Premium RTV Silicone Adhesive Sealant
1035 Technical Data Sheet
ISO 9001:2008 Registered Quality System. Burlington, Ontario, CANADA
1035
SAI Global File: 004008
Description
The 1035 Premium RTV Silicone Adhesive Sealant is a one-part, spreadable, non-corrosive, translucent
paste. It is a fast curing and designed to provide quick initial adhesion build. The adhesive sealant retains
elastomeric properties for long periods at temperatures from -60 to 204 °C (-76 to 399 °F).
The 1035 is excellent for the sealing and bonding of electronic components onto printed circuit boards and
protecting copper connections on electronic part assemblies. It also provides excellent weather proofing
where power cords enter motors. It can be used as a gasket for leak resistant sealing and insulating.
Benefits and Features
UL HB Recognition (File # E36952)
Fast cure—modified alkoxy (neutral) cure
Primerless adhesion to many plastics, metals, wood, glass, and ceramics
Provides electrical insulation
Excellent chemical and weather resistance
High strength
Suited for marine applications
Usage Parameters
Properties
Tack Free
Full Cure @22 °C [72 °F]
Shelf Life
Application Rate
Temperature Ranges
Value
15 min
24 h
2y
360 gm/min
Properties
Storage Temperature
Cured 1035 Properties
Physical Properties
Color
Flexibility
Flammability
Value
Translucent
Excellent
HB
Mechanical Properties a)
Value
Hardness, Shore A
24A
Tensile Strength
21 kg/cm2
Elongation
435%
Tear Strength
7.1 kg/cm
Peel Strength
Glass
7.5 kg/cm
Aluminum
8.6 kg/cm
Lexan Polycarbonate
7.1 kg/cm
PVC
8.0 kg/cm
a) Cured at 25 °C [77 °F] and 50% relative humidity for 7 days
Page 1 of 4
Date: 29 March 2021 / Ver. 1.02
[300 lb/in2]
[40 lb/in]
[42
[48
[40
[45
lb/in]
lb/in]
lb/in]
lb/in]
Value
16 to 27 °C
[60 to 80 °F]
1035
Electrical Properties b)
Volume Resistivity
Dielectric Strength
Dielectric Constant @100 Hz
Dissipation Factor @100 Hz
Value
2 x 1015 Ωcm
17 kV/mm
2.8
0.002
Thermal Properties b)
Coefficient of Thermal Expansion
Thermal Conductivity
Brittle Point
Value
300 ppm/°C
0.06 W/(m·K)
-60 °C [-75 °F]
[425 V/mil]
[0.10 Btu·ft/ft2·h·°F]
b) Information is provided for customer convenience. The properties are not tested on a routine basis.
Uncured 1035 Properties
Physical Properties
Odor
Viscosity
Specific Gravity
Flash Point
Value
Ammonia-like
Paste
1.04 g/mL
100 °C [230 °F]
Compatibility
A primer is not required; however, for difficult to bond substrates, a primer is recommended.
NOTE: Not recommended for use on polycarbonates and acrylics. Will discolor sensitive metals (copper
and brass) only when in direct contact.
The 1035 is compatible with most materials found on printed circuit assemblies; however, in an uncured
state it is not compatible with contaminants like water, oil, and greasy flux residues. Therefore, it is
extremely important to clean the printed circuit assembly thoroughly with a suitable electronic cleaner
before applying the coating (see recommended cleaners on page 4).
ATTENTION ! Perform a compatibility test in a representative environment prior to use to determine if
other incompatibilities may be present.
Storage
Store between 16 and 27 °C [60 and 80 °F] in dry area away from sunlight.
Page 2 of 4
1035
Health, Safety, and Environmental Awareness
Please see the 1035 Safety Data Sheet (SDS) for more details on transportation, storage, handling and
other security guidelines.
Health and Safety: Suspected of damaging fertility or the unborn child. May cause an allergic skin
reaction. Avoid breathing vapors. Wear protective gloves/protective clothing. Contaminated work clothing
should not be allowed out of the workplace.
HMIS® RATING
NFPA® 704 CODES
* 1
HEALTH:
FLAMMABILITY:
1
PHYSICAL HAZARD:
1
PERSONAL PROTECTION:
Approximate HMIS and NFPA Risk Ratings Legend:
0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe)
Application Instructions
The 1035 can be dispensed via caulking cartridges by manual caulking or air operated guns. The adhesive
sealant should be applied in a less than 6 mm (1/4 in) diameter bead or ribbon around the edge of the
surface to be bonded.
To apply the adhesive sealant
1. Clean and dry the surface of the substrate to remove oil, dust, water, solvents, and other
contaminants.
2. Apply the adhesive sealant, ensuring adequate coverage and desired thickness.
3. Allow a full cure at room temperature for at least 24 hours.
ATTENTION! Exact cure time will vary depending on temperature, humidity, and thickness.
NOTE: Adequate bond strength will develop in 4-6 hours to permit handling of parts.
Packaging and Supporting Products
Cat. No.
1035-85ML
1035-85MLCA
Packaging
Tube
Tube
Net Weight
88.1 g
88.1 g
Page 3 of 4
Net Volume
85 mL
85 mL
1035
Technical Support
Contact us regarding any questions, improvement suggestions, or problems with this product. Application
notes, instructions, and FAQs are located at www.mgchemicals.com.
Email: support@mgchemicals.com
Phone: +(1) 800-340-0772
+(1) 905-331-1396
+(44) 1663 362888
Fax: +(1) 905-331-2862
Mailing address:
(Canada, Mexico & USA)
(International)
(UK & Europe)
or +(1) 800-340-0773
Manufacturing & Support
1210 Corporate Drive
Burlington, Ontario, Canada
L7L 5R6
Head Office
9347–193rd Street
Surrey, British Columbia, Canada
V4N 4E7
Disclaimer
This information is believed to be accurate. It is intended for professional end users having the skills to
evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and
assumes no liability in connection with damages incurred while using it.
Page 4 of 4
很抱歉,暂时无法提供与“1035-85ML”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+361.764141+47.01843
- 12+272.0698712+35.36088
- 30+246.5403530+32.04281
- 54+231.9162354+30.14212
- 102+217.47326102+28.26497
- 252+216.58307252+28.14927
- 国内价格 香港价格
- 6+286.862776+37.28351
- 12+251.2170412+32.65064
- 30+233.0949930+30.29532
- 54+219.3536554+28.50936
