ESP32-WROVER-IB
ESP32-WROVER-IB
    ESPRESSIF(乐鑫)
ESP32-WROVER-IB 数据手册
ESP32­WROVER­B & ESP32­WROVER­IB FO NO T RE R CO NE M W M (N EN D RN ES DE D) IG NS D Datasheet Version 1.8 Espressif Systems Copyright © 2022 www.espressif.com About This Document This document provides the specifications for the ESP32-WROVER-B and ESP32-WROVER-IB modules. Document Updates Please always refer to the latest version on https://www.espressif.com/en/support/download/documents. Revision History For revision history of this document, please refer to the last page. Documentation Change Notification Espressif provides email notifications to keep customers updated on changes to technical documentation. Please subscribe at www.espressif.com/en/subscribe. Note that you need to update your subscription to receive notifications of new products you are not currently subscribed to. Certification Download certificates for Espressif products from www.espressif.com/en/certificates. Not Recommended For New Designs (NRND) Contents 1 Overview 6 2 Pin Definitions 8 2.1 Pin Layout 8 2.2 Pin Description 8 2.3 Strapping Pins 10 3 Functional Description 12 3.1 CPU and Internal Memory 12 3.2 External Flash and SRAM 12 3.3 Crystal Oscillators 12 3.4 RTC and Low-Power Management 13 4 Peripherals and Sensors 14 5 Electrical Characteristics 15 5.1 Absolute Maximum Ratings 15 5.2 Recommended Operating Conditions 15 5.3 DC Characteristics (3.3 V, 25 °C) 15 5.4 Wi-Fi Radio 16 5.5 BLE Radio 17 5.5.1 Receiver 17 5.5.2 Transmitter 17 5.6 Reflow Profile 18 6 Schematics 19 7 Peripheral Schematics 21 8 Physical Dimensions 22 9 Recommended PCB Land Pattern 23 10 Dimensions of External Antenna Connector 24 11 Related Documentation and Resources 25 Revision History 26 Not Recommended For New Designs (NRND) List of Tables 1 Ordering Information 6 2 ESP32-WROVER-B & ESP32-WROVER-IB Specifications 7 3 Pin Definitions 8 4 Strapping Pins 10 5 Absolute Maximum Ratings 15 6 Recommended Operating Conditions 15 7 DC Characteristics (3.3 V, 25 °C) 15 8 Wi-Fi Radio Characteristics 16 9 Receiver Characteristics – Bluetooth LE 17 10 Transmitter Characteristics – Bluetooth LE 17 Not Recommended For New Designs (NRND) List of Figures 1 Pin Layout (Top View) 8 2 Reflow Profile 18 3 Schematics of ESP32-WROVER-B 19 4 Schematics of ESP32-WROVER-IB 20 5 Peripheral Schematics 21 6 Physical Dimensions 22 7 Recommended PCB Land Pattern 23 8 Dimensions of External Antenna Connector 24 Not Recommended For New Designs (NRND) 1 Overview 1 Overview ESP32-WROVER-B and ESP32-WROVER-IB are two powerful, generic WiFi + Bluetooth + Bluetooth LE MCU modules that target a wide variety of applications, ranging from low-power sensor networks to the most demanding tasks, such as voice encoding, music streaming and MP3 decoding. ESP32-WROVER-B comes with a PCB antenna, and ESP32-WROVER-IB with an external antenna connector. They both feature a 4 MB external SPI flash and an additional 8 MB SPI Pseudo static RAM (PSRAM). The information in this datasheet is applicable to both modules. The ordering information of the two modules is listed as follows: Table 1: Ordering Information Module ESP32-WROVER-B ESP32-WROVER-IB Chip embedded Flash PSRAM Module dimensions (mm) ESP32-D0WD 4 MB 1 8 MB 18 × 31.4 × 3.3 Notes: 1. The module with 8 MB flash or 16 MB flash is available for custom order. 2. For detailed ordering information, please see ESP Product Selector. 