PGSMAJ36A M2G
PGSMAJ36A M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    PGSMAJ36A M2G
PGSMAJ36A M2G 数据手册
PGSMAJ10A - PGSMAJ100A Taiwan Semiconductor 400W, 10V - 100V Surface Mount Transient Voltage Suppressor FEATURES KEY PARAMETERS AEC-Q101 qualified Low profile package Photo Glass passivated junction Excellent clamping capability Moisture sensitivity level: level 1, per J-STD-020 400 watts peak pulse power capability with a 10 / 1000 μs waveform (300W above 78V) ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA UNIT VWM 10 - 100 V VBR 11.7 - 117 V TJ MAX 175 °C Package DO-214AC (SMA) Configuration Single die Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.06 g (approximately) DO-214AC (SMA) eco ● ● ● ● ● ● VALUE mm ● ● ● ● PARAMETER en de d ● ● ● ● ● ● No tR ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Peak power dissipation (Note 1) Steady state power dissipation Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage at 25 A for unidirectional only Operating junction temperature range Storage temperature range SYMBOL VALUE UNIT PPPM 400 W PD 1 W IFSM 40 A VF 3.5 V TJ -55 to +175 °C TSTG -55 to +175 °C Notes: 1. Non-repetitive Current Pulse Per Fig.3 and derated above TA=25°C Per Fig.2. Rating is 300 W for VWM > 78 V Devices for Bi-directional Applications 1. For Bi-directional use CA suffix (e.g. PGSMAJ10CA). 2. Electrical Characteristics Apply in Both Directions 1 Version:B1805 PGSMAJ10A - PGSMAJ100A Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-lead thermal resistance per diode Junction-to-ambient thermal resistance per diode Junction-to-case thermal resistance per diode SYMBOL TYP. UNIT RӨJL RӨJA RӨJC 29 120 31 °C/W °C/W °C/W Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) 10 11 12 13 14 15 16 17 18 20 22 24 26 28 30 33 36 40 43 45 48 51 54 58 60 64 70 75 78 85 90 100 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 No 23.5 22.0 20.1 18.6 17.2 16.4 15.4 14.5 13.7 12.3 11.3 10.3 9.5 8.8 8.3 7.5 6.9 6.2 5.8 5.5 5.2 4.9 4.6 4.3 4.1 3.9 3.5 3.3 3.2 2.2 2.1 1.9 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103 113 121 126 137 146 162 d 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Maximum clamping voltage VC@IPPM (V) tp =10/1000 μs de Max. 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 24.50 26.90 29.50 31.90 34.40 36.8 40.6 44.2 49.1 52.8 55.3 58.9 62.7 66.3 71.2 73.7 78.6 86 92.1 95.8 104 111 123 Maximum peak impulse current IPPM (A) tp =10/1000 μs en Min. 11.1 12.2 13.3 14.4 15.6 16.7 17.8 18.9 20.0 22.2 24.4 26.7 28.9 31.1 33.3 36.7 40.0 44.4 47.8 50.0 53.3 56.7 60.0 64.4 66.7 71.1 77.8 83.3 86.7 94.4 100 111 Maximum reverse leakage current IR@VWM (µA) (Note 1) mm PAX PAZ PBE PBG PBK PBM PBP PBR PBT PBV PBX PBZ PCE PCG PCK PCM PCP PCR PCT PCV PCX PCZ PRE PRG PRK PRM PRP PRR PRT PRV PRX PRZ Working stand-off voltage VWM (V) e co PGSMAJ10A PGSMAJ11A PGSMAJ12A PGSMAJ13A PGSMAJ14A PGSMAJ15A PGSMAJ16A PGSMAJ17A PGSMAJ18A PGSMAJ20A PGSMAJ22A PGSMAJ24A PGSMAJ26A PGSMAJ28A