U444-06N-HV4GUB
U444-06N-HV4GUB
    TRIPPLITE
    U444-06N-HV4GUB
U444-06N-HV4GUB 数据手册
USB-C Multiport Adapter - 4K HDMI, VGA, USBA, GbE, HDCP, Black MODEL NUMBER: U444-06N-HV4GUB Highlights ● Transmits video signals from sources supporting USB-C DisplayPort Alt Mode ● HDMI port delivers UHD quality at resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz ● Connects you to a wired Gigabit Ethernet network when Wi-Fi is weak or unavailable ● Supports USB 3.2 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● Reversible USB-C plug connects in either direction for immediate no-fuss use Applications ● Play video from your MacBook or Chromebook on a largescreen HDTV ● Give a video presentation at a meeting, training session or conference ● Write and edit multiple documents on a bigger monitor ● Stream 4K video for digital signage at a trade show ● Connect a USB peripheral, such as an external hard drive, printer or hub ● Upload data from your notebook or download data from the Ethernet at true 10/100/1000 Mbps Ethernet speeds USB-C adapter connects an HDMI or VGA monitor, USB peripheral and wired Gigabit Ethernet network to a USB-C or Thunderbolt 3 device. Features USB 3.2 Type-C Adapter Connects an HDMI or VGA Monitor to Your USB-C or Thunderbolt 3 DeviceThis USB 3.2 Type-C adapter helps you transmit digital audio and 4K video from your tablet, laptop, Chromebook, MacBook, smartphone or PC to an HDMI-enabled television, monitor or projector. It’s an ideal tool for giving video presentations in conference rooms and classrooms, editing multiple documents on a larger screen, or streaming video for digital signage in crystal-clear 4K. Supports USB-C DisplayPort Alternate Mode for Transmitting Audio/Video SignalsBy connecting the built-in USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to a compatible monitor, television or projector without installing special software drivers. System Requirements Transmits Crystal-Clear 4K HDMI Video and Digital AudioTo send digital audio and Ultra High Definition video to a 4K-ready HDMI television, projector or monitor, connect the HDMI port to the display using an HDMI cable (such as Tripp Lite’s P568-Series, sold separately). The USB to HDMI 4K adapter supports video resolutions up to 3840 x 2160 (4K x 2K) at 30 Hz with 7.1-channel surround sound. It’s backward compatible with 1080p displays, allowing you to use it with older equipment. The VGA port (Tripp Lite P502-Series VGA cables sold separately) supports high-definition resolutions up to 1920 x 1200, including 1080p, at 60 Hz. USB Port Connects Peripherals and Transfers Data at Fast USB 3.2 Gen 1 SpeedsThe USB-A 3.2 Gen 1 port accepts USB peripherals, such as a flash drive, mouse, keyboard or printer. It transfers data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. It is backward compatible with previous USB generations, so you can continue using older peripherals while getting high-speed performance from new devices. Note: Host must support USB OTG (On-the-Go). Accesses a Wired Gigabit Ethernet NetworkThe RJ45 port offers access to a Gigabit Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Built-In USB-C Cable Connects in Either DirectionConnect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. 