3. For dimensions of the IPEX connector, please see Chapter 10. At the core of the module is the ESP32-D0WD chip*. The chip embedded is designed to be scalable and adaptive. There are two CPU cores that can be individually controlled, and the CPU clock frequency is adjustable from 80 MHz to 240 MHz. The chip also has a low-power coprocessor that can be used instead of the CPU to save power while performing tasks that do not require much computing power, such as monitoring of peripherals. ESP32 integrates a rich set of peripherals, ranging from capacitive touch sensors, Hall sensors, SD card interface, Ethernet, high-speed SPI, UART, I2S and I2C. Note: * For details on the part numbers of the ESP32 family of chips, please refer to the document ESP32 Datasheet. The integration of Bluetooth® , Bluetooth LE and Wi-Fi ensures that a wide range of applications can be targeted, and that the module is all-around: using Wi-Fi allows a large physical range and direct connection to the Internet through a Wi-Fi router, while using Bluetooth allows the user to conveniently connect to the phone or broadcast low energy beacons for its detection. The sleep current of the ESP32 chip is less than 5 µA, making it suitable for battery powered and wearable electronics applications. The module supports a data rate of up to 150 Mbps, and 20 dBm output power at the antenna to ensure the widest physical range. As such the module does offer industry-leading specifications and the best performance for electronic integration, range, power consumption, and connectivity. The operating system chosen for ESP32 is freeRTOS with LwIP; TLS 1.2 with hardware acceleration is built in as well. Secure (encrypted) over the air (OTA) upgrade is also supported, so that users can upgrade their products even after their release, at minimum cost and effort. Table 2 provides the specifications of ESP32-WROVER-B and ESP32-WROVER-IB. Not Recommended For New Designs (NRND) Espressif Systems 6 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 1 Overview Table 2: ESP32­WROVER­B & ESP32­WROVER­IB Specifications Categories Items Specifications See RF certification Certification Test certificates for ESP32-WROVER-B and ESP32-WROVER-IB Bluetooth certification BQB Green certification RoHS, REACH Reliablity HTOL/HTSL/uHAST/TCT/ESD 802.11 b/g/n (802.11n up to 150 Mbps) Wi-Fi Protocols A-MPDU and A-MSDU aggregation and 0.4 µs guard interval support Center frequency range of operating channel Protocols 2412 ~ 2484 MHz Bluetooth v4.2 BR/EDR and Bluetooth LE specification NZIF receiver with –97 dBm sensitivity Bluetooth Radio Class-1, class-2 and class-3 transmitter AFH Audio CVSD and SBC SD card, UART, SPI, SDIO, I2C, LED PWM, Motor PWM, I2S, IR, pulse counter, GPIO, capacitive touch sen- Module interfaces sor, ADC, DAC, Two-Wire Automotive Interface (TWAI® ), compatible with ISO11898-1 (CAN Specification 2.0) Hardware On-chip sensor Hall sensor Integrated crystal 40 MHz crystal Integrated SPI flash 4 MB Integrated PSRAM 8 MB Operating voltage/Power supply 3.0 V ~ 3.6 V Minimum current delivered by power supply Recommended operating ambient temperature range 500 mA –40 °C ~ 85 °C Package size 18 mm × 31.4 mm × 3.3 mm Moisture sensitivity level (MSL) Level 3 Not Recommended For New Designs (NRND) Espressif Systems 7 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 2 Pin Definitions 2 Pin Definitions 2.1 Pin Layout Keepout Zone 1 GND GND 38 2 3V3 IO23 37 3 EN IO22 36 4 SENSOR_VP TXD0 35 5 SENSOR_VN RXD0 34 6 IO34 IO21 33 7 IO35 NC 32 8 IO32 IO19 31 9 IO33 IO18 30 10 IO25 IO5 29 11 IO26 NC 28 12 IO27 NC 27 13 IO14 IO4 26 14 IO12 IO0 25 15 GND IO2 24 16 IO13 IO15 23 17 SD2 SD1 22 18 SD3 SD0 21 19 CMD CLK 20 Pin 39 GND Figure 1: Pin Layout (Top View) 2.2 Pin Description ESP32-WROVER-B and ESP32-WROVER-IB each has 38 pins. See pin definitions in Table 3. Table 3: Pin Definitions Name No. Type Function GND 1 P Ground 3V3 2 P Power supply EN 3 I Module-enable signal. Active high. Not Recommended For New Designs (NRND) Espressif Systems 8 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 2 Pin Definitions Name No. Type Function SENSOR_VP 4 I GPIO36, ADC1_CH0, RTC_GPIO0 SENSOR_VN 5 I GPIO39, ADC1_CH3, RTC_GPIO3 IO34 6 I GPIO34, ADC1_CH6, RTC_GPIO4 IO35 7 I GPIO35, ADC1_CH7, RTC_GPIO5 IO32 8 I/O IO33 9 I/O IO25 10 I/O GPIO25, DAC_1, ADC2_CH8, RTC_GPIO6, EMAC_RXD0 IO26 11 I/O GPIO26, DAC_2, ADC2_CH9, RTC_GPIO7, EMAC_RXD1 IO27 12 I/O GPIO27, ADC2_CH7, TOUCH7, RTC_GPIO17, EMAC_RX_DV IO14 13 I/O IO12 14 I/O GND 15 P IO13 16 I/O SHD/SD2* 17 I/O