269G1-LPBK
269G1-LPBK
    ANDERSON
    269G1-LPBK
269G1-LPBK 数据手册
MARC Multi Axial Rotational Connector The Multi Axial Rotational Connector “MARC” features 8 Powerpole® contacts integrated into a blindmate housing. The connector is designed to blindmate from 2 rotating axis or straight on. The two row, horizontally oriented connector uses our industry leading flat wiping contacts. The MARC is rated to 29 amps per circuit and can be configured with 8 standard length contacts or 6 standard length and 2 pre mate, multi-purpose contacts, which can function as ground, power or signal. The rugged connector is UL listed and rated up to 10,000 mating cycles. The dielectric is a chemically resistant PBT plastic. APP connectors are manufactured using the finest materials and world-class manufacturing processes. They embody the highest quality in the industry and meet all applicable industry standards. • Rotational Blindmate Error Correction • Rugged and Durable • Sequential Mating • Interchangeable Genderless Design Enables blindmating from 2 independently rotating axes with .100” of error correction Can be configured with up to 8 power and signal or 6 power and signal circuits and 2 pre mate contacts - The connector is rated up to 10,000 mating cycles - Constructed of chemically resistant PBT plastic Makes assembly quick and easy and reduces number of parts stocked | ORDERING INFORMATION | 45A Premate Ground Wire Contacts Housings Description Minimum Quantity ...................... Housing with springs Housing with float mount kit Housing with fixed mount kit - Part Numbers 25 ...... 602G00 602G01 602G02 PP15-45 Tin Plated Power Contacts Offer cost effective performance up to 1,500 mating cycles. See specifications and temperature charts for amperage ratings by wire size. Mating Loose Piece Reeled Barrel AWG mm² Force -------- Part Numbers ------- Minimum Quantity ...................................... 200 5,000 ... Open 14 to 10 K* 2.1 to 5.3 High 269G3-LPBK 269G3 Open 14 to 10 K* 2.1 to 5.3 Low 261G2-LPBK 261G2 Open 14 to 10 SF* 2.1 to 6.0 High 201G1H-LPBK 201G1H Open 14 to 10 SF* 2.1 to 6.0 Low 200G1L-LPBK 200G1L Open 16 to 12 1.3 to 3.3 High 269G1-LPBK 269G1 Open 16 to 12 1.3 to 3.3 Low 261G1-LPBK 261G1 Open 20 to 16 0.52 to 1.3 High 269G2-LPBK 269G2 Open 20 to 16 0.52 to 1.3 Low 262G1-LPBK 262G1 Open 20 to 16 SF* 0.52 to 1.5 Low 200G2L-LPBK 200G2L Tin or silver plated contacts are rated for ground or power. Hand crimp tools are available for loose piece contacts. Reeled contacts can be used with high volume press and applicator crimp tooling. Tin contacts are rated for up to 1,500 mating cycles. Silver contacts are rated up to 10,000 mating cycles. Reeled Mating Loose Piece Part Type AWG mm² Force - Part Numbers - - Numbers Minimum Quantity ............................................. 200 5,000 ..... Open, Tin 14 to 10 2.1 to 6.0 Low 1830G1-LPBK 1830G1 Open, Silver 14 to 10 2.1 to 6.0 Low 1830G2-LPBK 1830G2 PP15-45 Silver Plated Power Contacts Maximize performance by offering up to 10,000 mating cycles and are recommended for circuit interrupt or hot plug applications. See specifications and temperature charts for amperage ratings by wire size. Only closed barrel contacts are suitable for soldering. Mating Loose Piece Reeled Barrel AWG mm² Force ------------- Part Numbers -------------Minimum Quantity ....................................... 