GEMMA Talking Toy Guts Sound Pack
PRODUCT ID: 1759
Description
Mod your stuffed toy to chirp, meow, or woof! This GEMMA parts pack makes it easy to add simple
sounds to any plush toy, and especially the Sew-Your-Own Owl Kit (not included!) A tilt ball switch is
used to trigger GEMMA to play a sound of your choosing (or write your own) through a small speaker,
amplified by a transistor.
This product includes:
o
o
o
o
o
o
o
o
o
1x Adafruit Gemma V2
1x 3.7v 150mAh LiPoly Battery
1x Tilt Ball Switch
1x Adafruit Micro Lipo - USB LiIon/LiPoly charger - v1
1x PN2222 Transistor (for more information on the PN2222, check out our 10-pack)
1x Small Speaker
1x 220-ohm Resistor
24" length of solid-core wire
Three pieces of different sized heat shrink (1/4", 1/8", and 1/16" in diameter)
This kit does not come with the plushie owl! We have a seperate kit just for that item, see below or
use a stuffed toy you have around the house! You'll also need a MicroB USB cable, which you also
likely have, or you can pick one up here. Some soldering is required, but its a fun weekend project and a
good way to learn about basic electronic assembly. Check out the Tutorial to learn how!
Technical Details
Learn how to use this product with the Plush Owl Toy!
Engineered in NYC Adafruit ®