GPIO9, SD_DATA2, SPIHD, HS1_DATA2, U1RXD SWP/SD3* 18 I/O GPIO10, SD_DATA3, SPIWP, HS1_DATA3, U1TXD SCS/CMD* 19 I/O GPIO11, SD_CMD, SPICS0, HS1_CMD, U1RTS SCK/CLK* 20 I/O GPIO6, SD_CLK, SPICLK, HS1_CLK, U1CTS SDO/SD0* 21 I/O GPIO7, SD_DATA0, SPIQ, HS1_DATA0, U2RTS SDI/SD1* 22 I/O GPIO8, SD_DATA1, SPID, HS1_DATA1, U2CTS IO15 23 I/O IO2 24 I/O IO0 25 I/O IO4 26 I/O NC1 27 - - NC2 28 - - IO5 29 I/O GPIO5, VSPICS0, HS1_DATA6, EMAC_RX_CLK IO18 30 I/O GPIO18, VSPICLK, HS1_DATA7 IO19 31 I/O GPIO19, VSPIQ, U0CTS, EMAC_TXD0 NC 32 - - IO21 33 I/O GPIO21, VSPIHD, EMAC_TX_EN RXD0 34 I/O GPIO3, U0RXD, CLK_OUT2 TXD0 35 I/O GPIO1, U0TXD, CLK_OUT3, EMAC_RXD2 IO22 36 I/O GPIO22, VSPIWP, U0RTS, EMAC_TXD1 IO23 37 I/O GPIO23, VSPID, HS1_STROBE GPIO32, XTAL_32K_P (32.768 kHz crystal oscillator input), ADC1_CH4, TOUCH9, RTC_GPIO9 GPIO33, XTAL_32K_N (32.768 kHz crystal oscillator output), ADC1_CH5, TOUCH8, RTC_GPIO8 GPIO14, ADC2_CH6, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2 GPIO12, ADC2_CH5, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3 Ground GPIO13, ADC2_CH4, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER GPIO15, ADC2_CH3, TOUCH3, MTDO, HSPICS0, RTC_GPIO13, HS2_CMD, SD_CMD, EMAC_RXD3 GPIO2, ADC2_CH2, TOUCH2, RTC_GPIO12, HSPIWP, HS2_DATA0, SD_DATA0 GPIO0, ADC2_CH1, TOUCH1, RTC_GPIO11, CLK_OUT1, EMAC_TX_CLK GPIO4, ADC2_CH0, TOUCH0, RTC_GPIO10, HSPIHD, HS2_DATA1, SD_DATA1, EMAC_TX_ER Not Recommended For New Designs (NRND) Espressif Systems 9 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 2 Pin Definitions Name No. Type Function GND 38 P Ground Notice: * Pins SCK/CLK, SDO/SD0, SDI/SD1, SHD/SD2, SWP/SD3 and SCS/CMD, namely, GPIO6 to GPIO11 are connected to the SPI flash integrated on the module and are not recommended for other uses. 2.3 Strapping Pins ESP32 has five strapping pins, which can be seen in Chapter 6 Schematics: • MTDI • GPIO0 • GPIO2 • MTDO • GPIO5 Software can read the values of these five bits from register ”GPIO_STRAPPING”. During the chip’s system reset release (power-on-reset, RTC watchdog reset and brownout reset), the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. The strapping bits configure the device’s boot mode, the operating voltage of VDD_SDIO and other initial system settings. Each strapping pin is connected to its internal pull-up/pull-down during the chip reset. Consequently, if a strapping pin is unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of the strapping pins. To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP32. After reset release, the strapping pins work as normal-function pins. Refer to Table 4 for a detailed boot-mode configuration by strapping pins. Table 4: Strapping Pins Voltage of Internal LDO (VDD_SDIO) Pin MTDI Default 3.3 V 1.8 V Pull-down 0 1 Booting Mode Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO2 Pull-down Don’t-care 0 Enabling/Disabling Debugging Log Print over U0TXD During Booting Pin Default U0TXD Active U0TXD Silent MTDO Pull-up 1 0 Not Recommended For New Designs (NRND) Espressif Systems 10 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 2 Pin Definitions Timing of SDIO Slave FE Sampling FE Sampling RE Sampling RE Sampling Pin Default FE Output RE Output FE Output RE Output MTDO Pull-up 0 0 1 1 GPIO5 Pull-up 0 1 0 1 Note: • Firmware can configure register bits to change the settings of ”Voltage of Internal LDO (VDD_SDIO)” and ”Timing of SDIO Slave” after booting. • Internal pull-up resistor (R9) for MTDI is not populated in the module, as the flash and SRAM in ESP32-WROVER-B and ESP32-WROVER-IB only support a power voltage of 3.3 V (output by VDD_SDIO). Not Recommended For New Designs (NRND) Espressif Systems 11 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 3 Functional Description 3 Functional Description This chapter describes the modules and functions integrated in ESP32-WROVER-B and ESP32-WROVER-IB. 3.1 CPU and Internal Memory ESP32-D0WD contains two low-power Xtensa® 32-bit LX6 microprocessors. The internal memory includes: • 448 KB