MK232-100K-1%
MK232-100K-1%
    CADDOCK
    插件,P=5.08mm
    厚膜电阻 100KΩ ±1% 750MW
MK232-100K-1% 数据手册
Type MK Precision Power Film Radial-Lead Resistors Page 1 of 2 RoHS Compliant -- MK200 Series and MK700 Series Resistors Non-Inductive with Expanded Resistance Range — 1 ohm to 100 Megohms Type MK Precision Power Film Radial-Lead Resistors provide high density packaging in circuit board applications. These resistors are available in two compact rectangular package configurations with standard lead spacings. Type MK Precision Power Radial-Lead Film Resistors cover the entire resistance range from 1 ohm to 100 Megohms, with a standard tolerance of 1%. Constructed with Caddock's Micronox® resistance films fired onto a solid ceramic substrate, Type MK Precision Film Resistors combine all of these outstanding advantages: • ±1% Resistance Tolerance is Standard - tolerances to ±0.1% are available on special order. • Operating Temperature - from -40°C to +150°C. • Power Ratings at +85°C and at +125°C. • Temperature Coefficient is ≤ 50 ppm/°C from 5 ohms to 5 Megohms and ≤ 80 ppm/°C up to 100 Megohms - referenced to +25°C with the ∆R taken at -15°C and +105°C. • Extended Life Stability is typically better than 0.1% per 1,000 Hours. • Caddock's Non-Inductive Performance - provides faster settling times and minimum distortion in all types of higher frequency circuits. This combination of performance features in a compact radial-lead resistor package can simplify engineering, inventory, and production: Selecting one compact radiallead resistor package can simplify board layouts. With the exceptionally wide range of resistance values that are available in each model of Type MK Precision Power Film Radial-Lead Resistors, circuits can now be designed for greater packaging densities without the need for leaving extra space where resistor value changes can require larger resistors or non-uniform lead spacings. Recommended use: The Type MK resistors that are shown on this data sheet are recommended by Caddock for use in commercial and industrial applications. These RoHS resistors have pure matte tin (Sn) lead finish optimized for use in commercial and industrial applications. Presently, most military applications either prohibit the use of a matte tin lead finish or are trending toward this prohibition. Therefore, Caddock does not recommend and does not support the Type MK Resistors that are shown on this data sheet for use in military applications. Any use of this product in a military program, against this recommended limitation of use, must be completely supported by the customer program design activity and component engineering activity based on the complete evaluation and testing by these activities, there will be no support provided by Caddock for the military use. In this case, a military customer drawing must clearly specify the lead material, lead finish, and the military customer’s responsibility for use. Using one compact radial-lead resistor package can speed assembly procedures, simplify procurement, and simplify inventory. By reducing the wide variety of sizes and types of axial-lead resistors to a single compact radial-lead resistor package with advanced performance ratings, procurement and inventory can be simplified. The radial leads do not require additional bending prior to insertion, and the standard lead spacing can reduce the time required for assembly. For specific price and delivery information, (Resistors shown full size) contact our Sales Office. Standard Part Number Includes: Standard resistance value (listed below), standard tolerance of 1%. MK227 1.00 Ω 2.00 Ω 4.00 Ω 5.00 Ω 10.0 Ω 20.0 Ω 40.0 Ω 50.0 Ω 100 Ω 200 Ω 400 Ω 500 Ω 1.00 K 2.00 K 4.00 K 5.00 K 10.0 K 20.0 K 40.0 K 50.0 K 100 K 200 K 400 K 500 K 1.00 Meg 2.00 Meg MK727 4.00 5.00 10.0 20.0 40.0 Meg Meg Meg Meg Meg MK232 1.00 Ω 2.00 Ω 4.00 Ω 5.00 Ω 10.0 Ω 20.0 Ω 40.0 Ω 50.0 Ω 100 Ω 200 Ω 400 Ω 500 Ω 1.00 K 2.00 4.00 5.00 10.0 20.0 40.0 50.0 100 200 400 500 1.00 2.00 4.00 5.00 K K K K K K K K K K K Meg