TS1117BCW33 RPG
TS1117BCW33 RPG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT223
    TS1117BCW33 RPG
TS1117BCW33 RPG 数据手册
TS1117B Series Taiwan Semiconductor 1A Low Dropout Positive Voltage Regulator DESCRIPTION TS1117B are high FEATURES performance positive voltage regulators are designed for use in applications requiring low dropout performance at full rated current. Additionally; TS1117B provides excellent regulation over variations due to changes in line, load and temperature. Outstanding features include low dropout performance at rated current, fast transient response, internal current limiting and thermal shutdown protection of the output device. TS1117B are three terminal ● ● ● ● ● ● ● ● ● regulators with fixed and adjustable voltage options available in popular packages. ● Low Dropout Performance 1.5V max. Fast Transient Response Built-in thermal shutdown Output Current Limit Line Regulation Typical 0.2% Load Regulation Typical 0.05% Low-ESR Ceramic Capacitor (MLCC) required for Stability. Good Ripple Rejection Compliant to RoHS Directive 2011/65/EU and WEEE 2002/96/EC Halogen-free according to IEC 61249-2-21 APPLICATION TO-252 (DPAK) ● PC peripheral ● Communication ● Consumer equipment SOT-223 Pin Definition: 1. Fixed / Adj 2. Output (Tab) 3. Input Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020 TYPICAL APPLICATION CIRCUIT Fixed output voltage version Adjustable output voltage version 1 Version: H1607 TS1117B Series Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS PARAMETER Input Supply Voltage Recommend Operation Input Supply Voltage Power Dissipation (Note 2) Operating Temperature Range Junction Temperature Range Storage Temperature Range o Lead Soldering Temperature (260 C) SYMBOL VIN VIN (Opr. Typ.) PD TOPER TJ TSTG LIMIT 15 12 Internal limited -40 ~ +125 +150 -65 ~ +150 UNIT V V 5 s TO-252 SOT-223 o C C o C o THERMAL PERFORMANCE LIMIT PARAMETER SYMBOL Junction to Ambient Thermal Resistance RӨJA UNIT SOT-223 TO-252 130 105 °C/W Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB in still air. ELECTRICAL SPECIFICATIONS (TA=25oC, unless otherwise noted) PARAMETER CONDITIONS Reference Voltage Output Voltage (Note 4) Line Regulation Load Regulation (Note 1,2) SYMBOL MIN TYP MAX UNIT VREF 1.225 1.25 1.275 V VIN = 2.7V~12V, IO=1A 1.176 1.2 1.224 VIN = 3V~12V, IO=1A 1.470 1.5 1.530 2.450 2.5 2.550 VIN = 4.8V~12V, IO=1A 3.235 3.3 3.366 VIN = 6.5V~12V, IO=1A 4.900 5.0 5.100 VIN = 2.75, IO=1A VIN = 4V~12V, IO=1A VOUT VO +1.5V ≤ VIN ≤ 12V, IO = 10mA REGLINE -- 0.2 0.5 % VIN = VOUT+1.5V, IO = 10mA~1A REGLOAD -- 0.05 1.0 % VDROP -- 1.3 1.5 V IQ -- 5 10 mA IADJ -- 90 -- µA ILIMIT 1.1 -- -- A -- 0.5 -- % -- 60 70 dB Dropout Voltage IO =1A, ∆VOUT = 1% VOUT Quiescent Current VIN = 5V Adjustable Pin Current Output Current Limit VIN - VOUT = 1.5V Temperature Stability IO =10mA, Ripple Rejection V f= 120Hz, IO= 1A, COUT =25µF, VIN = VOUT+3V RR Note: 1. See thermal regulation specification for changes in output voltage due to heating effects. Line and load regulation are measured at a constant junction temperature by low duty cycle pulse testing. Load regulation is measured at the output lead = 1/18” from the package. 2. Line and load regulation are guaranteed up to the maximum power dissipation of 15W. Power dissipation is determined by the input / output voltage difference and the output current. Guaranteed maximum power dissipation will not be available over the full input / output voltage range. 3. Quiescent current is defined as the minimum output current required to maintain the regulation. 4. The Output Capacitor does not have a theoretical upper limit and increasing its value will increase stability. COUT=100uF or more is typical for high current regulator design. 2 Version: H1607 TS1117B Series Taiwan Semiconductor FUNCTION BLOCK ORDERING INFORMATION OUTPUT VOLTAGE PART NO. PACKAGE PACKING TS1117BCP ROG TO-252 (DPAK) 2,500pcs / 13" Reel TS1117BCW RPG SOT-223 2,500pcs / 13" Reel 1.2V TS1117BCW12 RPG SOT-223 2,500pcs / 13" Reel 2.5V TS1117BCW25 RPG SOT-223 2,500pcs / 13" Reel TS1117BCP33 ROG TO-252 (DPAK) 2,500pcs / 13" Reel TS1117BCW33 RPG SOT-223 2,500pcs / 13" Reel TS1117BCP50 ROG TO-252 (DPAK) 2,500pcs / 13" Reel TS1117BCW50 RPG SOT-223 2,500pcs / 13" Reel ADJ 3.3V 5V 3 Version: H1607 TS1117B Series Taiwan Semiconductor CHARACTERISTICS CURVES Figure 1. VDROP vs. Output Current Figure 2. Load Regulation vs. Temperature Figure 3. VOUT Change vs. Temperature Figure 4. VOUT Deviation vs. Temperature Figure 5. Line Transient Response Figure 6. Load Transient Response 4 Version: H1607 TS1117B Series Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-252 SUGGESTED PAD LAYOUT MARKING DIAGRAM Y M = Year Code = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code XX = Output Voltage Code (3.3=3.3V, 5.0=5V) = CP for Adjustable output voltage version 5 Version: H1607 TS1117B Series Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-223 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y M = Year Code = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code XX = Output Voltage Code (1.2=1.2V, 2.5=2.5V, 3.3=3.3V, 5.0=5V) = CW for Adjustable output voltage version 6 Version: H1607 TS1117B Series Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: H1607
TS1117BCW33 RPG 价格&库存
很抱歉,暂时无法提供与“TS1117BCW33 RPG”相匹配的价格&库存,您可以联系我们找货
