IN-S126TASRGB
IN-S126TASRGB
    INOLUX(英诺斯)
    SMD-4P,3.2x1.5mm
    1206贴片式侧面发光LED,PCB型
IN-S126TASRGB 数据手册
IN-S126TASRGB Side View SMD LED 1206 PCB Type Features • 1206 1.0mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Side View • High reliability • Clear Lens Description The IN-S126TASRGB is a popular 1206 side view RGB package with versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S126TASRGB Solder Pattern Package Dimensions in mm Notes. 1. All dimensions are in millimeters. 2. Tolerance is ± 0.1 mm unless otherwise noted Figure 2. IN-S126TASRGB Package Dimensions Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 1 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) Red 75 25 70 IN-S126TASRGB Blue 75 25 VR (V) TOP (oC) TST (oC) 5 -30~+85 -40~+90 100 Green Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Electrical Characteristics T A Product IN-S126TASRGB = 25°C (Note 1) VF(V) IF Emission Color (mA) Viewing λ(nm) I*V(mcd) Angle typ. max λD λP △λ 2θ1/2 Min. typ. Max Red 20 1.6 2.6 615~630 625 20 120 150 250 350 Green 20 2.8 3.6 515~530 523 35 120 700 1100 1500 Blue 20 2.8 3.6 461~470 470 30 120 150 200 300 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 2 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 3 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 4 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product IN-S126TASRGB Inolux Corporation Proprietary & Confidential Emission Color Test Current Technology IF (mA) Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Red AllnGaP 20 250 2.0 Green InGaN 20 1100 3.2 Blue InGaN 20 200 3.2 Orderable Part Number IN-S126TASRGB September, 30, 2020 Page 5 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Label Specifications Inolux P/N: I N - S 1 Material Inolux SMD S = PCB Type 2 6 T Package A Variation S R G Orientation Current Lens Color 126TA = 3.2 x 1.5 x 1.0mm Tri-Chip S= Side View (Blank) = 20mA (Blank) = Clear R=625nm G=523nm B=470nm 2 1 B - - - - Customized Stamp-off - Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 0 7 Year (2017, 2018, …..) 01 24 001 Month Date Serial September, 30, 2020 Page 6 www.inolux-corp.com - IN-S126TASRGB Side View SMD LED 1206 PCB Type Packaging Information: 3000pcs Per Reel Tape Dimension Unit: mm Tolerance: +/-0.10 mm Reel Dimension Unit: mm Tolerance: +/-0.15mm Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 7 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 3000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 8 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential September, 30, 2020 Page 9 www.inolux-corp.com IN-S126TASRGB Side View SMD LED 1206 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S126TASRGB 价格&库存
很抱歉,暂时无法提供与“IN-S126TASRGB”相匹配的价格&库存,您可以联系我们找货
IN-S126TASRGB
  • 1+5.116381+0.66318
  • 10+3.5079210+0.45470
  • 100+2.52536100+0.32734
  • 500+2.08484500+0.27024
  • 1000+1.939931000+0.25146
库存:43222
IN-S126TASRGB
    IN-S126TASRGB
      IN-S126TASRGB
        库存:24000
