XDK110
XDK110
    BOSCH(博世)
    LGA4
    XDK110
XDK110 数据手册
Cross-Domain Development Kit XDK110 Platform for Application Development General Description The XDK110 is a wireless sensor device that enables rapid prototyping of sensor based products and applications for the Internet of Things (IoT). Inclusive of multiple Micro-Electromechanical Systems (MEMS) sensors, the XDK110 enables time and cost effective realization of IoT applications while offering users the freedom of programming from a basic to an advanced level. The XDK110 is an integrated product that offers access to the XDK developer community for active information exchange, knowledge sharing, technical support and more. The device was designed to allow users an easy transition from prototype to mass production by providing a clear road to product development. Application Advantages           All-in-one sensor development kit: No need for component selection, hardware assembly, or deployment of a real-time operating system Algorithm library and sample applications convenient for first-time programming Drivers for all system components included Secure data protocol Small form factor Built-in lithium ion rechargeable battery Functional extendibility via the included extension board High-level API for the standard user and low-level API for the power user PC-based development tools make it an easy to work with tool for any developer CE, FCC and IC certified Built-in Sensors     Accelerometer (BMA280) Gyroscope (BMG160) Magnetometer (BMM150) Inertial measurement unit (BMI160) Other Main Components      Bluetooth 4.0 low energy IEEE 802.15.1 Wireless LAN IEEE 802.11b/g/n 32-Bit microcontroller (ARM Cortex M3), 1MB Flash, 128 kB RAM Internal Li-Ion rechargeable battery 560 mAh Integrated antennas    Humidity/ Pressure/ Temperature/ sensor (BME280) Acoustic noise sensor (AKU340) Digital light sensor (MAX44009) Included in delivery    XDK110 Development Kit with “XDK Gateway” extension board for easy access to additional MCU functionality, incl. 10 cm connector cable Micro USB 2.0 connector cable Mounting plate and screws © Bosch Connected Devices and GmbH 2016. All rights reserved, also regarding and disposal, exploitation, reproduction, editing, distribution, as well as in the event of application for industrial property rights. March 3, 2016 Operating Conditions        Indoor use Operating temperature range: Storage temperature range: Humidity range: IP Rating: Supply Voltage: Charging Current: -20 ºC ... 60 °C, (0 °C … 45 °C for battery charging) -20 ºC … 60 °C 10…90 %rH (non-condensing) IP 30 (IEC 60529) 5 V DC 500 mA Maximum Measurement Ranges        Accelerometer Gyroscope Magnetic field strength Light sensor Temperature Pressure Humidity ±2 … ±16 g (programmable) ±125 º/s … ±2000 º/s (programmable) ±1300 µT (X,Y-Axis); ±2500µT (Z-Axis) 0.045 lux … 188,000 lux ; 22-bit -20 ºC ... 60 °C [limited by XDK operating conditions] 300…1100 hPa 10…90 %rH (non-condensing) [limited by XDK operating conditions] Sampling Rate      Accelerometer BMA280 Gyroscope BMG160 Magnetometer BMM150 Hum./Press./Temp. BME280 Inertial Measurement Unit BMI160 2000 Hz 2000 Hz 300 Hz 182 Hz 1600 Hz (Accelerometer); 3200 Hz (Gyroscope) Software    Integrated development environment supplied with XDK Workbench (Eclipse) LWM2M communication protocol Extensive libraries and modular source code enable the developer to fully understand the system User Interface        Power switch Green system LED to display the state of charging 3 programmable status LEDs (red, orange, yellow) 2 programmable push-buttons Micro SD card slot Interface for J-Link Debug-probe Interface for extension board Contact us For further information visit our website: Bosch Connected Devices and Solutions GmbH www.xdk.bosch-connectivity.com E-mail: sales@bosch-connectivity.com © Bosch Connected Devices and GmbH 2016. All rights reserved, also regarding and disposal, exploitation, reproduction, editing, distribution, as well as in the event of application for industrial property rights. March 3, 2016
XDK110 价格&库存
很抱歉,暂时无法提供与“XDK110”相匹配的价格&库存,您可以联系我们找货
