MA9909.A.002
MA9909.A.002
    TAOGLASLIMITED
    MA9909.A.002
MA9909.A.002 数据手册
GuardianX 9 in 1 Antenna Part No: MA9909.A.002 Description: 1*Active GNSS with RG-174 & SMA(M) 8*Cellular MIMO with TGC-200 & SMA(M) Features: Low-profile Adhesive Mount Multi-antenna 1* GPS-GLONASS Antenna 8* Cellular MIMO Worldwide 4G Bands Covers 5G Band 71 IP67 Rated Waterproof Enclosure Cables: 1M Low Loss TGC-200 and RG-174 Connectors: SMA(M) Dimensions: 360 * 160 * 16.5mm RoHS & REACH Compliant SPE-19-8-131-A 1. Introduction 3 2. Specifications 4 3. Active Antenna Characteristics 9 4. Antenna Characteristics 15 5. Radiation Patterns 20 6. Mechanical Drawing 69 7. Packaging 70 Changelog 71 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-19-8-131-A www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas GuardianX MA9909 is a low profile heavy duty, fully IP67 rated waterproof, adhesive external combination antenna. It combines 9 antenna elements into one enclosure, 1 GPS/GLONASS/Galileo, 8* Cellular MIMO (698 to 960MHz/1710 to 2170MHz/ 2490 to 2690MHz/ 3300 to 3600MHz). The Taoglas GuardianX has been designed as a low profile solution for several IoT and Automotive applications where space is at a premium. Introduction This unique product delivers powerful worldwide 4G LTE MIMO antenna technology at 700MHz/800MHz/1700MHz/1800MHz/2600MHz and GNSS. This is an ideal external combination antenna solution that is used where drilling a hole through the roof of a vehicle or a metal panel for an external antenna is not feasible. The GuardianX can operate at band 71 a newly established 5G band at 600MHz. Introduction Typical applications include: Passenger Bus / Rail / Air Applications. Automotive and Heavy Equipment Vehicle Tracking and Telematics Remote Asset and Pipeline Monitoring HD Video over LTE First Responder and Emergency Services M2M Applications/IoT Introduction 5G/4G applications demand high speed data uplink and downlink. High efficiency and high gain MIMO antennas are necessary to achieve the required signal to noise ratio and throughput required to solve these challenges. Taoglas also takes care to have high isolation between the two MIMO antennas to prevent selfinterference. Low loss cables are used to keep efficiency high over long cable lengths. In contrast, smaller MIMO antennas with poorer quality thinner cables will have much reduced efficiency and isolation, which would lead to a large drop in system throughput, increased number of drops, and may indeed not make a system connection at all. Cable length and connector types are customizable. Contact your regional Taoglas customer support team for more information. SPE-19-8-131-A www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered AntennaL1 Characteristics2. Specifications L2 L5 L6 GPS/QZSS 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz ■ □ □ □ L5R L3PT L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz □ □ □ ■ ■ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz L1 1575.42MHz □ □ ■ 3. GLONASS Antenna Characteristics 1176.45MHz 1201.5MHz Galileo 4. Antenna□ Radiation Patterns3. Antenna □ □ □ B1 Characteristics2. BeiDou 1561MHz 3. Compass □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz □ □ Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz □ Antenna Characteristics2. SBAS 3. B3 Specifications 1268.52MHz B2 1207.14MHz Specifications ■ Antenna□ Characteristics GNSS Electrical 4. Frequency (MHz) 1575.42 1602 Antenna Radiation Patterns3.Antenna VSWR (max.) 2.0:1 Characteristics Peak Gain at Zenith (dBic) Axial Ratio (dB) 2.0:1 1.5 0 6 14 Polarization RHCP 4. Antenna Radiation Patterns Impedance 4. Antenna Radiation Patterns3.Antenna 50Ω Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-19-8-131-A Specifications www.taoglas.com 4 LNA and Filter Electrical Properties Frequency (MHz) 1575.42 1602 VSWR (max.) 2.0:1 2.0:1 Gain@1.8V (dBic) 25 25 Gain@3.0V (dBic) 31 31 Gain@5.5V (dBic) 34 34 Noise@1.8V (dB) 3 3 Noise@3.0V (dB) 3 3 Noise@5.5V (dB) 3.3 3.3 Power consumption@1.8V (mA) 5 Power consumption@3.0V (mA) 10 Power consumption@5.5V (mA) 23 Total Specification (Through Antenna, SAW Filter and LNA) Frequency (MHz) 1575.42 1602 Gain@3V (dBic) 31 ± 3 30 ± 3 Output Impedance SPE-19-8-131-A 50 Ω www.taoglas.com 5 5G/4G Antenna Frequency (MHz) 5G NR Band 71 LTE700 617 ~698 698 ~824 GSM 5G NR Band 850/900 74, 75, 76 824 ~960 1427 ~1518 UMTS1 LTE2600 5G NR Band LTE5200/ 77, 78, 79 Wi-Fi 5800 DCS PCS 1710 ~1880 1850 ~1990 1920 ~2170 2300 ~2690 3300 ~3500 5150 ~5925 Efficiency (%) MIMO 1 1m 35.41 42.11 44.33 18.89 52.83 48.11 47.82 43.25 10.60 16.05 MIMO 2 1m 13.76 30.02 24.81 25.80 54.18 59.28 59.20 34.24 20.71 9.52 MIMO 3 1m 36.90 42.56 42.53 27.82 57.08 54.93 53.95 32.99 17.13 12.53 MIMO 4 1m 27.71 32.84 29.33 41.72 43.61 36.50 34.63 40.21 13.29 9.87 MIMO 5 1m 30.28 31.92 30.10 43.43 48.18 40.97 38.80 42.42 14.18 9.94 MIMO 6 1m 35.45 43.01 45.05 29.32 60.41 59.52 58.29 38.87 16.88 11.95 MIMO 7 1m 13.41 30.93 27.21 25.04 57.83 61.70 62.69 36.90 21.87 9.96 MIMO 8 1m 41.17 44.90 49.33 20.44 53.31 52.45 51.09 44.85 10.88 15.73 Average Gain (dB) MIMO 1 1m -4.54 -3.76 -3.55 -7.25 -2.77 -3.18 -3.21 -3.66 -9.76 -8.12 MIMO 2 1m -9.02 -5.30 -6.06 -5.91 -2.67 -2.28 -2.29 -4.67 -6.84 -10.24 MIMO 3 1m -4.35 -3.72 -3.72 -5.66 -2.44 -2.60 -2.69 -4.84 -7.68 -9.09 MIMO 4 1m -5.61 -4.84 -5.37 -3.80 -3.61 -4.39 -4.62 -3.96 -8.78 -10.15 MIMO 5 1m -5.23 -4.96 -5.26 -3.63 -3.18 -3.89 -4.13 -3.73 -8.50 -10.07 MIMO 6 1m -4.53 -3.67 -3.47 -5.43 -2.20 -2.26 -2.35 -4.14 -7.76 -9.30 MIMO 7 1m -9.07 -5.14 -5.66 -6.05 -2.40 -2.11 -2.03 -4.35 -6.63 -10.07 MIMO 8 1m -3.88 -3.49 -3.07 -6.90 -2.73 -2.81 -2.93 -3.52 -9.67 -8.19 Peak Gain (dBi) MIMO 1 1m -0.30 0.42 1.35 -3.07 2.56 1.99 1.46 1.26 -5.72 -1.93 MIMO 2 1m -4.26 -1.30 -2.64 -0.30 1.04 1.29 2.33 0.59 -2.54 -4.93 MIMO 3 1m -0.41 0.59 -0.15 -0.77 2.62 2.74 2.68 -0.55 -2.67 -3.38 MIMO 4 1m 0.04 0.52 -0.34 0.73 1.20 1.22 1.30 1.04 -2.90 -5.29 MIMO 5 1m 0.22 0.84 0.05 0.34 1.80 2.32 1.95 2.07 -2.48 -4.94 MIMO 6 1m -0.83 0.62 0.13 -1.13 2.64 3.00 3.13 0.41 -3.08 -4.01 MIMO 7 1m -4.11 -0.57 -2.04 -0.53 1.20 1.53 2.50 0.35 -2.66 -4.73 MIMO 8 1m 0.70 1.42 1.99 -2.78 2.49 2.19 1.55 1.24 -5.64 -1.87 Impedance 50 Ω Polarization Linear Radiation Pattern Omni Max. input power 2W SPE-19-8-131-A www.taoglas.com 6 Mechanical Dimension 360 * 160 * 16.5mm Casing PC Cable 1M TGC200 for Cellular – Fully Customizable 1M RG174 for GNSS – Fully Customizable Connector Cellular 5G/4G: SMA-Plug – Fully Customizable GNSS: SMA-Plug – Fully Customizable Sealant Rubber Stopper Weight Including Cables 1060g Environmental Protection IP67 Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH Cable Pull RG174 4KgF/ TGC200 9KgF SPE-19-8-131-A www.taoglas.com 7 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 – 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 3550 to 3700 48 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 4400 to 5000 79 *Covered bands represented as 20% efficiency, tested at 1m cable. SPE-19-8-131-A 1 2 3 4 5 6 7 8 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓    ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓    ✓ ✓    ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓    ✓ ✓ ✓    ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓    ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓    ✓ ✓    ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓    ✓ ✓ ✓   ✓ www.taoglas.com 8 3. 4. Active Antenna Characteristics 3.1 Block Diagram (Active antenna) Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Passive Antenna Return Loss 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-19-8-131-A www.taoglas.com 9 3.3 Passive Antenna Efficiency 3.4 Passive Antenna Average Gain SPE-19-8-131-A www.taoglas.com 10 3.5 Passive Antenna Peak Gain 3.6 Passive Antenna Axial Ratio (Zenith is at 0° ) SPE-19-8-131-A www.taoglas.com 11 3.7 Active measurements LNA Gain @ 3.0V Noise Figure @ 3.0V SPE-19-8-131-A www.taoglas.com 12 3.8 GNSS Radiation Pattern 1575.42MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 13 1602MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 14 4. 4. Antenna Characteristics 4.1 Return Loss Antenna Radiation Patterns3.Antenna Cellular MIMO Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-19-8-131-A www.taoglas.com 15 4.2 Isolation Cellular 1 Cellular 2 SPE-19-8-131-A www.taoglas.com 16 Cellular 3 and Cellular 4 Cellular 5、Cellular 6 and Cellular 7 SPE-19-8-131-A www.taoglas.com 17 4.3 Efficiency Cellular MIMO 4.4 Average Gain Cellular MIMO SPE-19-8-131-A www.taoglas.com 18 4.5 Peak Gain Cellular MIMO SPE-19-8-131-A www.taoglas.com 19 5. Radiation Patterns 4. 4. 