H
Specifications 规格
3.6
Electrical 电气规格
Voltage rating 电压额定值: 20 V DC
Current Rating 电流额定值: 5 Amp
Insulation Resistance 绝缘电阻值: 100 MΩ min.
Dielectric Withstanding 耐电压: 500 V AC
Contact Resistance 接触电阻值: 30 mΩ max.
4.8
1
G
2x1
1
7.4
2
E
Housing
PBT, UL94 V-0
1
2
Cover
PBT, UL94 V-0, Black
1
1
3
Centre Pin
1 Brass, Cu-Sn/Nickel plating
1
+0
-0.05
4
Centre Pin Terminal
1
1
5
Tip Spring
2 Phosphor Bronze, T=0.30mm, Silver plating
1
6
Shunt Terminal
3 Brass, T=0.50mm, Silver plating
1
2
3
5
Mating Plug
(Reference)
Ø5
Ø2
.5
.0
A
K
K1
Circuit Diagram
A = 2 Conductors/3 Contacts
Insulator Colour
K1 = Black (Standard)
W1 = White (0100) B1 = Blue (0037)
G1 = Grey (0292) G2 = Grey (0228)
V1 = Green (0247) V2 = Green (0116)
Y1 = Yellow (0039)
13.7
B
10
DCJ200
2.5±0.1
10.8
4.8
Ordering Grid
4
7.4
2.5±0.1
3±0.1
Q'ty
Material
1
Ø2.00
6.5±0.2
11
C
Component Outline
0.2
.3±
6
Ø
6
Description
No.
(Tolerance:±0.05mm)
3.5
D
Mechanical & Environmental 机械 & 环境
Operating Temperature 工作温度: -20°C to +70°C
Durability 耐久性: 5,000 cycles min.
Recommended PCB Layout
9
3.3±0.2
2x3.2
13.7
14.3
10.8
3
F
5
Request Samples
and Quotation
Packing
K = Bag
(500 per bag)
Circuit Diagram
1
3
2
A
Part Number
Product Description
DCJ200-10
DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs
Ø2.00mm Pin mates with Ø2.05mm Plug
Drawing Date
11th December 2015
By
# Terminal Number
Detail
1
2
3
4
Revision
Date
5
AJO
Drawing
Release
A
11/12/15
Tolerances (Except as Noted)
Length
Angle
± 0.3
± 2°
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/2
H
Part Number
Pcs/Bag
Bags/Carton
Cartons/Box
Pcs/Carton
DCJ200-10
500
4
4
8000
G
1 Carton
=500pcs x 4 Bags
=2000pcs
190
150
220
F
1 PE Bag = 500pcs
2
C
a
E
ns
r to
235
PE Bag
D
330
1 Box
=2000pcs x 4 Cartons
=8000pcs
2 Cartons
C
340
255
B
Part Number
Product Description
DCJ200-10
Drawing Date
A
11th December 2015
By
Detail
1
2
3
4
Revision
Date
5
AJO
Drawing
Release
A
11/12/15
Length
Angle
± 0.3
± 2°
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
2/2
很抱歉,暂时无法提供与“DCJ200-10-A-K1-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.01951
- 10+2.78544
- 30+2.73862
- 国内价格
- 10+5.55282
- 100+4.73414
- 250+4.22394
- 500+4.11716
- 1000+4.01037
- 2500+3.77307
- 国内价格 香港价格
- 1+7.450301+0.96450
- 10+6.5400010+0.84670
- 25+5.9770025+0.77380
- 100+5.39010100+0.69780
- 250+4.92300250+0.63740
- 1000+4.072501000+0.52730
- 2500+3.821002500+0.49470
- 5000+3.641305000+0.47140
- 10000+3.4616010000+0.44820
- 国内价格 香港价格
- 1+6.031511+0.78083
- 10+5.0189810+0.64975
- 25+4.6960225+0.60794
- 50+4.4952650+0.58195
- 100+4.29450100+0.55596
- 250+4.06756250+0.52658
- 500+3.88426500+0.50285
- 1000+3.735871000+0.48364
- 2500+3.552572500+0.45991
- 5000+3.404185000+0.44070
- 国内价格 香港价格
- 122+4.67825122+0.60564
- 250+4.42845250+0.57330
- 500+4.23541500+0.54831
- 1000+4.087801000+0.52920
- 国内价格
- 1+7.27920
- 10+5.95080
- 30+5.22720
- 100+4.40640
