Additional Resources:
Product Page
3D Model
date
11/12/2020
page
1 of 22
SERIES: CP60H │ DESCRIPTION: PELTIER MODULE
FEATURES
arcTEC™ structure on select models
enhanced reliability for high thermal cycling
superior thermal performance
silicon sealed
wide ΔT max
low profile
precise temperature control
solid state construction
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
CP60131H
3.8
6.0
0.45
13
14.3
70
77
CP60139H
2.1
6.0
0.30
7.4
8.2
70
77
CP60231H
8.8
6.0
1.05
29.7
32.7
70
77
CP60239H
3.8
6.0
0.55
13.6
14.9
70
77
CP602040395H6
7.6
6.0
1.09
27.5
30.2
70
77
CP60301233H
5.6
6.0
0.76
19.7
21.7
70
77
CP60301531H
7.6
6.0
0.93
26.3
28.9
70
77
CP60302031H
13.0
6.0
1.51
49.5
54.5
68
75
CP603315H6
15.7
6.0
1.90
53.1
59.1
70
77
CP6030395
11.8
6.0
1.65
41.5
45.6
70
77
CP603395H6
8.8
6.0
1.25
31.1
34.2
70
77
6
CP604020395H
output
Qmax4
output
∆Tmax5
7.6
6.0
1.09
27.5
30.2
70
77
19.5
6.0
2.54
67.6
74.3
68
75
CP604395H
15.7
6.0
2.2
55.6
61.0
70
77
CP6040406
24.1
6.0
3.21
83.5
91.9
68
75
CP60546241
41.3
6.0
5.78
147
161
70
77
CP6055354
35.4
6.0
4.95
126
138
70
77
CP605555426
29.8
6.0
4.15
106
116
70
77
23.6
6.0
3.3
80.2
88.2
70
77
6
CP60433H6
6
6
6
CP604060395
6
Notes:
1.
2.
3.
4.
5.
6.
Maximum voltage at ΔT max and Th=27°C
Maximum current to achieve ΔT max
Measured by AC 4-terminal method at 25°C
Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
Designed with arcTEC™ structure.
cuidevices.com
Product Page
3D Model
CUI Devices │ SERIES: CP60H │ DESCRIPTION: PELTIER MODULE
date 11/12/2020 │ page 2 of 22
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
235
typ
max
units
°C
assembly compression
1
RoHS
MPa
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
PLATING
ceramic plate
96% AL2O3
wire leads
(CP60131H,
CP60231H,
CP60302031H
CP60301233H,
CP60301531H,
CP603315H)
22 AWG
tin
wire leads (all
other models)
20 AWG
tin
sealer
silicon rubber 703 RTV (between cold
and hot side plates)
joint cover
marking
P/N & S/N printed on cold side
surface
10.0 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP60131H
15 ±0.3
15 ±0.3
3.1 ±0.025
CP603395H
30 ±0.3
30 ±0.3
3.95 ±0.025
CP60139H
15 ±0.3
15 ±0.3
3.9 ±0.025
CP604020395H
40 ±0.3
20 ±0.3
3.95 ±0.025
CP60231H
20 ±0.3
20 ±0.3
3.1 ±0.025
CP60433H
40 ±0.3
40 ±0.3
3.3 ±0.03
CP60239H
20 ±0.3
20 ±0.3
3.9 ±0.025
CP604395H
40 ±0.3
40 ±0.3
3.95 ±0.025
CP602040395H
20 ±0.3
40 ±0.3
3.95 ±0.025
CP604040
40 ±0.3
40 ±0.3
4.0 ±0.1
CP60301233H
30 ±0.1
12 ±0.1
3.3 ±0.1
CP60546241
62.5 ±0.3
54 ±0.3
4.1 ±0.1
CP60301531H
30 ±0.3
15 ±0.3
3.1 ±0.025
CP6055354
55 ±0.3
55 ±0.3
4.1 ±0.1
CP60302031H
30 ±0.3
20 ±0.3
3.1 ±0.1
CP60555542
55 ±0.3
55 ±0.3
4.2 ±0.1
CP603315H
30 ±0.3
30 ±0.3
3.15 ±0.025
CP604060395
40 ±0.3
60 ±0.3
3.95 ±0.025
CP6030395
30 ±0.3
30 ±0.3
3.95 ±0.025
cuidevices.com
Product Page
3D Model