of ROM for booting and core functions. • 520 KB of on-chip SRAM for data and instructions. • 8 KB of SRAM in RTC, which is called RTC FAST Memory and can be used for data storage; it is accessed by the main CPU during RTC Boot from the Deep-sleep mode. • 8 KB of SRAM in RTC, which is called RTC SLOW Memory and can be accessed by the co-processor during the Deep-sleep mode. • 1 Kbit of eFuse: 256 bits are used for the system (MAC address and chip configuration) and the remaining 768 bits are reserved for customer applications, including flash-encryption and chip-ID. 3.2 External Flash and SRAM ESP32 supports multiple external QSPI flash and SRAM chips. More details can be found in Chapter SPI in the ESP32 Technical Reference Manual. ESP32 also supports hardware encryption/decryption based on AES to protect developers’ programs and data in flash. ESP32 can access the external QSPI flash and SRAM through high-speed caches. • The external flash can be mapped into CPU instruction memory space and read-only memory space simultaneously. – When external flash is mapped into CPU instruction memory space, up to 11 MB + 248 KB can be mapped at a time. Note that if more than 3 MB + 248 KB are mapped, cache performance will be reduced due to speculative reads by the CPU. – When external flash is mapped into read-only data memory space, up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads are supported. • External SRAM can be mapped into CPU data memory space. Up to 4 MB can be mapped at a time. 8-bit, 16-bit and 32-bit reads and writes are supported. ESP32-WROVER-B and ESP32-WROVER-IB integrate a 4 MB SPI flash and an 8 MB PSRAM for more memory space. 3.3 Crystal Oscillators The module uses a 40-MHz crystal oscillator. Not Recommended For New Designs (NRND) Espressif Systems 12 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 3 Functional Description 3.4 RTC and Low­Power Management With the use of advanced power-management technologies, ESP32 can switch between different power modes. For details on ESP32’s power consumption in different power modes, please refer to section ”RTC and Low-Power Management” in ESP32 Datasheet. Not Recommended For New Designs (NRND) Espressif Systems 13 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 4 Peripherals and Sensors 4 Peripherals and Sensors Please refer to Section Peripherals and Sensors in ESP32 Datasheet. Note: External connections can be made to any GPIO except for GPIOs in the range 6-11, 16, or 17. GPIOs 6-11 are connected to the module’s integrated SPI flash and PSRAM. GPIOs 16 and 17 are connected to the module’s integrated PSRAM. For details, please see Section 6 Schematics. Not Recommended For New Designs (NRND) Espressif Systems 14 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 5 Electrical Characteristics 5 Electrical Characteristics 5.1 Absolute Maximum Ratings Stresses beyond the absolute maximum ratings listed in the table below may cause permanent damage to the device. These are stress ratings only, and do not refer to the functional operation of the device that should follow the recommended operating conditions. Table 5: Absolute Maximum Ratings Symbol Parameter VDD33 Power supply voltage Ioutput 1 Min Max –0.3 3.6 - 1,100 –40 105 Cumulative IO output current Tstore Storage temperature Unit V mA °C 1. The module worked properly after a 24-hour test in ambient temperature at 25 °C, and the IOs in three domains (VDD3P3_RTC, VDD3P3_CPU, VDD_SDIO) output high logic level to ground. Please note that pins occupied by flash and/or PSRAM in the VDD_SDIO power domain were excluded from the test. 2. Please see Appendix IO_MUX in ESP32 Datasheet for IO’s power domain. 