5,000 200 5,000 .. Open 14 to 10 K* 2.1 to 5.3 Low - 261G3-LPBK 261G3 Open 14 to 10 SF* 2.1 to 6.0 High - - 201G3H Open 14 to 10 SF* 2.1 to 6.0 Low - 200G3L-LPBK 200G3L Open 16 to 12 1.3 to 3.3 Low - 261G4-LPBK 261G4 Open 20 to 16 0.52 to 1.3 Low - 262G2-LPBK 262G2 Open 20 to 16 SF* 0.52 to 1.5 Low - - 200G4L Closed 16 to 12 1.3 to 3.3 Low 1331-BK 1331 Closed 20 to 16 0.52 to 1.3 Low 1332-BK 1332 - Accessories Description - Part Numbers Minimum Quantity ... 25 ... Float Mount Kit 110G69 Fixed Mount Kit 103G40 K* - For #10 AWG class K stranded wire or smaller. For larger wires use superflex contacts. SF*- Indicates wires with high stranding such as Super Flex. | SPECIFICATIONS | Current Rating (Amperes) #10 AWG = 29A @ 30º rise #12 AWG = 24A @ 30º rise #18 AWG = 14A @ 30º rise Voltage Rating (AC/DC) 600V AC/DC per UL1977 150V DC per EN1175-1 35 Contact Barrel Wire Size (AWG) 10 to 20 (mm²) 4 to 0.5 Average Contact Resistance MARC Connector Temperature Rise at Constant Current 40 Temperature (°C) Electrical | TEMPERATURE CHART | 15A contact = 875 x 106 ohms 30A contact = 600 x 106 ohms 45A contact = 525 x 106 ohms 30 25 20 15 10 5 0 Mechanical Contact Retention Force (lbf) 25 (N) 111 0 5 18 AWG Maximum Wire Insulation Diameter (inches) 0.175 (mm) 4.45 No Load (mating cycles) Up to 10,000 Average Disconnect Force -Fully Loaded (lbf) 18 (N) 80 Operating Temperature Range (°C) (°F) 10 15 20 25 Amperes Applied 12 AWG 30 35 10 AWG Materials Flammability Rating of Housing Material PBT UL94 V-0 -40° to 125° -40° to 257° | TOOLING INFORMATION | W ire Size Loose Piece Part Numbers Tin Plating AWG mm² 16 / 20 12 / 16 16 / 20 16 / 20 16 / 20 12 / 16 10 / 14 12 / 16 10 / 14 10 / 14 10 / 14 10 / 14 1.3 / 0.52 L o o s e Pie c e Co n t act C rimp Tool Pneumatic Hand Bench Tool or Tool + Die Silver Plating Reeled Part Numbers Number + Locator of Crimps Tin Plating Silver Plating Reeled Contact Crimp Tools ATS Applicator ATS Press Air Feed Kit* PP15 / 45 Flat Wiping Power & Ground N/A 1332 N/A 3.3 / 1.3 1331 1.3 / 0.52 262G1-LPBK 262G2-LPBK 1.5 / 0.52 200G2L-LPBK 200G4L-LPBK 1.3 / 0.52 269G2-LPBK N/A 3.3 / 1.3 261G1-LPBK 261G4-LPBK 5.3 / 2.1 261G2-LPBK 261G3-LPBK 3.3 / 1.3 269G1-LPBK N/A 5.3 / 2.1 269G3-LPBK N/A 6.0 / 2.1 200G1L-LPBK 200G3L-LPBK 6.0 / 2.1 201G1H-LPBK 201G3H-LPBK 6.0 / 2.1 1830G1-LPBK 1830G2-LPBK 1309G2 or 1309G8 1367G1 N/A N/A N/A 262G1 200G2L 269G2 261G1 261G2 269G1 269G3 200G1L 201G1H 1830G1 262G2 200G4L N/A 261G4 261G3 N/A N/A 200G3L 201G3H 1830G2 1309G3 or 1309G8 N/A N/A Single 1309G6 or 1309G8 N/A N/A N/A 1385519-1 TBD 1385519-1 1385520-1 1725900-2 1424266-1 1385458-1 or or 1385520-1 [354500-1] [354578-1] 1385458-1 1385460-1 1385460-1 1385460-1 * All ATS applicators for APP® contacts are air feed style and require the press to have an air feed kit installed. NOTE: See website for the most current information. | DIMENSIONS | Top View Side View LOCATION FOR OPTIONAL FLAT-WIPING GROUND CONTACTS Mounted View [ 27.2 ] 1.07 [ 26.9 ] 1.06 PANEL FLAT WASHERS (2) [ 62.0 ] 2.44 [ 74.4 ] 2.93 Layout For Panel Cut-Outs PLASTIC SHOULDER WASHERS (2) MACHINE SCREWS (4) FLOAT-MOUNTED SIDE PANEL HEX NUTS (4) [ 60.96 ] 2.400 A B [ 6.60 ] Ø 0.260 All Data Subject To Change Without Notice C D LOCK WASHERS (4) [ 19.3 ] .76 RIGID-MOUNTED SIDE [ 30.48 ] 1.200 Mounting -AHardware mm in. -Bmm in. -Cmm in. -Dmm in. Float Fixed 25.78 22.23 22.29 20.51 44.58 1.755 41.02 1.615 12.89 11.11 0.508 0.438 1.015 0.875 “APP & Anderson Power Products are registered trademarks of Anderson Power Products” 0.878 0.808 15406 DS-MARC REV 05 HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 www.andersonpower.com
269G1-LPBK 价格&库存
很抱歉,暂时无法提供与“269G1-LPBK”相匹配的价格&库存,您可以联系我们找货
269G1-LPBK
    库存:4
