B118-002-UHD-2
B118-002-UHD-2
    TRIPPLITE
    B118-002-UHD-2
B118-002-UHD-2 数据手册
2-Port HDMI Splitter - HDCP 2.2, 4K @ 60 Hz, HDR, TAA MODEL NUMBER: B118-002-UHD-2 Highlights ● Supports UHD resolutions up to 4K @ 60 Hz (3840 x 2160) for crystal-clear video ● Distributes A/V up to 15 ft. when used with 28 AWG HDMI cable ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy ● Expand the number of connected displays, up to 32, by cascading up to 3 levels of splitters together ● Plug-and-play operation with no software required for easy, immediate installation System Requirements Transmits Ultra High Definition (UHD) 4K x 2K audio/video (A/V) from an HDMI source to two HDMI displays at the same time. Recommended for digital signage in classrooms, churches, office buildings, restaurants/bars, etc. ● HDMI Source ● HDMI Monitor(s) Package Includes ● B118-002-UHD-2 2-Port 4K 3D HDMI Splitter ● External power supply (Input: 100–240V, 50/60 Hz, 0.35A; Output: 5V 2A) ● International plug adapters (North America, Europe, U.K. and Australia) ● Mounting hardware ● Owner’s manual Description The B118-002-UHD-2 2-Port 4K 3D HDMI Splitter transmits a UHD 4K @ 60 Hz (3840 x 2160) audio/video signal from an HDMI source, such as a Blu-ray player or computer, to two HDMI monitors, projectors or televisions at the same time. Ideal for classrooms, churches, offices, restaurants, bars, trade shows and anywhere else featuring 4K x 2K digital signage, the B118-002-UHD-2 is quick and simple to install with no software or drivers necessary. Using standard 28 AWG HDMI cabling, this splitter can transmit a 4K (3840 x 2160) signal up to 15 feet (4.6 meters). It supports a wide range of audio formats, including DTS-HD, Dolby TrueHD, Dolby Digital Plus, and LPCM 7.1-channel surround sound, as well as 36-bit Deep Color (12 bits per channel). The Full 3D-compliant B118-002-UHD-2 also supports HDCP 2.2 for up-to-date content protection. Note: The B118-002-UHD-2 sends the same image to all connected displays. If you would like to extend an image over multiple displays, you will need an MST hub, such as the B156-002-HD-V2. Features Transmits a 4K HDMI A/V Signal to 2 HDMI Displays Simultaneously ● Recommended for 4K digital signage in classrooms, churches, offices, restaurants, bars, trade shows, etc. ● Distributes A/V signals up to 15 ft. (4.6 m) when used with standard 28 AWG HDMI cable ● Supports UHD resolutions up to 4K @ 60 Hz for crystal-clear video ● Compliant with HDCP 2.2 and EDID to ensure compatibility with latest A/V hardware ● Cascade up to 3 levels of splitters together to increase the number of connected monitors up to 32. Supports the Most Up-To-Date Features and Formats ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy ● Full 3D ● DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1-channel surround sound audio ● 36-bit Deep Color (12 bits per channel) ● Video amplifier bandwidth of 600 MHz/6 Gbps per channel (18 Gbps total) ● Lip sync pass-through, xvYCC and x.vColor 1/4 Easy to Use Almost Anywhere ● Plug-and-play operation with no software required for easy, immediate installation ● Supports desktop use or wall-mounting using included hardware ● Power supply includes international plug adapters (North America, Europe, U.K. and Australia) TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332200648 Device Compatibility Monitor/HDTV Technology HDMI Host Connector HDMI (FEMALE) VIDEO Max Supported Video Resolution 4K @ 60Hz (3840 x 2160) Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 3.61 Product Length (ft.) 0.300 POWER Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.35A; Output: 5V, 2A, 4 ft External Power Supply Input Specs (V / Hz / A) 100-240V, 50/60HZ, 0.35A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.0 2/4 External Power Supply Cord Length (m.) 1.2 DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve External Power Supply Plug(s) NEMA 5-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia USER INTERFACE, ALERTS & CONTROLS LED Indicators (x1) Green (Power), (x2) Orange (Signal) PHYSICAL Color Black Material of Construction Metal Included Mounting Accessories Yes Rackmountable Yes Shipping Dimensions (hwd / in.) 2.17 x 7.24 x 6.46 Shipping Dimensions (hwd / cm) 5.51 x 18.39 x 16.41 Shipping Weight (lbs.) 0.99 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 2.160 x 6.450 x 7.240 Unit Dimensions (hwd / cm) 5.49 x 16.38 x 18.39 Unit Packaging Type Box Unit Weight (lbs.) 0.187 Unit Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Connector Plating Nickel 3/4 FEATURES & SPECIFICATIONS HDCP Specification 2.2 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL; cUL; TUV; CCC; PSE; C-Tick; GS; RoHS Product Certifications NOM (Mexico) Product Compliance RoHS; CE (Europe); REACH; WEEE; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
B118-002-UHD-2 价格&库存
很抱歉,暂时无法提供与“B118-002-UHD-2”相匹配的价格&库存,您可以联系我们找货
