SMDA03LCCTR
SMDA03LCCTR
    SMCDIODESOLUTIONS(桑德斯)
    SOIC8_150MIL
    SMDA03LCCTR
SMDA03LCCTR 数据手册
SMDA03LCC THRU SMDA24LCC Technical Data Data Sheet N0301, Rev. B SMDA03LCC THRU SMDA24LCC TVS ARRAY SERIES Description The SMDAXXLCC series of TVS array have been designed to provide bidirectional protection for sensitive electronics from damage due to voltage transients caused by electrostatic discharge (ESD), electrical fast transients (EFT), lightning and other voltage-induced transient events. The device can be used to protect combinations of four bidirectional lines. SO-8 Schematic & Pin Configuration Features            Mechanical Characteristics     Protects 3.3, 5, 12, 15, 24 V Components Bidirectional Provides Electrically Isolated Protection 300 W @ 8/20 us Protects 4 Lines SO-8 Packaging LOW CAPACITANCE: 5PF “-A” is an AEC-Q101 qualified device This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Application SO-8 Surface Mount Package Approximate Weight: 0.1 grams PIN #1 Indicator: DOT on top of package Packaging: Tubes or Tape & Reel per EIA Standard 481       RS-232 & RS-422 data lines Microprocessor Based Equipment Notebooks, Desktops, & Servers LAN/WAN Equipment Serial and Parallel Port Peripherals Absolute Maximum Ratings: Parameter Symbol Value Units Peak Pulse Power, 8/20 μs Wave shape P 300 W Operating Temperature TJ -55 to +125 C Storage Temperature Tstg -55 to +150 C Lead Soldering Temperature TL 260 (10 Sec.) C  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMDA03LCC THRU SMDA24LCC Technical Data Data Sheet N0301, Rev. B Electrical Characteristics@25°C Stand-off Voltage Vwm (V) Max Breakdown Voltage VBR @1mA (V) Min Clamping Voltage Vc @1A (V) Max Leakage Current IR @ Vwm (uA) Max Capacitance (f = 1MHz) C @ 0V (pF) Max Temperature Coefficient of VBR a(VBR) mv/°C Max SMDA03LCC 3.3 4 7 200 15 -5 SMDA05LCC 5.0 6 9.8 20 15 1 SMDA12LCC 12.0 13.3 19 1 15 8 SMDA15LCC 15.0 16.7 24 1 15 11 SMDA24LCC 24.0 26.7 43 1 15 28 Part Number Ratings and Characteristics Curves Ordering Information Device SMDA03LCC THRU SMDA24LCC SMDA03LCCTR THRU SMDA24LCCTR Marking Diagram Package Shipping SO-8 (Pb-Free) 2500pcs / reel SO-8 (Pb-Free) 2500pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Where XXXXX is YYWWL SMDA03LCC S YY WW L = Part Number =S = Year = Week = Lot Number Cautions:Molding resin  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMDA03LCC THRU SMDA24LCC Technical Data Data Sheet N0301, Rev. B Circuit Diagram Ideal for Ethernet applications, SMDAxxLCC Series provides up to four (4) lines of protection in a common-mode configuration. Circuit connectivity is as follows: ✔ TPIN is connected to Pin 5. ✔ TPIP is connected to Pin 6. ✔ TPON is connected to Pin 1. ✔ TPOP is connected to Pin 2. ✔ Pins 3, 4, 7 & 8 are connected to ground. Mechanical Dimensions SO-8 SYMBOL Millimeters Inches MIN. MAX. MIN. MAX. A A1 A2 b 1.350 0.100 1.350 0.306 1.800 0.250 1.750 0.510 0.053 0.004 0.053 0.012 0.071 0.010 0.069 0.020 c 0.150 0.300 0.006 0.012 D e E E1 L 4.720 1.140 5.700 3.750 0.300 5.120 1.400 6.300 4.150 1.270 0.186 0.045 0.224 0.148 0.012 0.202 0.055 0.248 0.163 0.050 θ 0° 8° 0° 8° Carrier Tape Specification SO-8  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SMDA03LCC THRU SMDA24LCC Technical Data Data Sheet N0301, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SMDA03LCCTR
物料型号:SMDA03LCC至SMDA24LCC
器件简介:这些TVS阵列设计用于为敏感电子设备提供双向保护,以防止由静电放电(ESD)、电气快速瞬变(EFT)、雷击和其他电压引起的瞬变事件造成的损害。该设备可用于保护四条双向线路的组合。
引脚分配:SO-8封装,具有电气隔离保护,300W @ 8/20μs脉冲功率,低电容:5pF。
参数特性:包括工作温度范围(-55°C至+125°C)、存储温度范围(-55°C至+150°C)、焊接温度(260°C,10秒内)等。
功能详解:适用于RS-232和RS-422数据线、基于微处理器的设备、笔记本电脑、台式机和服务器、LAN/WAN设备、串行和并行端口以及外围设备。
应用信息:适用于以太网应用,提供高达四条线路的保护。
封装信息:SO-8表面贴装封装,重量约为0.1克,符合EIA标准481的管装或卷装。
SMDA03LCCTR 价格&库存
很抱歉,暂时无法提供与“SMDA03LCCTR”相匹配的价格&库存,您可以联系我们找货
