2
R3
R4
6
6. TERMINATION
Sealed Miniature Rocker Switch
SP
DP
3P
5
*Actuator style R8 or R9 only.
8. CONTACTS / TERMINALS
Contact Material
G silver 3
K gold 4,7
P silver 3,8
Q silver 3
R gold 4
Terminal Plating Rating
Approvals
2A 250VAC
6
tin
0.4VA max 20V max (AC/DC) N/A
tin 6
5A 125VAC or 28VDC,
2A 250VAC
silver 3
5A 125VAC or 28VDC,
2A 250VAC
gold 5
9. EPOXY SEAL
E
Epoxy Seal
without Epoxy Seal
Notes:
1
Double-Pole and Four-Pole only. Center position connects 2-3, 5-4, 8-9, 11-10
2 Double-Pole only
3 Movable contact and terminal platings: silver over copper alloy
4 Movable contact platings: gold over nickel over copper alloy
5 Terminal platings: gold over nickel over copper alloy
6 Terminal platings: tin over copper alloy
7 Terminal contact platings: gold over nickel alloy
8 Terminal contact platings: silver over nickel alloy
Dimensional Specs
inches [millimeters]
Single Pole
.370
[9.40]
.079
[2.00]
.095
[2.40] DIA
.260
[6.60]
EPOXY SEAL
.030
[0.75]
3
1.158
[29.40]
.937
[23.80]
.500
[12.70]
.185
[4.70]
2
1
.144
[3.65]
.111
[2.83]
.347
[8.80]
.080
[2.03]
Double Pole
.079
[2.00]
.449
[11.40]
EPOXY SEAL
.030
[0.75]
.185
[4.70]
.144
[3.65]
3
2
4
1
.080
[2.03]
.111
[2.83]
.370
[9.40]
6
.500 5
[12.70]
.189
[4.80]
Three Pole
.079
[2.00]
.095
[2.40] DIA
.650
[16.50]
EPOXY SEAL
.030
[0.75]
.937
[23.80]
1.158
[29.40]
.500
[12.70]
.185
[4.70]
.148
[3.75]
R1
.095
[2.40]DIA
5
7
1.158
[29.40]
.370
[9.40]
.319
[8.10]
.095
[2.40]DIA
.131
[3.33]
.059
[1.50]
.937
[23.80]
.347
[8.80]
.079
[2.00]
.059
[1.50]
1.055
[26.80]
1.374
[34.90]
.516
[13.10]
1
.059
[1.50]
1.634
[41.50]
.630
[16.00]
3
.331R
[8.40R]
.366
[9.30]
.079
[2.00]
R3
4
2
.075
[1.90]
1.158
[29.40]
.551
[14.00]
.937
[23.80]
6
.190
[4.83]
Actuator Options for Panel Rear Mount
R2
.347
[8.80]
4.
9
.080
[2.03]
.111
[2.83]
.347
[8.80]
8
.417
[10.60]
.118
[3.00]DIA
.024
[0.60]
.154
[3.90]
.984
[25.0 ]
.713
[18.10]
.131
[3.33]
Dimensional Specs
R4
1.634
[41.50]
.094
[2.40]
1.374
[34.90]
.620
[15.75]
.516
[13.10]
1.169
[29.70]
.118
[3.00]DIA
.154
[3.90]
.024
[0.60]
R5
1.634
[41.50]
1.347
[34.20]
1.374
[34.90]
.620
[15.75]
R6
.516
[13.10]
.118
[3.00]DIA
.457
[11.60]
.095
[2.40]DIA
.283
[7.20]
.453
[11.50]
.347
[8.80]
.111
[2.83]
.079
[2.00]
.154
[3.90]
.024
[0.60]
R7
1.158
[29.40]
.937
[23.80]
.095
[2.40]DIA
.587
[14.90]
.937
[23.80]
.457
[11.60]
.347
[8.80]
.059
[1.50]
Actuator Options for PC Mount
.551
[14.00]
R1
.190
[4.83]
R2
.319
[8.10]
1.055
[26.80]
.630
[16.00]
.906
[23.00]
.315
[8.00]
R4
.984
[25.0 ]
.075
[1.90]
.713
[18.10]
.114
[2.90]
.094
[2.40]
1.067
[27.10]
.598
[15.20]
.169
[4.30]
.131
[3.33]
.059
[1.50]
.193
[4.90]
R3
.634
[16.10]
.079
[2.00]
.331R
[8.40R]
.366
[9.30]
.370
[9.40]
.984
[25.0 ]
.094
[2.40]
1.158
[29.40]
.197
[5.00]
1.164
[29.56]
.169
[4.30]
R5
R6
1.346
[34.20]
.472
[12.00]
.620
[15.75]
5.