Meg Meg Meg MK732 10.0 20.0 40.0 50.0 100 Meg Meg Meg Meg Meg Non-Standard Part Number Includes: Non-standard resistance value and/or non-standard tolerance. Available in a minimum order quantity of 25 pcs. Ordering Information: Model Number Resistor Value MK232 - 500K - 1% Tolerance Type MK Precision Power Film Radial-Lead Resistors Page 2 of 2 Type MK Precision Film Resistors - Low and Standard Resistance Ranges Model No. Resistance Dimensions Dieletric Strength Low Min. Standard Min. Standard Max. MK227 1Ω 5Ω 2 Meg 0.07% Fig 1 300 MK232 1Ω 5Ω 5 Meg 0.07% Fig 2 400 Resistance Tolerance: ±1% is standard. (Tolerances to ±0.1% available on values of 30 ohms or higher). +85°C Maximum Ratings Max. 1000 hr Max. 1000 hr Wattage Working Load Stablity Wattage Working Load Stablity Voltage ∆R less than Voltage ∆R less than ±(0.20% ±(0.40% 200 0.20 200 0.50 + 0.01 ohm) + 0.01 ohm) ±(0.20% ±(0.40% 400 0.30 400 0.75 + 0.01 ohm) + 0.01 ohm) Temperature Coefficient: Overload/Overvoltage: 5 times rated power with applied voltage not to exceed 1.5 times maximum working voltage for 5 seconds, ∆R ±(0.15 percent + 0.01 ohm) max. Resistance Range Temp. Coef. Standard : 5 Ω and above 50 ppm/°C Low : 1 Ω to 4.99 Ω 200 ppm/°C Temperature Coefficient referenced to +25°C, ∆R taken at -15°C and +105°C. Insulation Resistance: 10,000 Megohms, minimum. Operating Temperature: -40°C to +150°C. +125°C Maximum Ratings (see Derating Curve) Load Stability: %∆R is shown in the table for 1,000 hours at rated voltage not to exceed rated power. Thermal Shock: MIL-STD-202, Method 107, Cond. B, except low temperature is -40°C, ∆R ±(0.20 percent + 0.01 ohm) max. Moisture Resistance: MIL-STD-202, Method 106, ∆R ±(0.50 percent + 0.01 ohm) max. Solderable Leads: Matte Tin Plated Copper. Measurement Note: Resistance measurement on low resistance values shall be made at a point within 0.2 inch (5.08 mm) of the body. Type MK Precision Film Resistors - Extended Resistance Range TC ppm/°C MK727 MK732 Resistance Min. Max. 80 2.01 Meg 40.0 Meg 0.07% Fig 1 300 80 5.01 Meg 100 Meg Fig 2 0.07% 400 Resistance Tolerance: ±1% (consult factory for tighter tolerances). Overload/Overvoltage: 1.5 times maximum working voltage for 5 seconds, ∆R 0.50% max. Operating Temperature: -40°C to +150°C. Fig 1 Dieletric Dimensions Strength Model MK227 and MK727 .095 ±.005 (2.41 ±.13) .245 ±.010 (6.22 ±.26) .245 ±.010 (6.22 ±.26) .150 ±.015 (3.81 ±.38) .025 ±.002 (.64 ±.05) DIA., LEADWIRE OFFSET .012 (.31) FROM CENTERLINE Max. 1000 hr Max. 1000 hr Wattage Working Load Stability Wattage Working Load Stability Voltage ∆R less than Voltage ∆R less than Limited by Max. Working Voltage 200 0.20% 400 0.20% Limited by Max. Working Voltage 200 0.50% 400 0.50% Temperature Coefficient: See Table for TC value. TC referenced to +25°C, ∆R taken at -15°C and +105°C. Thermal Shock: MIL-STD-202, Method 107, Cond. B, except low temperature is -40°C, ∆R 0.50% max. Load Stability: %∆R is shown in the table for 1,000 hours at rated voltage. Solderable Leads: Matte Tin Plated Copper. Insulation Resistance: 10,000 Megohms, minimum. Fig 2 Model MK232 and MK732 .095 ±.005 (2.41 ±.13) .290 ±.010 (7.37 ±.26) MK227 10.0 1% .250 ±.050 (6.35 ±1.27) +125°C Maximum Ratings (see Derating Curve) +85°C Maximum Ratings .250 ±.050 (6.35 ±1.27) .200 ±.015 (5.08 ±.38) MK732 100 MEG 1% .290 ±.010 (7.37 ±.26) .025 ±.002 (.64 ±.05) DIA., LEADWIRE OFFSET .012 (.31) FROM CENTERLINE Moisture Resistance: MIL-STD-202, Method 106, ∆R 0.50% max. Derating Curve: 100% @ +85°C 100 % RATED POWER Model No. 80 60 40% @ +125°C 40 20 0 25 85 125 150 AMBIENT TEMPERATURE, °C DIMENSIONS IN INCHES AND (MILLIMETERS) ELECTRONICS, INC. e-mail: caddock@caddock.com • web: www.caddock.com For Caddock Distributors listed by country see caddock.com/contact/dist.html © 2003-2018 Caddock Electronics, Inc. Sales and Applications Engineering 17271 North Umpqua Hwy. Roseburg, Oregon 97470-9422 Phone: (541) 496-0700 Fax: (541) 496-0408 29_IL143.0118
MK232-100K-1% 价格&库存
很抱歉,暂时无法提供与“MK232-100K-1%”相匹配的价格&库存,您可以联系我们找货
