IN-PI55TAT(X)R(X)G(X)B
5050 RGB LED 4-Pin with Integrated IC
Features
Description
5050 with integrated high quality constant
current IC and RGB LED chip.
Built-in IC, with high precision of constant
current and internal RGB chips spectral
processing in advance.
Single line data transmission (return to zero
code).
Specific Shaping Transmit Technology - number
of LED stacked is not restricted.
Cascading Enhancement Technology - any 2 LED
spacing can be up to 10 meters
Data transfer rate of 800 kbp/s at 30 frames per
second.
RGB output port PWM control can achieve 256
grey level adjustments.
Upon powering up, IC performs self-inspection
then lights connection on the pin B lamp.
SA-I Anti-interference patent technology for
single line data transmission.
Built-in power supply reverse connect protection
module, reversed power input will not damage
the IC.
The IN-PI55TAT(X)R(X)G(X)B is 5.0*5.0*1.6mm RGB
LED with integrated IC. It is a SMD type LED which
can be used in various applications.
Applications
Full color LED string light
LED full color module
LED guardrail tube
LED scene lighting
LED point light
LED pixel screen
LED shaped screen
Package Outline Dimensions & Pin Configuration
Figure 1. IN-PI55TAT(X)R(X)G(X)B Package Outline Dimensions
Inolux Corporation
Proprietary & Confidential
Page 1
Feb. 4, 2021
www.inolux-corp.com
Pin Configuration
Figure 2. IN-PI55TAT(X)R(X)G(X)B Pin Configuration
Notes:
1. Dimension in millimeter, tolerance is ±0.1mm unless otherwise noted.
Number
Symbol
Function Description
1
2
3
4
GND
DOUT
DIN
VDD
Ground
Control data signal output
Control data signal input
Power supply LED
Soldering Pad Size
Pad Size
Steel mesh size
Notes:
Inolux Corporation
Page 2
Feb. 4, 2021
www.inolux-corp.com
Absolute Maximum Rating (Ta = 25 ℃, VSS=0V)
Parameter
Symbol
Range
Unit
Logic supply voltage
VDD
+3.7~+5.4
V
Logic input voltage
VIN
-0.4 ~VDD+0.4
V
Operating temperature
TOPT
−30 ~ +85
°C
Storage temperature
TSTG
−40 ~ +90
°C
ESD pressure(HBM)
VESD
4K
V
ESD pressure(DM)
VESD
200
V
LED Characteristics (Ta = 25°C)
IN-PI55TAT5R5G5B
IN-PI55TATPRPGPB
(5mA Max. per LED Chip)
(12mA Max. per LED Chip)
Color
Wavelength(nm)
Light Intensity(mcd)
Wavelength(nm)
Red
620-630
100-200
620-630
400-700
Green
520-535
400-700
520-535
1000-1500
Blue
460-475
50-100
460-475
200-400
Inolux Corporation
Page 3
Feb. 4, 2021
www.inolux-corp.com
Recommended Operating Ranges (unless otherwise specified, Ta= -20 ~ +70 ℃, VDD=4.5 ~ 5.5V,VSS=0V)
Parameter
Symbol
Min.
Typ.
Max
Unit
Test conditions
Supply voltage
VDD
5.0
V
High level input voltage
VIH
0.7*VDD
V
VDD=5.0V
Low level input voltage
VIL
0.3*VDD
V
VDD=5.0V
The frequency of PWM
FPWM
1.2
KHZ
IDD
0.5
mA
VDD=4.5V
Iout ”OFF”
Static power consumption
Inolux Corporation
Page 4
Feb. 4, 2021
www.inolux-corp.com
Switching Characteristics (unless otherwise specified, Ta=25 ℃)
Parameter
The speed of data transmission
Symbol
Min.
Typ.
Max
Unit
Test conditions
fDIN
800
KHZ
The duty ratio of 67%
(data 1)
TPLH
80
ns
TPHL
80
ns
Tr
50
ns
Tf
100
ns
DOUT transmission delay
IOUT Rise/Drop Time
The earth load
capacitance of the dout
port is 30pf.