559
[14.20]
.169
[4.30]
.453
[11.50]
.362
[9.20]
.283
[7.20]
.190
[4.83]
Dimensional Specs
.094
[2.40]
R7
.516
[13.10]
.620
[15.75]
.024
[0.60]
Termination Options
M1 Standard Solder Lug M2 PC Thru-Hole
EPOXY SEAL
EPOXY SEAL
.144
[3.65]
.078
[1.98]
M6 Single Pole
.200
[5.08]
.200
[5.08]
.500
[12.70]
M6 Three Pole
.150
[3.81]
.185
[4.70]
7
4
M7 Single Pole
.150
[3.81]
EPOXY SEAL
8
5
2
.030
[0.75]
.500
[12.70]
.200
[5.08]
.150
[3.81]
9
6
3
.565
[14.35]
.185
[4.70]
.500
[12.70]
.030
[0.75]
.185
[4.70]
.073
[1.85]DIA
.200
[5.08]
P.C.MOUNTING
3
.500
[12.70]
.073
[1.85]DIA
P.C.MOUNTING
.500
[12.70]
1
.565
[14.35]
.185
[4.70]
.030
[0.75]
.650
[16.50]
.020
[0.50]
P.C.MOUNTING
.150
[3.81]
EPOXY SEAL
.200
[5.08]
.386 [9.80]
.449
[11.40]
.050
[1.26]
.050
[1.27]
.924 [23.48]
M5-3
.185
[4.70]
.500
[12.70]
EPOXY SEAL
.016
[0.40]
M5-2
P.C.MOUNTING
.500
[12.70]
.030
[0.75]
.050
[1.26]
.020
[1.26]
.711 [18.05]
.260
[6.60]
.500
[12.70]
M6 Double Pole
DIM.'A'
M5-1
M5-4 1.022 [25.97]
THK
.030
[0.75]
EPOXY SEAL
.020
[0.50]
OPTION
CODE
.050
[1.26]
THK
.030
[0.75]
.050
[1.26]
.051
[1.30]
EPOXY SEAL
.191
[4.84]
.062
[1.57]
THK
.030
[0.75]
THK
.030
[0.75]
M5 Wire Wrap
EPOXY SEAL
.191
[4.84]
.050
[1.26]
.047
[1.20]
.080
[2.03]
M3 Quick Connect
.150
[3.81]
2
1
.020
[0.50]
6.
.200
[5.08]
.050
[1.26]
.215
[5.46]
.500
[12.70]
.150
[3.81]
.050
[1.26]
.500
[12.70]
.073
[1.85]DIA
Dimensional Specs
Termination Options
M7 Double Pole
.030
[0.75]
.020
[0.50]
.200
[5.08]
.050
[1.26]
.215
[5.46]
.150
[3.81]
.500
[12.70]
M7 Three Pole
.020
[0.50]
.200
[5.08]
.050
[1.26]
.215
[5.46]
.150
[3.81]
.565
[14.35]
.190
[4.83]
6
3
.500
[12.70] 5
2
4
1
.150
[3.81]
.500
[12.70]
.050
[1.26]
8
9
5
7
6
4
2
.150
[3.81]
3
.190
[4.83]
1
.073
[1.85]DIA
.050
[1.26]
.190
[4.83]
VS2-VS3Single Pole
EPOXY SEAL
.050
[1.26]
.321
[8.15]
.125
[3.18]
.020
[0.50]
1
.185
[4.70]
.030
[0.75]
3
2
.620
[15.75]
OPTION
CODE
DIM.'A'
VS2
.461
[11.70]
VS3
.630
[16.00]
VS2-VS3Double Pole
.321
[8.15]
.020
[0.50]
4
.185
[4.70]
.125
[3.18]
DIM.'A'
VS2
.461
[11.70]
5
6
.030
[0.75]
VS3
.630
[16.00]
.620
[15.75]
U2-VS3 Three Pole
.189
[4.80]
.050
[1.26]
.321
[8.15]
7.
