TP094003-1
TP094003-1
    DBUNLIMITED
    TP094003-1
TP094003-1 数据手册
4 3 2 1 Part Number: DRAWN TP094003-1 12/19/2016 CJ CHECKED 12/19/2016 P.D. Description: APPROVED Piezo Transducer 12/19/2016 J.S. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Bottom View Side View C C 1.00 9.00 Max. 1.90 3.20 1.50 1.50 2.00 9.00 Sound Emission Hole 0.30 1.50 B A B Items Specifications Conditions Sound Pressure Level 70 dB (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 3 V Voltage Range 1 ~ 25 V Capacitance 12,000 pF Max. Rated Current 3 mA Storage Temperature -40 ~ +85 C Operating Temperature -40 ~ +85 C Connection Method Surface Pads Mount Type Surface Mount Housing Material LCP Weight 0.2 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 3/31/2014 J.S. 1 Updated to new template 12/19/2016 J.S. 2 Updated specs and sound emission hole description 4/2/2020 J.S. NOTES 1) All dimensions are in mm unless otherwise noted 2) All tolerances are 0.5 mm unless otherwise noted 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 A
TP094003-1 价格&库存
很抱歉,暂时无法提供与“TP094003-1”相匹配的价格&库存,您可以联系我们找货
TP094003-1
  • 1+14.029551+1.81732