IOUT R/G/B = 12mA,
out port is connected
with 200 Ω resistor to
VDD in series, and the
load capacitance to
ground is 30pf
Timing Waveforms
1. Input Code
Inolux Corporation
Page 5
Feb. 4, 2021
www.inolux-corp.com
2. The data transmission time (TH+TL=1.25µs±600ns):
Name
Description
Min.
Typ.
Max.
Unit
T0H
0 code, high level time
0.3μs
μs
T0L
0 code, low level time
0.9μs
μs
T1H
1 code, high level time
0.6μs
μs
T1L
1 code, low level time
0.6μs
μs
Trst
Reset code, low level time
200
80μs
μs
3. Connection Scheme
4. Data Transfer Format
Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit.
5. 24-bit data format
Note: high starting, in order to send data (G7 - G6 - ...... ..B0)
Inolux Corporation
Page 6
Feb. 4, 2021
www.inolux-corp.com
Typical Application Circuit
Product signal input and output must be connected in series with protection resistor R1. R1 depends on the size of the cascade amount,
the greater the number of cascade, the smaller R1. The general recommended value is between 200-2KΩ, usually the recommended
value is typical 500Ω.
Inolux Corporation
Page 7
Feb. 4, 2021
www.inolux-corp.com
LED Performance Graph
Inolux Corporation
Page 8
Feb. 4, 2021
www.inolux-corp.com
Ordering Information
Product
Emission Color
IV(mcd)
R
100-200
G
400-700
B
50-100
R
400-700
G
1000-1500
B
200-400
IN-PI55TAT5R5G5B
IN-PI55TATPRPGPB
Orderable
Part Number
IN-PI55TAT5R5G5B
IN-PI55TATPRPGPB
Label Specifications
Inolux P/N:
I
N
PI
Product
Inolux
55
T
Package
Die
Qty.
PI- Single trace IC
A
Variation
55TA = 5.0 x 5.0 x 1.6 mm (4
pins)
PC- Clock Function IC
T
(X)
R
(X)
G
(X)
B
Orientation
Current
Color
Current
Color
Current
Color
T = Top
Mount
P=12mA
5 = 5mA
R = 624
nm
P=12mA
5 = 5mA
G=
520
nm
P=12mA
5 = 5mA
B=
470
nm
- X
X
X
Customized
Stamp-off
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
Page 9
01
24
001
Month
Date
Serial
Feb. 4, 2021
www.inolux-corp.com
X
Precautions
Please read the following notes before using the product:
1. Storage
1.1 Do not open moisture proof bag before the products are ready to use.
1.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less.
1.3 The LEDs should be used within a year.
1.4 After opening the package, the LEDs should be kept at 30℃ or less and 60%RH or less.
1.5 The LEDs should be used within 24 hours (1 days) after opening the package.
1.6 If the moisture adsorbent material has fabled away or the LEDs have exceeded the storage time,
baking treatment should be performed using the following conditions. Baking treatment: 60±5℃ for
24 hours.
Inolux Corporation
Page 10
Feb. 4, 2021
www.inolux-corp.com
2. Soldering Condition
Recommended soldering conditions:
Profile Feature
Lead-Free Solder
Average Ramp-Up Rate (Ts
max
to Tp )
3℃/second max.
Preheat: Temperature Min (Ts
min)
150℃
max)
200℃
Preheat: Time ( ts
min to
ts
max
60-180 seconds
Time Maintained Above: Temperature (TL)
217 ℃
Time Maintained Above: Time (t L)
60-150 seconds
Peak/Classification Temperature (T P)
240 ℃
Time Within 5℃ of Actual Peak Temperature ( tp)
很抱歉,暂时无法提供与“IN-PI55TATPRPGPB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.113881+0.66369
- 10+3.5062010+0.45504
- 100+2.52413100+0.32759
- 500+2.08380500+0.27044
- 国内价格
- 1+3.29280
- 10+2.59700
- 30+2.30300
- 100+1.93060
- 国内价格
- 1+3.61800
- 10+2.84940
- 30+2.52220
- 100+2.11230
- 500+1.93630
- 1000+1.82900
- 国内价格
- 1+3.62880
- 10+2.86200
- 30+2.53800
- 100+2.12760
- 500+1.95480
- 1000+1.84680
- 国内价格
- 1+4.67640
- 10+3.78000
- 30+3.33720
- 国内价格 香港价格
- 1+5.122331+0.66479