.125
[3.18]
.073
[1.85]DIA
.185
[4.70]
.620
[15.75]
.073
[1.85]DIA
.190
[4.83]
P.C.MOUNTING
.190
[4.83]
'A'
.185
[4.70]
.620
[15.75]
.125
[3.18]
OPTION
CODE
EPOXY SEAL
.185
[4.70]
.050
[1.26]
.125
[3.18]
P.C.MOUNTING
.190
[4.83]
'A'
.200
[5.08]
P.C.MOUNTING
.190
[4.83]
.185
[4.70]
.200
[5.08]
P.C.MOUNTING
.650
[16.50]
.500
[12.70]
.073
[1.85]DIA
.190
[4.83]
EPOXY SEAL
.030
[0.75]
P.C.MOUNTING
.449
[11.40]
EPOXY SEAL
EPOXY SEAL
.020
[0.50]
.185
[4.70]
7
8
.620
[15.75]
9
.030
[0.75]
OPTION
CODE
DIM.'A'
U2
.551
[14.00]
VS3
.630
[16.00]
.125
[3.18]
.620
[15.75]
.185
[4.70]
.073
[1.85]DIA
.190
[4.83]
Dimensional Specs
Termination Options
VS4-VS5 Single Pole
P.C.MOUNTING
.190
[4.83]
'A'
EPOXY SEAL
.185
[4.70]
.050
[1.26]
.362
[9.20]
.020
[0.50]
1
.185
[4.70]
.250
[6.35]
2
3
.030
[0.75]
OPTION
CODE
DIM.'A'
VS4
.461
[11.70]
.250
[6.35]
.630
[16.00]
VS5
.073
[1.85]DIA
.750
[19.05]
VS4-VS5 Double Pole
P.C.MOUNTING
.190
[4.83]
'A'
EPOXY SEAL
.185
[4.70]
.050
[1.26]
.362
[9.20]
.020
[0.50]
.250
[6.35]
.185
[4.70]
4
5
6
.030
[0.75]
OPTION
CODE
DIM.'A'
VS4
.461
[11.70]
VS5
.630
[16.00]
.750
[19.05]
.250
[6.35]
.073
[1.85]DIA
.190
[4.83]
P.C.MOUNTING
.190
[4.83]
'A'
EPOXY SEAL
.020
[0.50]
.189
[4.80]
.362
[9.20]
.185
[4.70]
.250
[6.35]
.030
[0.75]
OPTION
CODE
DIM.'A'
U4
.551
[14.00]
VS5
.630
[16.00]
.750
[19.05]
.190
[4.83]
.750
[19.05]
.250
[6.35]
VS21, VS31
.020
[0.50]
.071
[1.80]
.050
[1.26]
.110
[2.80]
.043
[1.10]
.020
[0.50]
VS41, VS51
.051
[1.30]
.020
[0.50]
.071
[1.80]
.110
[2.80]
.050
[1.26]
.043
[1.10]
.020
[0.50]
* PC Mounting for M61, M71, VS21, VS31, VS41, VS51 refer to M6, M7, VS2, VS3, VS4, VS5 respectively.
8.
