IN-S85ATYG
IN-S85ATYG
    INOLUX(英诺斯)
    发光二极管/LED 黄绿色 0805 572nm 45mcd
IN-S85ATYG 数据手册
IN-S85AT series Top View SMD LED 0805 PCB Type Features • 0805 1.1mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens Description The IN-S85AT series is a popular low profile 0805 package with versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S85AT Solder Pattern Package Dimensions in mm Figure 2. IN-S85AT Package Dimensions Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 1 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color IN-S85ATYG Yellow Green IN-S85ATY Yellow IN-S85ATA Amber IN-S85ATR Red IN-S85AT5B Blue IN-S85ATG Green IN-S85AT5UW White Pd (mW) IF (mA) IFP* (mA) 75 25 70 75 25 VR (V) TOP (oC) TST (oC) 5 -30oC~+85oC -40oC~+90oC 100 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 2 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Electrical Characteristics T A = 25°C (Note 1) VF(V) Product Emission Color IN-S85ATYG Yellow Green Viewing λ(nm) Angel IF(mA) I*V(mcd) min max λD λP △λ 2θ1/2 typ. 20 1.8 2.6 572 576 15 120 45 IN-S85ATY Yellow 20 1.8 2.6 592 594 15 120 115 IN-S85ATA Amber 20 1.8 2.6 605 610 20 120 80 IN-S85ATR Red 20 1.8 2.6 625 630 20 120 140 IN-S85AT5B Blue 5 2.6 3.4 470 473 30 120 80 IN-S85ATG Green 20 2.8 3.6 520 528 35 120 600 IN-S85AT5UW White 5 2.6 3.4 X=0.29 Y=0.29 - - 120 180 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 3 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Chromaticity Bin (for White only) Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 4 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 5 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 6 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 7 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product Technolog Test Current Emission Color y IF (mA) Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Orderable Part Number IN-S85ATYG Yellow Green AllnGaP 20 45 2.0 IN-S85ATYG IN-S85ATY Yellow AllnGaP 20 115 2.0 IN-S85ATY IN-S85ATA Amber AllnGaP 20 80 2.0 IN-S85ATA IN-S85ATR Red AllnGaP 20 140 2.2 IN-S85ATR IN-S85AT5B Blue InGaN 5 80 3.0 IN-S85AT5B IN-S85ATG Green InGaN 20 600 3.2 IN-S85ATG IN-S85AT5UW White InGaN 5 180 3.0 IN-S85AT5UW Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 8 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Label Specifications Inolux P/N: I N - S 8 Material S = PCB Type Inolux SMD 5 Package A T Variation Orientation 85A = 2.0 x 1.25 x 1.1mm X T = Top Mount Current (Blank) = 20mA Lens Color (Blank) = Clear U = Diffused R=630nm A=610nm Y=594nm YG=576nm G=528nm B=473nm W=White 5-5mA - X X X Customized Stamp-off Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) 01 24 001 Month Date Serial February, 13, 2019 Page 9 X www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Packaging Information: 3000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 10 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 3000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 11 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential February, 13, 2019 Page 12 www.inolux-corp.com IN-S85AT series Top View SMD LED 0805 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S85ATYG 价格&库存
很抱歉,暂时无法提供与“IN-S85ATYG”相匹配的价格&库存,您可以联系我们找货
IN-S85ATYG
    IN-S85ATYG
    • 1+1.589241+0.20587
    • 10+1.0762110+0.13941
    • 100+0.74887100+0.09701
    • 500+0.59626500+0.07724
    • 1000+0.545371000+0.07065
    库存:5687
    IN-S85ATYG
    • 3000+0.479483000+0.06211
    • 6000+0.445746000+0.05774
    • 9000+0.428399000+0.05550
    • 15000+0.4087615000+0.05295
    • 21000+0.3970721000+0.05144
    • 30000+0.3856430000+0.04996
    库存:5687
    IN-S85ATYG
      库存:6000
