7-Port USB 2.0 Hub, Tower
Highlights
Connect up to 7 USB 2.0
devices
Hi-Speed 480Mbps data transfer
Backward compatible with USB
1.1 devices
Over-current protection
safeguards connected
equipment from overvoltages
Supports USB 2.0 spec up to
500mA per port
Includes base stand for upright
positioning
Compatible with all major
operating systems
MODEL NUMBER: U222-007-R
System Requirements
Description
Tripp Lite's ultra small 7-port USB 2.0 hub is the most versatile and powerful hub on the market. It allows
you to connect up to seven USB devices to a single USB port on your computer. This unit meets or
exceeds USB 2.0 Specifications for Hi-Speed data transmission rates up to 480Mbps. Perfect for both the
mobile and desktop user. While the hub will function perfectly in virtually all cases without needing
external power, a compact, multi-voltage AC adapter (100-240V ) has been provided for the rare
circumstance when connecting a power hungry device. This USB 2.0 device is backwards compatible so
that it will function with both USB 2.0 and USB 1.1 devices. Over-current protection safeguards connected
equipment from overvoltages. Includes stand for upright positioning.
Features
USB2.0 7-Port Hub
Supports data transfer rates up to 480Mbps
Connect up to 7 USB devices to a single USB port on your computer
Compact design is ideal for use with a laptop/notebook computer
Does not require external power, software, or complicated set-up procedures
Plug-and-play/hot-swappable allows you to add or remove a device at any time
Per-port overcurrent protection
Bus-powered or self-powered
Supports USB 2.0 spec up to 500mA per port
On bus-power, 500mA from the USB 2.0 computer port is shared between the hub ports
The included external power supply provides 2.5A of power, to be shared between the hub ports (up to
500mA per port)
Compact, multi-voltage power supply (100-240V) provided
Compatible with all major operating systems
Specifications
OVERVIEW
1/3
USB 2.0 port
operating systems
Package Includes
U222-007-R USB 2.0 7-Port
Mini Hub
Compact External Power Supply
with NEMA 1-15P Plug (Input:
100-240V, 50/60Hz, 0.5A;
Output: 5V, 2.5A)
4 ft. extension cable
UPC Code
037332126733
Product Type
Hub
Technology
USB 2.0 (High Speed)
Host Connector
USB A (MALE)
VIDEO
Number of Monitors Supported
Extended Mode
No
Mirror Mode
No
DATA
Data Ports
(7) USB A (FEMALE)
Data Ports Details
(7) USB-A - USB 2.0
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2.5A
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2.5A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
DC Barrel Plug
OD: 3.5 x 1.35 x 9.5mm, Positive Pin, Negative Sleeve
External Power Supply Plug(s)
NEMA 1-15P North America
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red - Power
PHYSICAL
Color
Black; White
Material of Construction
Plastic
Shipping Dimensions (hwd / in.)
8.90 x 5.60 x 2.50
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
3.500 x 1.000 x 2.750
2/3
Unit Packaging Type
Clamshell
Unit Weight (lbs.)
0.2
Unit Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
14 to 176 °F (-10 to 80 °C)
Relative Humidity
0% to 90 RH, Non-Condensing
BTUs
8.5 BTU/Hr
CONNECTIONS
Number of Ports
7
Side A - Connector 1
USB B (FEMALE)
Side B - Connector 1
(7) USB A (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
Over Current Protection
Yes
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; UL; cUL; RoHS
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U222-007-R”相匹配的价格&库存,您可以联系我们找货
