Touch Wheel Controller for Analog RGB
LED Strips
PRODUCT ID: 1005
This touch controller set is a quick and easy way to control a bunch of our 12V
analog RGB LED strip. The box part contains power driver circuitry and a
capacitive touch interface. By wiring the analog strip to the box you can easily
adjust the color with the touch wheel-- perfect for mounting on the wall.
The box has a few 'programs' built in, such as rainbow fading and a really
obnoxious colorful blinking effect. However, you'll probably end up being very
happy with the basic control system that the dial allows. You can turn it on or
off by pressing the power button, change through programmable modes, and
select the color using the scrolling color wheel. The controller remembers what
the last setting is/was when power is lost.
This package contains just the wired controller box. You'll likely want to pick up
a few other items to complete the project:
Solderless Analog RGB LED Strip Clip Sampler or 4-pin euro terminal
block allows connecting the LED strip without soldering
12V 5A power adapter is perfect for driving any of our LED strips! It can
drive up to 5 meters of the 60 LED/meter strip
JST Plugs and JST Receptacles - for quick connecting LED strip segments.
2.1mm barrel jack adapter will let you solderlessly connect the 12V power
adapter to the RGB controller box.
LED strips! You can use this with our 60 LED/meter RGB, 30 LED/meter
RGB or 60 LED/meter warm white.
TECHNICAL DETAILS
Working temperature: -20 to 60°C
Control Box Dimensions: 86mm x 86mm x 37mm
Strip power voltage: 12-24VDC
3 Channel output, 4 Amps per channel (12 Amps total)
For common anode LED strips
100 brightness levels
64 Color selectable wheel
https://www.adafruit.com/product/1005 12‐3‐18
很抱歉,暂时无法提供与“1005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+375.414371+48.56987
- 国内价格 香港价格
- 1+119.140471+15.41400
- 国内价格 香港价格
- 1+117.098071+15.14976
