LINK-VS
LINK-VS
    VOX
    LINK-VS
LINK-VS 数据手册
Parallel link | Series link VCCM Series Accessories _______________________________________________________________________________________________ PARALLEL LINKS – Use same link for both positive and negative connections Specification LINK-VP4 M4 Screws – Tighten to 0.55NM Copper – Tin Plated LINK-VP3 LINK-VP2 SERIES LINK Specification LINK-VS M4 Screws – Tighten to 0.55NM Copper – Tin Plated Notes: Refer to the User Manual and datasheets for information on how to connect modules in parallel or in series. All specifications are believed to be correct at time of publishing. Vox Power Ltd reserves the right to make changes to any of its products and to change or improve any part of the specification, electrical or mechanical design or manufacturing process without notice. Vox Power Ltd does not assume any liability arising out of the use or application of any of its products and of any information to the maximum extent permitted by law. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any products of Vox Power Ltd. VOX POWER LTD DISCLAIMS ALL WARRANTIES AND REPRESENTATIONS OF ANY KIND WHETHER EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF SUITABILITY, FITNESS FOR PURPOSE, MERCHANTABILITY AND NONINFRINGEMENT. Please consult your local distributor or Vox Power directly to ensure that you have the latest revision before using the product and refer to the latest relevant user manual for further information relating to the use of the product. Vox Power Ltd products are not intended for use in connection with life support systems, human implantations, nuclear facilities or systems, aircraft, spacecraft, military or naval missile, ground support or control equipment used for the purpose of guidance navigation or direction of any aircraft, spacecraft or military or naval missile or any other application where product failure could lead to loss of life or catastrophic property damage. The user will hold Vox Power Ltd harmless from any loss, cost or damage resulting from its breach of these provisions. DOC-ACS-004-02, VCCM600 Parallel and Series link Vox Power Limited | Unit 2, Red Cow Interchange Estate, Ballymount, Dublin 22, D22 Y8H2, Ireland | T +353 1 4591161 | www.vox-power.com
LINK-VS 价格&库存
很抱歉,暂时无法提供与“LINK-VS”相匹配的价格&库存,您可以联系我们找货