5.2 Recommended Operating Conditions Table 6: Recommended Operating Conditions Symbol Parameter Min Typical Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.5 - - A T Operating ambient temperature –40 - 85 °C 5.3 DC Characteristics (3.3 V, 25 °C) Table 7: DC Characteristics (3.3 V, 25 °C) Symbol CIN VIH Parameter Min Pin capacitance Typ - High-level input voltage 0.75×VDD 2 1 - Max Unit - pF 1 VDD +0.3 V 1 VIL Low-level input voltage –0.3 - 0.25×VDD IIH High-level input current - - 50 nA IIL Low-level input current - - 50 nA VOH High-level output voltage 0.8×VDD1 - - V VOL Low-level output voltage - - 0.1×VDD1 V VDD3P3_CPU power domain 1, 2 - 40 - mA 1, 2 - 40 - mA - 20 - mA High-level source current 1 IOH (VDD = 3.3 V, VOH >= 2.64 V, output drive strength set to the maximum) VDD3P3_RTC power domain VDD_SDIO power domain 1, 3 Not Recommended For New Designs (NRND) Espressif Systems 15 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback V 5 Electrical Characteristics Symbol Parameter Min Typ Max Unit Low-level sink current (VDD1 = 3.3 V, VOL = 0.495 V, IOL - 28 - mA output drive strength set to the maximum) RP U Resistance of internal pull-up resistor - 45 - kΩ RP D Resistance of internal pull-down resistor - 45 - kΩ VIL_nRST Low-level input voltage of CHIP_PU to power off the chip - - 0.6 V Notes: 1. Please see Appendix IO_MUX in ESP32 Datasheet for IO’s power domain. VDD is the I/O voltage for a particular power domain of pins. 2. For VDD3P3_CPU and VDD3P3_RTC power domain, per-pin current sourced in the same domain is gradually reduced from around 40 mA to around 29 mA, VOH >=2.64 V, as the number of current-source pins increases. 3. Pins occupied by flash and/or PSRAM in the VDD_SDIO power domain were excluded from the test. 5.4 Wi­Fi Radio Table 8: Wi­Fi Radio Characteristics Parameter Condition Center frequency range of operating channel Typical Max Unit - 2412 - 2484 MHz - - * - 12 13 14 dBm 17.5 18.5 20 dBm 11b, 1 Mbps - –98 - dBm 11b, 11 Mbps - –89 - dBm 11g, 6 Mbps - –92 - dBm 11g, 54 Mbps - –74 - dBm 11n, HT20, MCS0 - –91 - dBm 11n, HT20, MCS7 - –71 - dBm 11n, HT40, MCS0 - –89 - dBm 11n, HT40, MCS7 - –69 - dBm 11g, 6 Mbps - 31 - dB 11g, 54 Mbps - 14 - dB 11n, HT20, MCS0 - 31 - dB 11n, HT20, MCS7 - 13 - dB note1 Output impedance note2 TX power Min note3 11n, MCS7 11b mode Sensitivity Adjacent channel rejection Ω 1. Device should operate in the center frequency range of operating channel allocated by regional regulatory authorities. Target center frequency range of operating channel is configurable by software. 2. For the modules that use external antennas, the output impedance is 50 Ω. For other modules without external antennas, users do not need to concern about the output impedance. 3. Target TX power is configurable based on device or certification requirements. Not Recommended For New Designs (NRND) Espressif Systems 16 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 5 Electrical Characteristics 5.5 BLE Radio 5.5.1 Receiver Table 9: Receiver Characteristics – Bluetooth LE Parameter Conditions Min Typ Max Sensitivity @30.8% PER - - –97 - dBm Maximum received signal @30.8% PER - 0 - - dBm Co-channel C/I - - +10 - dB F = F0 + 1 MHz - –5 - dB F = F0 – 1 MHz - –5 - dB F = F0 + 2 MHz - –25 - dB F = F0 – 2 MHz - –35 - dB F = F0 + 3 MHz - –25 - dB F = F0 – 3 MHz - –45 - dB 30 MHz ~ 2000 MHz –10 - - dBm 2000 MHz ~ 2400 MHz –27 - - dBm 2500 MHz ~ 3000 MHz –27 - - dBm 3000 MHz ~ 12.5 GHz –10 - - dBm - –36 - - dBm Unit Adjacent channel selectivity C/I Out-of-band blocking performance Intermodulation Unit 5.5.2 Transmitter Table 10: Transmitter Characteristics – Bluetooth LE Parameter Conditions Min Typ Max RF transmit power - - 0 - dBm Gain control step - - 3 - dBm RF power control range - –12 - +9 dBm F = F0 ± 2 MHz - –52 - dBm F = F0 ± 3 MHz - –58 - dBm F = F0 ± > 3 MHz - –60 - dBm ∆ f 1avg - - - 265 kHz ∆ f 2max - 247 - - kHz ∆ f 2avg /∆ f 1avg - - –0.92 - - ICFT - - –10 - kHz Drift rate - - 0.7 - kHz/50 µs Drift - - 2 - kHz Adjacent channel transmit power Not Recommended For New Designs (NRND) Espressif Systems 17 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 5 Electrical Characteristics Temperature (℃) 5.6 Reflow Profile Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 2: Reflow Profile Note: Solder