date 11/12/2020 │ page 3 of 22
Input Voltage (V)
CP60131H PERFORMANCE (Th=27°C)
6A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
12
4.8
3.6
8.0
A
2.4 A
4.0
A
1.2 A
70
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60131H PERFORMANCE (Th=50°C)
6A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
12
8.0
A
3.6
A
2.4 A
1.2 A
4.0
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 4 of 22
Input Voltage (V)
CP60139H PERFORMANCE (Th=27°C)
6A
2.0
4.8 A
3.6 A
2.4 A
1.0
1.2 A
Heat Pumped, Q (W)
6A
A
4.8
6.0
3.6
A
2.4 A
4.0
1.2 A
2.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60139H PERFORMANCE (Th=50°C)
6A
4.8 A
2.0
3.6 A
2.4 A
1.0
1.2 A
Heat Pumped, Q (W)
6A
6.0
4.8
A
3.6
A
2.4 A
4.0
1.2 A
2.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 5 of 22
CP60231H PERFORMANCE (Th=27°C)
Input Voltage (V)
6A
8.0
4.8 A
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30
6A
4.8
3.6
A
A
2.4 A
10
1.2 A
60
50
40
30
ΔT=Th-Tc (°C)
CP60231H PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
6A
Heat Pumped, Q (W)
30
4.8
A
2.4 A
1.2 A
10
A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 6 of 22
Input Voltage (V)
CP60239H PERFORMANCE (Th=27°C)
6A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
12
4.8
8.0
A
3.6
A
2.4 A
1.2 A
4.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60239H PERFORMANCE (Th=50°C)
6A
4.0
4.8 A
3.6 A
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
4.8
12
3.6
A
A
2.4 A
8.0
1.2 A
4.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 7 of 22
Input Voltage (V)
CP602040395H PERFORMANCE (Th=27°C)
8.0
6A
4.8 A
6.0
3.6 A
4.0
2.4 A
1.2 A
2.0
Heat Pumped, Q (W)
4.8 A
30
6A
3.6 A
10
2.4 A
1.2 A
60
50
40
ΔT=Th-Tc (°C)
30
10
CP602040395H PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
8.0
4.8 A
3.6 A
6.0
2.4 A
4.0
1.2 A
2.0
Heat Pumped, Q (W)
4.8 A
30
6A
2.4 A
10
3.6 A
1.2 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 8 of 22
Input Voltage (V)
CP60301233H PERFORMANCE (Th=27°C)
8.0
6.0
6A
4.8 A
3.6 A
4.0
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
4.8 A
15
3.6 A
2.4 A
10
1.2 A
5.0
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP60301233H PERFORMANCE (Th=50°C)
8.0
6.0
6A
4.8 A
3.6 A
4.0
2.4 A
2.0
1.2 A
Heat Pumped, Q (W)
6A
4.8 A
3.6 A
15
2.4 A
10
1.2 A
5.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 9 of 22
Input Voltage (V)
CP60301531H PERFORMANCE (Th=27°C)
8.0
6A
4.8 A
6.0
3.6 A
4.0
2.4 A
1.2 A
2.0
Heat Pumped, Q (W)
6A
24
4.8 A
3.6 A
18
2.4 A
12
1.2 A
6.0
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP60301531H PERFORMANCE (Th=50°C)
8.0
6A
4.8 A
3.6 A
6.0
2.4 A
4.0
1.2 A
2.0
Heat Pumped, Q (W)
6A
4.8 A
24
3.6 A
18
2.4 A
12
1.2 A
6.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 10 of 22
Input Voltage (V)
CP60302031H PERFORMANCE (Th=27°C)
16
6A
12
4.8 A
3.6 A
8