1/5 ● Source device with USB-C or Thunderbolt 3 output that supports USB DisplayPort Alternate Mode ● Display device with HDMI or VGA input Package Includes ● U444-06N-HV4GUB USB-C Multiport Adapter, Black ● Owner’s manual Ready to Use Right Out of the PackageThe plug-and-play USB Type-C adapter is specifically designed for the MacBook, Google Chromebook Pixel and other laptops, tablets and devices equipped with a USBC or Thunderbolt 3 port. It requires no software, drivers or external power. Specifications OVERVIEW UPC Code 037332210487 Product Type Multiport Adapter Technology Cat5/5e; Cat6; HDMI Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE); VGA Number of Monitors Supported 1 Video Ports HDMI (FEMALE); HD15 (FEMALE) Video Ports Details HDMI 1.4; HDCP 1.4 Resolutions Supported HDMI: 4K 30Hz (3840 x 2160) VGA: 1920 x 1200 60Hz Supported Resolutions 1920x1080 (1080p); 3840x2160 (4K) Max Supported Video Resolution HDMI: 3840 X 2160 (4K X 2K) @ 30HZ; VGA: 1920 X 1200 (1080P) @ 60HZ Extended Mode Yes Extended Mode Details A desktop can be extended to a single display (either HDMI or VGA) at the following resolutions:3840 x 2160 (4K) @ 30 Hz HDMI1920 x 1080p @ 60 Hz VGA Mirror Mode Yes Mirror Mode Details Video out can be mirrored on a single display (either HDMI or VGA) at the following resolutions:3840 x 2160 (4K) @ 30 Hz HDMI1920 x 1080p @ 60 Hz VGA HDR Support No 3D Video Supported Yes EDID Support No AUDIO Audio Specification 7.1 channel surround sound via HDMI port DATA Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) 2/5 NETWORK Network Ports RJ45 (FEMALE) INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Built-In Cable Length (cm) 11 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 2.8 USB Power Delivery (PD) Charging Support No External Power Supply Yes USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Connection), Orange (Activity) CHARGING Charging Ports Details USB 3.2 Gen 1 port supports up to 900mA (0.9A) charging Charging Ports / Amps 0.9A PHYSICAL Material of Construction PVC, ABS Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Wire Gauge (AWG) 28/34 3/5 Shipping Dimensions (hwd / cm) 2.31 x 13.97 x 9.91 Shipping Dimensions (hwd / in.) 0.91 x 5.50 x 3.90 Shipping Weight (kg) 0.05 Shipping Weight (lbs.) 0.10 Unit Dimensions (hwd / in.) 0.61 x 4.06 x 2.05 Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 9.6 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3u; 802.3az; 802.3x CONNECTIONS Number of Ports 4 RJ45 Ports 1 RJ45 Ports Detail 10/100/1000 Mbps (Gigabit) Ethernet Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 USB C (FEMALE) Side B - Connector 5 DB15 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.4 USB Hub Ports Yes USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No 4/5 Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes MST Support No Multi-Resolution Support Yes Ethernet Support Yes STANDARDS & COMPLIANCE Certification & Compliance RoHS; CE (Europe); FCC (USA); REACH WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 5/5
U444-06N-HV4GUB
物料型号: - 型号:U444-06N-HV4GUB
器件简介: - 这是Tripp Lite生产的USB-C多端口适配器,可以连接HDMI或VGA显示器、USB外设和有线千兆以太网网络到USB-C或Thunderbolt 3设备。
引脚分配: - 视频输入:USB-C(公) - 视频输出:HDMI(母)、VGA(母) - 数据端口:USB-A(母) - 网络端口:RJ45(母)
参数特性: - 支持USB-C DisplayPort替代模式,最高3840x2160(4Kx2K)@30Hz分辨率 - HDMI端口支持4K 30Hz(3840x2160)分辨率,VGA端口支持最高1920x1200 60Hz分辨率 - USB-A 3.2 Gen 1端口支持最高5Gbps传输速度 - RJ45端口支持10/100/1000 Mbps以太网速度
功能详解: - 支持USB 3.2 Gen 1速度,最高5Gbps,以确保快速数据传输 - 支持3D视频 - 不支持HDR,但通过HDMI端口支持7.1声道环绕声 - 支持USB-C DisplayPort替代模式,可从支持的源设备传输4K视频和数字音频
应用信息: - 适用于在大屏幕HDTV上播放视频、进行视频会议、编写和编辑文档、流式传输4K视频等场景
封装信息: - 产品尺寸:6英寸(15.24厘米) - 包装类型:盒装 - 工作温度范围:32至113华氏度(0至45摄氏度) - 存储温度范围:14至158华氏度(-10至70摄氏度)
认证与合规: - 产品符合RoHS、CE(欧洲)、FCC(美国)、REACH等标准 - 提供3年有限保修期
U444-06N-HV4GUB 价格&库存
很抱歉,暂时无法提供与“U444-06N-HV4GUB”相匹配的价格&库存,您可以联系我们找货