the module in a single reflow. Not Recommended For New Designs (NRND) Espressif Systems 18 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 5 4 3 6 Schematics Espressif Systems 6 Schematics GND The values of C1 and C2 vary with the selection of the crystal. C1 C20 1uF GND 3 1 100pF VDD33 PCB ANTENNA GND 0.1uF C12 C11 C10 C21 NC 1uF 0.1uF NC 3.3nF/6.3V(10%) R3 499 GPIO21 U0TXD U0RXD GPIO22 D1 ESD GND CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 49 NC J39 C4 VDD33 0 L4 PCB ANT C TBD C15 C14 C16 TBD TBD NC C17 GND GND GND The values of C15, L4 and C14 vary with the actual PCB board. NC: No component. R12 SENSOR_VN CHIP_PU GPIO34 GPIO35 GPIO32 GPIO33 GPIO25 VDDA LNA_IN VDD3P3 VDD3P3 SENSOR_VP SENSOR_CAPP SENSOR_CAPN SENSOR_VN CHIP_PU VDET_1 VDET_2 32K_XP 32K_XN GPIO25 FLASH_CLK 0 38 37 36 35 34 33 32 31 30 29 28 27 26 25 GPIO19 VDD3P3_CPU GPIO23 GPIO18 GPIO5 SD_DATA_1 SD_DATA_0 SD_CLK SD_CMD SD_DATA_3 SD_DATA_2 GPIO17 VDD_SDIO GPIO16 15 16 17 18 19 20 21 22 23 24 U2 ESP32-D0WD GPIO23 GPIO18 GPIO5 SDI/SD1 SDO/SD0 SCK/CLK SCS/CMD SWP/SD3 SHD/SD2 GPIO17 GPIO16 R4 C24 VDD_SDIO NC 1uF GND VDD33 10K(NC) SRAM_CLK 0 R9 GPIO26 GPIO27 GPIO14 GPIO12 R13 C19 GPIO13 GPIO15 GPIO2 GPIO0 GPIO4 NC GPIO17 GPIO19 VDD33 R11 0.1uF GND VDD_SDIO FLASH_CLK 6 SHD/SD2 7 /CS CLK /HOLD FLASH VDD_SDIO VDD_SDIO 8 VCC 1 GND U3 SCS/CMD Flash and PSRAM DI DO /WP 5 SDI/SD1 2 SDO/SD0 3 SWP/SD3 R10 10K U4 GPIO16 SDO/SD0 SWP/SD3 4 Not Recommended For New Designs (NRND) ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 SCK/CLK NC SENSOR_VP 1 2 3 4 5 6 7 8 9 10 11 12 13 14 GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 0.1uF GND ANT1 1 R15 2 VDD33 GND GND GND 3 2 C6 10nF/6.3V(10%) CONN(NC) 19 Submit Documentation Feedback 1 R14 GND C5 20K(5%) R2 C13 10uF R1 48 47 46 45 44 43 42 41 40 39 L5 GND GND GND 2.0nH 0 40MHz(±10ppm) VDD33 GND TBD GND C9 GND C2 2 XIN TBD C3 U1 GND XOUT The value of R2 varies with the actual PCB board. VDD33 GND 4 GND GND D B 2 1 2 3 4 CS# VDD SO/SIO1 SIO3 SIO2 SCLK VSS SI/SIO0 8 7 6 5 SHD/SD2 SRAM_CLK SDI/SD1 GND GND Pin.1 GND Pin.2 3V3 Pin.3 EN Pin.4 SENSOR_VP Pin.5 SENSOR_VN Pin.6 IO34 Pin.7 IO35 Pin.8 IO32 Pin.9 IO33 Pin.10 IO25 Pin.11 IO26 Pin.12 IO27 Pin.13 IO14 Pin.14 IO12 Pin.15 GND Pin.16 IO13 Pin.17 SD2 Pin.18 SD3 Pin.19 CMD GND GND GPIO23 VDD33 CHIP_PU GPIO22 SENSOR_VP U0TXD SENSOR_VN U0RXD GPIO34 GPIO21 GPIO35 GPIO32 Pin.39 EPAD GPIO18 GPIO25 GPIO5 GND GPIO26 GPIO27 GPIO14 GPIO4 GPIO12 GPIO0 GPIO2 GND GPIO13 GPIO15 SHD/SD2 SDI/SD1 SWP/SD3 SDO/SD0 SCS/CMD FLASH_CLK PSRAM GND ESP32-WROVER-B(pin-out) GND Figure 3: Schematics of ESP32­WROVER­B GPIO19 EP GPIO33 Pin.38 GND Pin.37 IO23 Pin.36 IO22 Pin.35 U0TXD Pin.34 U0RXD Pin.33 IO21 Pin.32 NC Pin.31 IO19 Pin.30 IO18 Pin.29 IO5 Pin.28 NC Pin.27 NC Pin.26 IO4 Pin.25 IO0 Pin.24 IO2 Pin.23 IO15 Pin.22 SD1 Pin.21 SD0 Pin.20 CLK 5 4 1uF 1 100pF GND XOUT C20 VDD33 PCB ANTENNA GND 0.1uF C11 C10 C21 10uF NC 1uF 0.1uF NC C6 10nF/6.3V(10%) 3.3nF/6.3V(10%) R3 499 GPIO21 U0TXD U0RXD GPIO22 CONN D1 ESD GND CAP1 CAP2 VDDA XTAL_P XTAL_N VDDA GPIO21 U0TXD U0RXD GPIO22 49 0 J39 C4 VDD33 GND ANT1 0(NC) C L4 TBD C15 C14 C16 TBD TBD NC C17 GND GND GND The values of C15, L4 and C14 vary with the actual PCB board. NC: No component. NC SENSOR_VP SENSOR_VN CHIP_PU GPIO34 GPIO35 GPIO32 GPIO33 GPIO25 VDDA LNA_IN VDD3P3 VDD3P3 SENSOR_VP SENSOR_CAPP SENSOR_CAPN SENSOR_VN CHIP_PU VDET_1 VDET_2 32K_XP 32K_XN GPIO25 20 SCK/CLK R12 FLASH_CLK 0 38 37 36 35 34 33 32 31 30 29 28 27 26 25 GPIO19 VDD3P3_CPU GPIO23 GPIO18 GPIO5 SD_DATA_1 SD_DATA_0 SD_CLK SD_CMD SD_DATA_3 SD_DATA_2 GPIO17 VDD_SDIO GPIO16 15 16 17 18 19 20 21 22 23 24 U2 ESP32-D0WD GPIO16 R4 C24 VDD_SDIO NC 1uF 0 R9 GPIO26 GPIO27 GPIO14 GPIO12 R13 10K(NC) C19 GPIO13 GPIO15 GPIO2 GPIO0 GPIO4 VDD33 SRAM_CLK 0.1uF GND VDD_SDIO SHD/SD2 6 7 /CS CLK /HOLD FLASH VDD_SDIO 8 VCC FLASH_CLK 1 GND U3 SCS/CMD Flash and PSRAM VDD_SDIO DI DO /WP 5 2 3 R10 SDI/SD1 10K SDO/SD0 SWP/SD3 U4 GPIO16 SDO/SD0 SWP/SD3 4 Not Recommended For New Designs (NRND) B GPIO23 