VAZ-T1-FK-G10-1M-PUR-V1-G
    PEPPERL+FUCHS(倍加福)
VAZ-T1-FK-G10-1M-PUR-V1-G 数据手册
AS-Interface splitter box VAZ-T1-FK-G10-1M-PUR-V1-G < < < < < < < One piece housing Simple and fast mounting Gold-plated and machined contacts Oil and abrasion resistant PUR line appropriate for drag chains Immunity to vibration Degree of protection IP68 / IP69K Halogen-free Splitter box G10, AS-Interface to 1x M12 round connector 45.3 27.7 L 22 40.5 14.8 M12 x 1 Dimensions Technical Data Release date: 2021-09-17 Date of issue: 2021-09-17 Filename: 216030_eng.pdf General specifications Construction type Socket, straight Flat cable terminal AS-Interface UL File Number E223772 "For use in NFPA 79 Applications only" Electrical specifications Rated operating voltage Ue ≤ 32 V PELV ( AS-Interface ) Rated operating current Ie ≤3A Protection class III Current loading capacity max. 4 A Surge protection overvoltage category III Compliance with standards and directives Standard conformity Degree of protection EN 60529:2000 Approvals and certificates UL approval Maximum permissible ambient temperature cULus Listed, Type 1 enclosure max. 55 °C (max. 131 °F) Ambient conditions Ambient temperature -25 ... 75 °C (-13 ... 167 °F) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 AS-Interface splitter box VAZ-T1-FK-G10-1M-PUR-V1-G Technical Data Storage temperature -25 ... 85 °C (-13 ... 185 °F) Pollution degree 3 Mechanical specifications Degree of protection IP67 IP67 / IP68 / IP69K with flat cable VAZ-FK-S-* Connection Flat cable AS-Interface: cable piercing method Plug connection: M12 x 1 socket (V1) Material Contacts CuSn / Au Housing PBT PC Body PUR, black Cable PUR Mounting screw Stainless steel 1.4305 / AISI 303 Cable Sheath diameter ∅4,3 mm Color black Cores 2 x 0.34 mm2 Length L 1m Mass 75 g Tightening torque, fastening screws 1.65 Nm Note The unused flat cable connector is closed with a seal. Connection 3.1 AS-Interface + 1.1 1 5 1.2 3.2 AS-Interface - 1.3 2 4 1.4 1.5 3 Mounting 17 27.7 Release date: 2021-09-17 Date of issue: 2021-09-17 Filename: 216030_eng.pdf Ø 4.2 40.5 You may screw the device onto a level mounting surface using two M4 attachment screws. The attachement screws are not included. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
物料型号:VAZ-T1-FK-G10-1M-PUR-V1-G
器件简介:AS-Interface splitter box,具有单件式外壳,安装简单快捷,镀金加工接触点,耐油耐磨PUR线适用于拖链,抗振,防护等级为IP68/IP69K,无卤。
引脚分配:1.1 AS-Interface +,1.2 AS-Interface -,1.3 至 1.5 为连接点。
参数特性:额定工作电压Ue ≤ 32 V PELV (AS-Interface),额定工作电流Ie ≤ 3 A,保护等级III,最大电流负载4 A,浪涌保护电压等级III。
功能详解:该分线盒将AS-Interface信号转换为1个M12圆形连接器,适用于工业自动化和控制领域。
应用信息:适用于NFPA 79应用,UL文件编号E223772。
封装信息:尺寸为27.7 x 22 x 40.5 x L45.3 mm,M12 x 1接口,重量为75克。
VAZ-T1-FK-G10-1M-PUR-V1-G 价格&库存
很抱歉,暂时无法提供与“VAZ-T1-FK-G10-1M-PUR-V1-G”相匹配的价格&库存,您可以联系我们找货
