1N4007FLTR
1N4007FLTR
    SMCDIODESOLUTIONS(桑德斯)
    1N4007FLTR
1N4007FLTR 数据手册
1N4001FL THRU 1N4007FL Technical Data Data Sheet N1646, Rev. A 1N4001FL THRU 1N4007FL General Purpose Plastic Rectifier Features Low forward voltage drop Low leakage current High forward surge capability Solder dip 260 °C, 40 s Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC This is a Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         SOD-123FL Circuit Diagram Mechanical Data      Case: SOD-123FL molded plastic Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0007 ounce, 0.02 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol Marking code 1N 1N 1N 1N 1N 1N 1N Units 4001FL 4002FL 4003FL 4004FL 4005FL 4006FL 4007FL A1 A2 A3 A4 A5 A6 A7 Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum average forward rectified current @TA = 75°C Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) I(AV) 1.0 A IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF 1.1 V Maximum DC reverse current @TA = 25°C at rated DC blocking voltage @TA = 100°C IR 5.0 50.0 µA Typical Junction Capacitance (Note 1) CJ 15.0 pF RθJA 75.0 °C/W TJ,TSTG -65 to +150 °C Typical Thermal Resistance (Note 2) Operating and Storage Temperature Range Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375" (9.5mm)lead length,P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4001FL THRU 1N4007FL Technical Data Data Sheet N1646, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1N4001FL THRU 1N4007FL Technical Data Data Sheet N1646, Rev. A Mechanical Dimensions SOD-123FL(Inches/Millimeters) Ordering Information Device 1N4001FL THRU 1N4007FL Marking Diagram Package Shipping SOD-123FL 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. A1 = Marking Code Carrier Tape Specification SOD-123FL SYMBOL A B C d E F P P0 P1 W Millimeters Min. Max. 7.90 8.30 1.95 3.85 1.35 1.50 1.65 3.40 3.90 3.90 1.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  2.15 4.05 1.55 1.60 1.85 3.60 4.10 4.10 2.10 1N4001FL THRU 1N4007FL Technical Data Data Sheet N1646, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
1N4007FLTR 价格&库存
很抱歉,暂时无法提供与“1N4007FLTR”相匹配的价格&库存,您可以联系我们找货
1N4007FLTR
  • 1+1.52087
  • 5+1.18290
  • 25+0.81113
  • 100+0.49682
  • 500+0.31093
  • 985+0.11998
  • 2709+0.11322
1N4007FLTR
    • 3000+0.075413000+0.00944
    • 12000+0.0727512000+0.00911
    • 30000+0.0709830000+0.00888
    • 75000+0.0692075000+0.00866
    • 120000+0.06654120000+0.00833
    1N4007FLTR
    • 1+1.752081+0.21922
    • 5+1.336645+0.16724
    • 25+0.9121725+0.11413
    • 100+0.55904100+0.06995
    • 500+0.34952500+0.04374
    • 3000+0.205923000+0.02577
    • 9000+0.153549000+0.01921
    • 45000+0.1345745000+0.01684
    • 90000+0.1273590000+0.01594
    库存:8907
    1N4007FLTR
      • 3000+0.098483000+0.01233
      • 9000+0.095829000+0.01199
      • 30000+0.0931530000+0.01166
      • 60000+0.0913860000+0.01144
      • 120000+0.08694120000+0.01088
      库存:255000
      1N4007FLTR
        • 3000+0.100253000+0.01255
        • 12000+0.0967012000+0.01210
        • 45000+0.0931545000+0.01166
        • 90000+0.0913890000+0.01144
        • 225000+0.08694225000+0.01088
