P130-000-AUD4K6
P130-000-AUD4K6
    TRIPPLITE
    P130-000-AUD4K6
P130-000-AUD4K6 数据手册
4K HDMI Audio Extractor with TOSLINK, RCA and 3.5 mm Stereo Output, 7.1 Channel, 4K 60 Hz, HDR Highlights ● Features 3.5 mm stereo, TOSLINK optical and RCA audio outputs ● Supports multi-channel audio, including LPCM, DTS and Dolby Digital ● Supports UHD resolutions up to 4K @ 60 Hz for crystal-clear video ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy MODEL NUMBER: P130-000-AUD4K6 System Requirements ● Source device with HDMI output ● Audio device with 3.5 mm, TOSLINK or RCA audio input Package Includes Separates the audio track from an HDMI audio/video signal and sends it to a stereo receiver, speakers or other separate audio system. Ideal for connecting a Blu-ray player or other HDMI source to speakers with no HDMI input. Description The P130-000-AUD4K6 4K HDMI Audio Extractor connects an HDMI source, such as a Blu-ray player or desktop computer, to audio speakers that don’t have an HDMI input port. Recommended for home or office workstations, digital signage, and classrooms, it can save you money by eliminating the need to upgrade to a new audio system or speakers. The P130-000-AUD4K6 extracts the audio track from the HDMI signal and sends it directly to an alternate digital or analog non-HDMI audio device. To power the unit, connect the included USB Micro-B cable between the P130-000-AUD4K6 and a USB port on the HDMI source or a USB charger. The compact HDMI audio de-embedder/extractor unit features 3.5 mm stereo, TOSLINK digital optical and RCA digital audio outputs to match most non-HDMI receivers and audio devices. It supports twochannel stereo and multi-channel audio up to 7.1 surround sound. It also supports uncompressed audio, such as LPCM, and compressed audio formats, including DTS and Dolby Digital. LEDs indicate when the unit is receiving power and transmitting an audio/video signal. On the video side, the P130-000-AUD4K6 transmits UHD video resolutions up to 4K x 2K (3840 x 2160) at 60 Hz, as specified in HDMI 2.0. It supports 24-bit True Color (8 bits per channel) at 4K x 2K, 36-bit Deep Color (12 bits per channel) at 1080p and optional 3D formats up to 60 Hz. It complies with HDCP 2.2 specifications to conform to the latest equipment and encryption standards. Features Extracts Audio from an HDMI Signal and Sends It to a Separate Audio DeviceRecommended for connecting an HDMI source to speakers that don’t have HDMI inputIdeal for home or office workstations, digital signage or classroom use3.5 mm stereo, TOSLINK and RCA audio outputs connect to analog or digital non-HDMI audio equipment (audio and HDMI cables sold separately)LEDs indicate the unit is receiving power or transmitting an audio/video signal Versatile Audio OptionsSupports 2-channel stereo and multi-channel audio up to 7.1 surround soundSupports uncompressed audio, such as LPCMSupports compressed audio, such as DTS and Dolby Digital Vibrant UHD VideoTransmits UHD video resolutions up to 4K x 2K (3840 x 2160) @ 60 Hz, as specified in HDMI 2.0Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracySupports 24-bit True Color (8 bits per channel) at 4K x 2KSupports 36-bit Deep Color (12 bits per 1/2 ● P130-000-AUD4K6 4K HDMI Audio Extractor ● USB Micro-B cable, 3 ft. ● Owner’s manual channel) at 1080pSupports optional 3D formats up to 60 MHz Simple Plug-and-Play OperationNo software or drivers requiredIncluded 3 ft. USB Micro-B cable connects to HDMI source or USB charger to power the unitComplies with HDCP 2.2 standardsCompact unit measures just 3 x 2.4 x 1 in. for easy integration with your A/V setup Specifications OVERVIEW UPC Code 037332203434 Technology HDMI; Stereo Audio; Toslink/SPDIF VIDEO HDR Support Yes PHYSICAL Color Black Cable Length (ft.) 0 Cable Length (m) 0.00 CONNECTIONS Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 TOSLINK (MALE) Side B - Connector 3 3.5MM (FEMALE) Side B - Connector 4 RCA (FEMALE) WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P130-000-AUD4K6 价格&库存
很抱歉,暂时无法提供与“P130-000-AUD4K6”相匹配的价格&库存,您可以联系我们找货