.185
[4.70]
.073
[1.85]DIA
Snap-In Termination Options
M61
.051
[1.30]
.185
[4.70]
.750
[19.05]
U4-VS5 Three Pole
.050
[1.26]
.185
[4.70]
.750
[19.05]
Dimensional Specs
Single Pole
.095
[2.40]DIA
.020
[0.50]
Double Pole
.260
[6.60]
.374
[9.50]
.020
[0.50]
.095
[2.40]DIA
.374
[9.50]
.987
[23.80]
1.165
[29.60]
.500
[12.70]
.185
[4.70]
.937
[23.80]
.156
[3.95]
.276
[7.00]
.152
[3.85]
.276
[7.00]
Three Pole
.095
[2.40]DIA
.020
[0.50]
.185
[4.70]
.433
[11.00]
Four Pole
.652
[16.55]
.059
[1.50]
.185
[4.70]
.156
[3.95]
R1
.020
[0.50]
.095
[2.40]DIA
.437
[11.10]
.500
[12.70]
9
7
5
6
4
2
3
1
.500
.185 [12.70]
[4.70]
.937
[23.80]
1.165
[29.60]
.080
[2.03]
.276
[7.00]
.156
[3.95]
.152
[3.85]
.080
[2.03]
R2
.152
[3.85]
.020
[0.50]
R3
.366
[9.30]
.276
[7.00]
R4
.906
[23.00]
1.378
[35.00]
.512
[13.00]
.630
[16.00]
.724
[18.40]
.331R
[8.40R]
1.634
[41.50]
.118
[3.00]DIA
.075
[1.90]
.937
[23.80]
.095
[2.40]DIA
.319
[8.10]
.152
[3.85]
.020
[0.50]
.315
[8.00]
.152
[3.85]
.020
[0.50]
.984
[25.0 ]
1.634
[41.50]
.094
[2.40]
1.378
[35.00]
.118
[3.00]DIA
.512
[13.00]
.899
[22.83]
.598
[15.20]
.020
[0.50]
9.
.190
[4.83]
.984
[25.0 ]
1.165
[29.60]
.551
[14.00]
.276
[7.00]
.370
[9.40]
8
.190
[4.83]
1.165
[29.60]
.850
[21.60]
.059
[1.50]
.030
[0.75]
.152
[3.85]
.937
[23.80]
.095
[2.40]DIA
.190
[4.83]
.080
[2.03]
.937
[23.80]
.276
[7.00]
.500
[12.70]
.156
[3.95]
.152
[3.85]
.030
[0.75]
1.165
[29.60]
.080
[2.03]
.030
[0.75]
.030
[0.75]
1.165
[29.60]
.449
[11.40]
.055
[1.40]
1.169
[29.70]
.152
[3.85]
Dimensional Specs
R5
1.876
[47.65]
1.626
[41.30]
.126
[3.20]DIA
1.346
[34.20]
.472
[12.00]
.620
[15.75]
.504
[12.80]
R6
.150
[3.80]
.024
[0.60]
Actuator Options for Snap-In Mount
R6 WITHOUT FRAME
.784
[19.90]
.614
[15.60]
PANEL THICKNESS
.047
.125
[1.19] TO [3.18]
.118
[3.00]
.005R
[0.13R]
.728
[18.50]
.016
[0.40]
.095
[2.40]
.441
[11.20]
.295
[7.50]
PANEL MOUNTING
.472
[12.00]
MAX. TYP.
.500
[12.70]
.600 *
[15.24]
.319
[8.10]
* Increase thisdimension to .620/.625
[15.75/15.88] for .091/.125 [2.31/3.18]
thk. panels.
R7
.784
[19.90]
.614
[15.60]
R7 WITHOUT FRAME
.095
[2.40]
.728
[18.50]
.453
[11.50]
.095
[2.40]
.295
[7.50]
.047 TO .125
[3.18]
[1.19]
PANEL THICKNESS
.005R
[0.13R]
.095
[2.40]
PANEL MOUNTING
.528
[13.40]
.472
[12.00]
MAX. TYP.