5.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y 4. Antenna Radiation X Patterns Z 4. Antenna Radiation Patterns Free space 4. Antenna Radiation Patterns SPE-19-8-131-A www.taoglas.com 20 5.2 Cellular MIMO1 Radiation Pattern 751MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 21 880MHz XY Plane XZ Plane X Z Z Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 22 1805MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 23 1920MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 24 1990MHz XY Plane X Y SPE-19-8-131-A XZ Plane YZ Plane Z Z X Y www.taoglas.com 25 2500MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 26 5.3 Cellular MIMO2 Radiation Pattern 751MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 27 880MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 28 1805MHz XY Plane XZ Plane X Z Z Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 29 1920MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 30 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 31 2500MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 32 5.4 Cellular MIMO3 Radiation Pattern 751MHz XY Plane X Y SPE-19-8-131-A XZ Plane YZ Plane Z Z X Y www.taoglas.com 33 880MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 34 1805MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 35 1920MHz XY Plane X Y SPE-19-8-131-A XZ Plane YZ Plane Z Z X Y www.taoglas.com 36 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 37 2500MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 38 5.5 Cellular MIMO4 Radiation Pattern 751MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 39 880MHz XY Plane XZ Plane YZ Plane X Z Z Y SPE-19-8-131-A X Y www.taoglas.com 40 1805MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 41 1920MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 42 1990MHz XY Plane X Y SPE-19-8-131-A XZ Plane YZ Plane Z Z X Y www.taoglas.com 43 2500MHz XY Plane XZ Plane X Z Z Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 44 5.6 Cellular MIMO5 Radiation Pattern 751MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 45 880MHz XY Plane XZ Plane Z X Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 46 1805MHz XY Plane XZ Plane YZ Plane X Z Z Y SPE-19-8-131-A X Y www.taoglas.com 47 1920MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 48 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 49 2500MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 50 5.7 Cellular MIMO6 Radiation Pattern 751MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 51 880MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 52 1805MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 53 1920MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 54 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 55 2500MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 56 5.8 Cellular MIMO7 Radiation Pattern 751MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 57 880MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 58 1805MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 59 1920MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 60 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 61 2500MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 62 5.9 Cellular MIMO8 Radiation Pattern 751MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 63 880MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 64 1805MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 65 1920MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 66 1990MHz XY Plane XZ Plane X Z Y SPE-19-8-131-A YZ Plane Z X Y www.taoglas.com 67 2500MHz XY Plane XZ Plane Z Z X Y SPE-19-8-131-A YZ Plane X Y www.taoglas.com 68 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-131-A Mechanical Drawing www.taoglas.com 69 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-19-8-131-A Mechanical Drawing www.taoglas.com 70 Changelog for the datasheet SPE-19-8-131 – MA9909.A.002 Revision: A (Original First Release) Date: Notes: 2019-10-08 Author: Jack Conroy Previous Revisions SPE-19-8-131-A www.taoglas.com 71 www.taoglas.com ©Taoglas SPE-19-8-131-A www.taoglas.com 72
MA9909.A.002 价格&库存
很抱歉,暂时无法提供与“MA9909.A.002”相匹配的价格&库存,您可以联系我们找货
MA9909.A.002
    • 1+1977.54480
    • 200+1857.30840
    • 500+1795.25160
    • 1000+1764.57960
    MA9909.A.002
    • 50+1980.42154
    库存:40
