USB-C Multiport Adapter (M/2xF) - 4K HDMI,
VGA, White
MODEL NUMBER: U444-06N-HV4K
Highlights
Supports USB DisplayPort
Alternate Mode for transmitting
audio/video
Supports HDMI video
resolutions up to 3840 x 2160
(4K x 2K) @ 30 Hz
Supports VGA video resolutions
up to 1920 x 1200 (1080p) @ 60
Hz
Reversible USB-C plug
connects in either direction
Plug-and-play operation with no
software or drivers required
System Requirements
Connects your existing 4K HDMI or 1080p VGA TV, monitor or projector to the USB-C or Thunderbolt 3
port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC.
Source device with USB-C or
Thunderbolt 3 port that supports
USB DisplayPort Alternate
Mode
Display device with HDMI or
VGA input
Package Includes
U444-06N-HV4K USB-C
Multiport Adapter
Owner’s manual
Description
The U444-06N-HV4K USB 3.2 Gen 1 USB-C to HDMI/VGA 4K Adapter (M/2xF) helps you transmit digital
audio and video from your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC to a highdefinition television, monitor or projector. It’s an ideal tool for giving video presentations in conference
rooms and classrooms, editing multiple documents on a larger screen or streaming video for digital
signage.
With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your
primary display to another, duplicate the same video on both displays or change the second display to
your primary.
The plug-and-play USB-C to HDMI adapter requires no software, drivers or external power. Connect the
reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug
connects in either direction to ensure fast, easy connection every time. Then, connect the HDMI port or
the HD15 port to your HDMI or VGA display using a compatible cable (sold separately).
The U444-06N-HV4K meets HDCP 1.4 specifications. It supports HDMI video resolutions up to 3840 x
2160 (4K x 2K) at 30 Hz and VGA video resolutions up to 1920 x 1200 (including 1080p) at 60 Hz. It also
supports 300 MHz/3 Gbps per channel bandwidth (9 Gbps total). The HDMI port delivers rich 7.1-channel
surround sound.
Features
Connects an HDMI or VGA Display to Your USB-C or Thunderbolt 3 Device
● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode
Ideal for giving video presentations, editing multiple documents or streaming video for digital signage
Supports 300 MHz/3 Gbps per channel bandwidth (9 Gbps total)
Meets HDCP 1.4 specifications
Common Applications
● Extends video from your primary display to another
Duplicates the same video on 2 displays
Converts a secondary display to your primary display
Crystal-Clear Video and Digital Audio
● Supports HDMI video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz
Supports VGA video resolutions up to 1920 x 1200 (1080p) @ 60 Hz
1/5
Supports 24-bit Deep Color (8 bits per channel) on the VGA port and 30-bit Deep Color (10 bits per
channel) on the HDMI port
Supports 7.1-channel surround sound (HDMI only)
Built-In Cable with Reversible USB-C Connector
● Fumble-free reversible USB-C plug connects in either direction for quick connection every time
Ready for Instant Use
● Plug-and-play operation with no software, drivers or external power required
About the size of a credit card for easy carrying in a pocket, purse or laptop bag
Backward compatible with non-4K displays
Specifications
OVERVIEW
UPC Code
037332205704
Product Type
Multiport Adapter
Technology
HDMI; VGA/SVGA
Host Connector
USB C (MALE)
VIDEO
Video Input
USB C (MALE)
Video Output
HDMI (FEMALE); VGA
Number of Monitors Supported
1
Video Ports
HDMI (FEMALE); HD15 (FEMALE)
Video Ports Details
HDMI 1.4; HDCP 1.4
Resolutions Supported
HDMI: 4K 30Hz (3840 x 2160) VGA: 1920 x 1200 60Hz
Supported Resolutions
1920x1080 (1080p); 3840x2160 (4K)
Max Supported Video Resolution
HDMI: 3840 X 2160 (4K X 2K) @ 30HZ; VGA: 1920 X 1200 (1080P) @ 60HZ
Extended Mode
Yes
Extended Mode Details
Capable of extending a desktop via the HDMI port at a video resolution up to 3840 x 2160 (4K) @ 30 Hz or the VGA
port at a video resolution up to 1920 x 1200 (1080p) @ 60 Hz.Note: If connecting two monitors simultaneously, the
VGA port is the main extended monitor. The HDMI monitor will mirror the VGA monitor.
Mirror Mode
Yes
Mirror Mode Details
Capable of transmitting video via the HDMI port at a video resolution up to 3840 x 2160 (4K) @ 30 Hz or the VGA
Max Supported Color Depth
24-bit True Color; 30-bit Deep Color
HDR Support
No
3D Video Supported
Yes
EDID Support
No
DisplayPort Alt Mode
Yes
2/5
AUDIO
Audio Specification
7.1 channel surround sound via HDMI port
DATA
Data Ports
USB C (MALE)
INPUT
Built-In Cable Length (ft.)
0.36
Built-In Cable Length (m)
0.11
Built-In Cable Length (in.)
4.33
Bus Powered
Yes
Product Length (in.)
6
Product Length (cm.)
15.24
Product Length (ft.)
0.5
Product Length (m.)
0.15
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
Power Consumption (Watts)
0.65
USB Power Delivery (PD) Charging
Support
No
PHYSICAL
Material of Construction
PVC, ABS
Color
White
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.9mm
Wire Gauge (AWG)
28+34
Shipping Dimensions (hwd / cm)
2.01 x 11.99 x 10.01
Shipping Dimensions (hwd / in.)
0.79 x 4.72 x 3.94
Shipping Weight (kg)
0.04
Shipping Weight (lbs.)
0.09
Unit Dimensions (hwd / in.)
0.55 x 1.65 x 2.36
3/5
Unit Dimensions (hwd / cm)
1.4 x 4 x 6
Unit Packaging Type
Box
Unit Weight (lbs.)
0.07
Unit Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
BTUs
2.2 BTU/Hr
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
CONNECTIONS
Number of Ports
2
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
HD15 (FEMALE)
Side B - Connector 2
HDMI (FEMALE)
Connector Plating
Nickel
Contact Plating
Nickel
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
No
Auto MDIX Support
No
Full Duplex Support
No
Suspend Mode Support
No
Remote Wakeup Support
No
MST Support
No
Multi-Resolution Support
Yes
Ethernet Support
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
4/5
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
5/5
很抱歉,暂时无法提供与“U444-06N-HV4K”相匹配的价格&库存,您可以联系我们找货