GPIO18 GPIO5 SDI/SD1 SDO/SD0 SCK/CLK SCS/CMD SWP/SD3 SHD/SD2 GPIO17 GND NC GPIO17 GPIO19 VDD33 R11 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 1 R15 2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 GPIO26 GPIO27 MTMS MTDI VDD3P3_RTC MTCK MTDO GPIO2 GPIO0 GPIO4 0.1uF PCB ANT VDD33 GND GND GND 3 2 1 R14 GND C5 20K(5%) R2 C12 R1 48 47 46 45 44 43 42 41 40 39 L5 C13 GND GND GND 2.0nH 0 40MHz(±10ppm) VDD33 GND TBD GND C9 GND C2 2 XIN TBD GND U1 GND C1 3 GND 4 GND The value of R2 varies with the actual PCB board. C3 6 Schematics Espressif Systems D 2 GND The values of C1 and C2 vary with the selection of the crystal. VDD33 3 1 2 3 4 CS# VDD SO/SIO1 SIO3 SIO2 SCLK VSS SI/SIO0 8 7 6 5 SHD/SD2 SRAM_CLK SDI/SD1 GND GND Pin.1 GND Pin.2 3V3 Pin.3 EN Pin.4 SENSOR_VP Pin.5 SENSOR_VN Pin.6 IO34 Pin.7 IO35 Pin.8 IO32 Pin.9 IO33 Pin.10 IO25 Pin.11 IO26 Pin.12 IO27 Pin.13 IO14 Pin.14 IO12 Pin.15 GND Pin.16 IO13 Pin.17 SD2 Pin.18 SD3 Pin.19 CMD GND GND GPIO23 VDD33 CHIP_PU GPIO22 SENSOR_VP U0TXD SENSOR_VN U0RXD GPIO34 GPIO21 GPIO35 GPIO32 Pin.39 EPAD GPIO33 GPIO18 GPIO25 GPIO5 GND GPIO26 GPIO27 GPIO14 GPIO4 GPIO12 GPIO0 GPIO2 GND GPIO13 GPIO15 SHD/SD2 SDI/SD1 SWP/SD3 SDO/SD0 SCS/CMD FLASH_CLK PSRAM GND ESP32-WROVER-IB(pin-out) GND Figure 4: Schematics of ESP32­WROVER­IB GPIO19 EP Pin.38 GND Pin.37 IO23 Pin.36 IO22 Pin.35 U0TXD Pin.34 U0RXD Pin.33 IO21 Pin.32 NC Pin.31 IO19 Pin.30 IO18 Pin.29 IO5 Pin.28 NC Pin.27 NC Pin.26 IO4 Pin.25 IO0 Pin.24 IO2 Pin.23 IO15 Pin.22 SD1 Pin.21 SD0 Pin.20 CLK 7 Peripheral Schematics 7 Peripheral Schematics U1 C2 R1 22uF 0.1uF TBD C3 TBD GND GND EN SENSOR_VP SENSOR_VN IO34 IO35 IO32 IO33 IO25 IO26 IO27 IO14 IO12 IO13 P_GND GND3 IO23 IO22 TXD0 RXD0 IO21 NC3 IO19 IO18 IO5 NC2 NC1 IO4 IO0 IO2 IO15 SD1 SD0 CLK GND1 3V3 EN SENSOR_VP SENSOR_VN IO34 IO35 IO32 IO33 IO25 IO26 IO27 IO14 IO12 GND2 IO13 SD2 SD3 CMD 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 GND JP1 1 2 3 4 IO19 IO18 IO5 1 2 3 4 UART GND IO4 IO0 IO2 IO15 ESP32-WROVER-B/ESP32-WROVER-IB GND JP2 Boot Option GND SW1 JP3 1 2 3 4 VDD33 IO23 IO22 TXD0 RXD0 IO21 1 2 C1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 1 2 VDD33 1 2 3 4 TMS TDI TCK TDO IO14 IO12 IO13 IO15 R2 C4 JTAG 0 EN 0.1uF GND IO12 should be kept low when the module is powered on. Figure 5: Peripheral Schematics Note: • Soldering Pad 39 to the Ground of the base board is not necessary for a satisfactory thermal performance. If users do want to solder it, they need to ensure that the correct quantity of soldering paste is applied. • To ensure the power supply to the ESP32 chip during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32’s power-up and reset sequence timing diagram, please refer to Section Power Scheme in ESP32 Datasheet. Not Recommended For New Designs (NRND) Espressif Systems 21 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 8 Physical Dimensions 8 Physical Dimensions Unit: mm 18.00±0.15 3.30±0.15 3.60 3.72 23.05 24.09 31.40±0.15 6.22 3.60 10.45 1.27 15.84 0.57 1.10 10.50 16.16 0.45 0.85 0.1 6.22 0.90 0.80 2.12 Top View Side View Bottom View Figure 6: Physical Dimensions Note: For information about tape, reel, and product marking, please refer to Espressif Module Package Information. Not Recommended For New Designs (NRND) Espressif Systems 22 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 9 Recommended PCB Land Pattern 9 Recommended PCB Land Pattern Unit: mm Via for thermal pad Copper 6.22 18.00 Antenna Area 38x1.50 3.70 0.90 0.50 0.50 0.90 3.70 16.16 1.27 1.10 7.50 38 22.86 31.40 38x0.90 1 20 19 0.50 Figure 7: Recommended PCB Land Pattern Not Recommended For New Designs (NRND) Espressif Systems 23 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 10 Dimensions of External Antenna Connector 10 Dimensions of External Antenna Connector Unit: mm Figure 8: Dimensions of External Antenna Connector Not Recommended For New Designs (NRND) Espressif Systems 24 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback 11 Related Documentation