.500
[12.70]
.600 *
[15.24]
.319
[8.10]
* Increase this dimension to .620/.625
thk. panels.
R1
.370
[9.40]
R2
.551
[14.00]
.366
[9.30]
.319
[8.10]
.163
[4.15]
.984
[25.0 ]
.075
[1.90]
.724
[18.40]
.331R
[8.40R]
.163
[4.15]
R3
R4
.906
[23.00]
.630
[16.00]
.315
[8.00]
.140
[3.55]
.598
[15.20]
.984
[25.0 ]
.094
[2.40]
.899
[22.83]
1.169
[29.70]
.140
[3.55]
10.
Dimensional Specs
R5
R6
1.306
[33.18]
.362
[9.20]
1.346
[34.20]
.457
[11.60]
.620
[15.75]
.140
[3.55]
.283
[7.20]
.453
[11.50]
.163
[4.15]
.094
[2.40]
R7
.648
[16.45]
.457
[11.60]
.163
[4.15]
Termination Options
M2 PC Thru-Hole
.260
[6.60]
.156
[3.95]
.080
[2.02]
.080
[2.03]
M3 Quick Connect
'A'
.062
[1.57]
THK
.030
[0.75]
THK
.030
[0.75]
OPTION
CODE
.260
[6.60]
.050
[1.26]
.047
[1.20]
M5 Wire Wrap
.050
[1.26]
THK
.030
[0.75]
THK
.030
[0.75]
.200
[5.08]
.020
[0.50]
.500
[12.70]
.050
[1.26]
1.062 [26.97]
.500
[12.70]
.200
[5.08]
.185
[4.70]
P.C.MOUNTING
.500
[12.70]
.030
[0.75]
.150
[3.81]
.500
[12.70]
.449
[11.40]
.185
[4.70]
.200
[5.08]
.185
[4.70]
.260
[6.60]
.030
[0.75]
P.C.MOUNTING
.500
[12.70]
.500
[12.70]
.150
[3.81]
.200
[5.08]
.050
[1.26]
.188
[4.78]
.150
[3.81]
.073
[1.85]DIA
M7 Single Pole
11.
.425 [10.80]
M5-4
.073
[1.85]DIA
.020
[0.50]
.200
[5.08]
.964 [24.48]
M5-3
.200
[5.08]
.050
[1.26]
.020
[0.50]
.750 [19.05]
M5-2
.500
[12.70]
M6 Double Pole
.050
[1.26]
M5-1
P.C.MOUNTING
M6 Single Pole
.051
[1.30]
DIM.'A'
.500
[12.70]
.150
[3.81]
.050
[1.26]
.073
[1.85]DIA
Dimensional Specs
Termination Options
P.C.MOUNTING
M7 Double Pole
.500
[12.70]
.030
[0.75]
.150
[3.81]
.200
[5.08]
.020
[0.50]
.050
[1.26]
.200
[5.08]
.188
[4.78]
.500
[12.70]
.150
[3.81]
.073
[1.85]DIA
P.C.MOUNTING
.652
[16.55]
M7 Three Pole
.030
[0.75]
.020
[0.50]
.565
[14.35]
.050
[1.26]
.565
[14.35]
.188
[4.78]
.073
[1.85]DIA
P.C.MOUNTING
.850
[21.60]
.030
[0.75]
.050
[1.26]
.200
[5.08]
.190
[4.83]
.190
[4.83]
.150
[3.81]
M7 Four Pole
.020
[0.50]
.565
[14.35]
.188
[4.78]
.150
[3.81]
.500
[12.70]
.565
[14.35]
12
11
9
8
6
5
3
2
10
7
4
1
.190
[4.83]
.190
[4.83]
.073
[1.85]DIA
P.C.MOUNTING
.163
[4.15]
'A'
.050
[1.26]
.321
[8.15]
.125
[5.08]
.020
[0.50]
.185
[4.70]
.030
[0.75]
OPTION
CODE
DIM.'A'
VS2
.461
[11.70]
VS3
.630
[16.00]
'A'
.321
[8.15]
12.