PGSMAJ30A PGSMAJ33A PGSMAJ36A PGSMAJ40A PGSMAJ43A PGSMAJ45A PGSMAJ48A PGSMAJ51A PGSMAJ54A PGSMAJ58A PGSMAJ60A PGSMAJ64A PGSMAJ70A PGSMAJ75A PGSMAJ78A PGSMAJ85A PGSMAJ90A PGSMAJ100A Test current IT (mA) tR Part number Marking code Breakdown voltage VBR@IT (V) (Note 1) Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA=25°C per Fig. 2 2. Mounted on 5 x 5mm copper pads to each terminal 3. Lead temperature at TL=75°C 4. Measure on 8.3ms single half sine-wave duty cycle=4 pulses per minutes maximum 5. Peak pulse power waveform is 10/1000 μs 2 Version:B1805 PGSMAJ10A - PGSMAJ100A Taiwan Semiconductor PACKING PGSMAJxxxAHE3G Clip SMA 1,800 / 7” Plastic reel PGSMAJxxxAHE2G Clip SMA 7,500 / 13” Plastic reel PGSMAJxxxA E3G Clip SMA 1,800 / 7” Plastic reel PGSMAJxxxA E2G Clip SMA 7,500 / 13” Plastic reel PGSMAJxxxCAHE3G Clip SMA 1,800 / 7” Plastic reel PGSMAJxxxCAHE2G Clip SMA 7,500 / 13” Plastic reel PGSMAJxxxCA E3G Clip SMA 1,800 / 7” Plastic reel PGSMAJxxxCA E2G Clip SMA 7,500 / 13” Plastic reel PGSMAJxxxA R3G SMA 1,800 / 7” Plastic reel PGSMAJxxxAHR3G SMA 1,800 / 7” Plastic reel PGSMAJxxxA M2G SMA 7,500 / 13” Plastic reel PGSMAJxxxAHM2G SMA de PACKAGE mm en ORDERING CODE (Note 1) d ORDERING INFORMATION 7,500 / 13” Plastic reel No tR e co Note 1: "xxx" defines voltage from 10V (PGSMAJ10A) to 100V (PGSMAJ100A) 3 Version:B1805 PGSMAJ10A - PGSMAJ100A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Pulse Derating Curve PEAK PULSE POWER (PPPM) OR CURRENT(IPP) DERATING IN PERCENTAGE (%) Fig.1 Peak Pulse Power Rating Curve 100 PGSMAJ10A - PGSMAJ78A 1 PGSMAJ85A - PGSMAJ100A 0.1 1 10 100 1000 td - PULSE WIDTH (μs) 50 25 10000 0 0 25 50 75 100 125 150 175 mm 0 75 d 10 de Non-Repetitive Pulse Waveform Shown in Fig.3 TA=25°C en PPPM, PEAK PULSE POWER (KW) 100 TJ - INITIAL JUNCTION TEMPERATURE (°C) Fig.3 Clamping Power Pulse Waveform Fig.4 Typical Junction Capacitance 100 tR Rise time tr=10μs to 100% 80 Half value-IPPM/2 10/1000μs, waveform as defined by R.E.A. 60 40 No PEAK PULSE CURRENT (%) 120 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM CAPACITANCE (pF) Peak value IPPM e co 1000 140 20 PGSMAJ10A 100 PGSMAJ40A 10 td f=1.0MHz Vsig=50mVp-p 1 0 0 0.5 1 1.5 2 2.5 1 3 10 100 REVERSE VOLTAGE (V) t, TIME (ms) 4 Version:B1805 PGSMAJ10A - PGSMAJ100A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) DIM Unit (mm) Unit (inch) Max Min Max A 1.27 1.58 0.050 0.062 B 4.06 4.60 0.160 0.181 C 2.29 2.83 0.090 0.111 de D d Min 1.99 2.50 0.078 0.098 0.90 1.41 0.035 0.056 4.95 5.33 0.195 0.210 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 E e co mm en F Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.52 0.060 C 3.93 0.155 D 2.41 0.095 E 5.45 0.215 No tR SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N G YW F 5 = Marking Code = Green Compound = Date Code = Factory Code Version:B1805 PGSMAJ10A - PGSMAJ100A No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:B1805
PGSMAJ36A M2G 价格&库存
很抱歉,暂时无法提供与“PGSMAJ36A M2G”相匹配的价格&库存,您可以联系我们找货
PGSMAJ36A M2G