and Resources 11 Related Documentation and Resources Related Documentation • ESP32 Technical Reference Manual – Detailed information on how to use the ESP32 memory and peripherals. • ESP32 Hardware Design Guidelines – Guidelines on how to integrate the ESP32 into your hardware product. • ESP32 ECO and Workarounds for Bugs – Correction of ESP32 design errors. • Certificates https://espressif.com/en/support/documents/certificates • ESP32 Product/Process Change Notifications (PCN) https://espressif.com/en/support/documents/pcns • ESP32 Advisories – Information on security, bugs, compatibility, component reliability. https://espressif.com/en/support/documents/advisories • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32 Series SoCs – Browse through all ESP32 SoCs. https://espressif.com/en/products/socs?id=ESP32 • ESP32 Series Modules – Browse through all ESP32-based modules. https://espressif.com/en/products/modules?id=ESP32 • ESP32 Series DevKits – Browse through all ESP32-based devkits. https://espressif.com/en/products/devkits?id=ESP32 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Not Recommended For New Designs (NRND) Espressif Systems 25 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback Revision History Revision History Date Version Release notes Updated Table 1 Added a link to RF certificates in Table 2 2022-03-04 v1.8 Updated Table 5 Added a note below Figure 6 Updated the description to the connector Added Section 11: Related Documentation and Resources Added ESP32-WROVER-IB module Added Figure 4: Schematics of ESP32-WROVER-IB Updated Figure 1: Pin Layout (Top View) , Figure 3: Schematics of ESP32-WROVER-B, 2021-08-10 v1.7 and Figure 5: Peripheral Schematics Replaced Espressif Product Ordering Information with ESP Product Selector Updated the description of TWAI in Table 2: Overview Added a label of (Not Recommended For New Designs) to this document Updated Figure 6: Physical Dimensions and Figure 7: Recommended PCB Land Pattern Deleted Reset Circuit and Discharge Circuit for VDD33 Rail in Section 7: Peripheral 2021-02-09 V1.6 Schematics Modified the note below Figure 2: Reflow Profile. Updated the trade mark from TWAI™ to TWAI® . 2020-11-27 V1.5 Added TWAITM in Table 2; Updated the C value in RC circuit from 0.1 µF to 1 µF. • Changed the module’s operating temperature range from –40°C ~ 65°C to –40°C 2020-03-13 V1.4 ~ 85°C • Added documentation feedback link • Changed the supply voltage range from 2.7 V ~ 3.6 V to 3.0 V ~ 3.6 V; • Added Moisture sensitivity level (MSL) 3 in Table 2 ESP32-WROVER-B Specifications; 2019.09 V1.3 • Added notes about ”Operating frequency range” and ”TX power” under Table 8 Wi-Fi Radio Characteristics; • Updated Section 7 Peripheral Schematics and added a note about RC delay circuit under it; • Updated Figure 9 Recommended PCB Land Pattern. 2019.01 V1.2 Changed the RF power control range in Table 10 from –12 ~ +12 to –12 ~ +9 dBm. Added notes on module custom options to Table 1; 2018.10 V1.1 Added ”Cumulative IO output current” entry to Table 5: Absolute Maximum Ratings; Added more parameters to Table 7: DC Characteristics. Not Recommended For New Designs (NRND) Espressif Systems 26 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback Revision History Date Version Release notes Official release: • Added certifications and reliability test items the module has passed in Table 2: ESP32-WROVER-B Specifications; 2018.07 V1.0 • Updated the dimensions of the module; • Changed the module’s recommended operating temperature from –40°C ~ 85°C to –40°C ~ 65°C; • Updated table 8: Wi-Fi Radio. 2018.06 V0.1 Preliminary release. Not Recommended For New Designs (NRND) Espressif Systems 27 ESP32-WROVER-B & ESP32-WROVER-IB Datasheet v1.8 Submit Documentation Feedback Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2022 Espressif Systems (Shanghai) Co., Ltd. All rights reserved. Not Recommended For New Designs (NRND)
ESP32-WROVER-IB 价格&库存
很抱歉,暂时无法提供与“ESP32-WROVER-IB”相匹配的价格&库存,您可以联系我们找货