.125
[3.18]
.620
[15.75]
.185
[4.70]
.073
[1.85]DIA
P.C.MOUNTING
.163
[4.15]
.185
[4.70]
.150
[3.81]
.620
[15.75]
VS2-VS3 Double Pole
.050
[1.26]
.150
[3.81]
.200
[5.08]
.050
[1.26]
VS2-VS3Single Pole
.185
[4.70]
.150
[3.81]
.500
[12.70]
.200
[5.08]
.050
[1.26]
.200
[5.08]
.190
[4.83]
.020
[0.50]
.185
[4.70]
.030
[0.75]
.620
[15.75]
OPTION
CODE
DIM.'A'
VS2
.461
[11.70]
VS3
.630
[16.00]
.150
[3.81]
.620
[15.75]
.190
[4.83]
.185
[4.70]
.073
[1.85]DIA
Dimensional Specs
Termination Options
VS4-VS5 Single Pole
.163
[4.15]
DIM.'A'
VS4
.461
[11.70]
VS5
.630
[16.00]
'A'
.185
[4.70]
.050
[1.26]
.030
[0.75]
.020
[0.50]
.250
[6.35]
.185
[4.70]
.362
[9.20]
P.C.MOUNTING
OPTION
CODE
.250
[6.35]
.073
[1.85]DIA
.750
[19.05]
VS4-VS5 Double Pole
.163
[4.15]
.185
[4.70]
.020
[0.50]
.250
[6.35]
.185
[4.70]
.362
[9.20]
.030
[0.75]
P.C.MOUNTING
OPTION
CODE
DIM.'A'
VS4
.461
[11.70]
VS5
.630
[16.00]
'A'
.050
[1.26]
.250
[6.35]
.750
[19.05]
EPOXY SEAL
'A'
.185
[4.70]
.185
[4.70]
.362
[9.20]
.030
[0.75]
.750
[19.05]
.020
[0.50]
.250
[6.35]
OPTION
CODE
DIM.'A'
U4
.551
[14.00]
VS5
.630
[16.00]
.750
[19.05]
.050
[1.26]
.071
[1.80]
.110
[2.80]
.073
[1.85]DIA
.043
[1.10]
.020
[0.50]
VS41, VS51
.110
[2.80]
.020
[0.50]
.043
[1.10]
* PC Mounting for M61, VS21, VS31, VS41, VS51 refer to M6, VS2, VS3, VS4, VS5 respectively.
.190
[4.83]
.185
[4.70]
VS21, VS31
.020
[0.50]
.051
[1.30]
13.
.073
[1.85]DIA
M61
.050
[1.26]
.185
[4.70]
P.C.MOUNTING
.190
[4.83]
.250
[6.35]
.750
[19.05]
.190
[4.83]
U4-VS5 Three Pole
.050
[1.26]
.185
[4.70]
.750
[19.05]
Authorized Sales Representatives and Distributors
Click on a region of the map below to find your local representatives and distributors
or visit www.carlingtech.com/findarep.
CANADA
EUROPE
USA
MIDDLE
EAST
MEXICO
AFRICA
ASIA-PACIFIC
OCEANIA
SOUTH
AMERICA
About Carling
Founded in 1920, Carling Technologies is a leading manufacturer of electrical and
electronic switches and assemblies, circuit breakers, electronic controls, power
distribution units, and multiplexed power distribution systems. With six ISO9001 and
IATF16949 registered manufacturing facilities and technical sales offices worldwide,
Carling Technologies Sales, Service and Engineering teams do much more than
manufacture electrical components, they engineer powerful solutions! To learn more
about Carling please visit www.carlingtech.com/company-profile.
To view all of Carling’s environmental, quality, health & safety certifications please visit
www.carlingtech.com/environmental-certifications.
14.
© Carling Technologies, Inc.
Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