2.4 A
4
1.2 A
Heat Pumped, Q (W)
4.8 A
6A
36
3.6
A
24
2.4 A
1.2 A
12
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60302031H PERFORMANCE (Th=50°C)
16
12
6A
4.8 A
3.6 A
8.0
2.4 A
1.2 A
4.0
Heat Pumped, Q (W)
6A
A
4.8
48
3.6
36
A
2.4 A
24
1.2 A
12
60
50
40
30
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 11/12/2020 │ page 11 of 22
Input Voltage (V)
CP603315H PERFORMANCE (Th=27°C)
6A
16
4.8 A
3.6 A
2.4 A
8.0
1.2 A
Heat Pumped, Q (W)
6A
4.8
40
3.6
A
A
2.4 A
1.2 A
60
50
40
30
ΔT=Th-Tc (°C)
CP603315H PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
4.8 A
16
3.6 A
2.4 A
8.0
1.2 A
Heat Pumped, Q (W)
6A
4.8
3.6
40
A
A
2.4 A
1.2 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 12 of 22
Input Voltage (V)
CP6030395 PERFORMANCE (Th=27°C)
6A
4.8 A
10
3.6 A
2.4 A
5
1.2 A
Heat Pumped, Q (W)
40
6A
4.8
A
3.6 A
30
2.4
A
1.2 A
10
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP6030395 PERFORMANCE (Th=50°C)
6A
4.8 A
10
3.6 A
2.4 A
5
1.2 A
6A
A
4.8
Heat Pumped, Q (W)
40
3.6 A
30
2.4
A
1.2 A
10
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 13 of 22
CP603395H PERFORMANCE (Th=27°C)
Input Voltage (V)
6A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
Heat Pumped, Q (W)
30
6A
4.8
3.6
A
A
2.4 A
10
1.2 A
60
50
40
30
ΔT=Th-Tc (°C)
CP603395H PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
4.8 A
8.0
3.6 A
2.4 A
4.0
1.2 A
6A
A
4.8
Heat Pumped, Q (W)
30
3.6
A
2.4 A
1.2 A
10
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 14 of 22
Input Voltage (V)
CP604020395H PERFORMANCE (Th=27°C)
8.0
6A
4.8 A
6.0
3.6 A
4.0
2.4 A
1.2 A
2.0
Heat Pumped, Q (W)
4.8 A
30
6A
3.6 A
10
2.4 A
1.2 A
60
50
40
ΔT=Th-Tc (°C)
30
10
CP604020395H PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
8.0
4.8 A
3.6 A
6.0
2.4 A
4.0
1.2 A
2.0
Heat Pumped, Q (W)
4.8 A
30
6A
2.4 A
10
3.6 A
1.2 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 15 of 22
Input Voltage (V)
CP60433H PERFORMANCE (Th=27°C)
24
6A
18
4.8 A
3.6 A
12
2.4 A
6.0
1.2 A
Heat Pumped, Q (W)
4.8 A
6A
60
3.6 A
40
2.4 A
1.2 A
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP60433H PERFORMANCE (Th=50°C)
24
18
6A
4.8 A
3.6 A
12
2.4 A
1.2 A
6.0
Heat Pumped, Q (W)
4.8 A
80
6A
60
3.6 A
2.4 A
40
1.2 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 16 of 22
Input Voltage (V)
CP604395H PERFORMANCE (Th=27°C)
6A
16
4.8 A
3.6 A
2.4 A
8.0
1.2 A
Heat Pumped, Q (W)
60
4.8 A
6A
3.6
40
A
2.4 A
1.2 A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP604395H PERFORMANCE (Th=50°C)
6A
4.8 A
16
3.6 A
2.4 A
8.0
1.2 A
4.8 A
Heat Pumped, Q (W)
60
6A
3.6
40
A
2.4 A
1.2 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 17 of 22
Input Voltage (V)
CP604040 PERFORMANCE (Th=27°C)
6A
24
4.8 A
18
3.6 A
2.4 A
12
1.2 A
6
Heat Pumped, Q (W)
6A
A
8
4
3.6 A
80
60
2.4
40
1.2 A
A
70
60
50
40
ΔT=Th-Tc (°C)
30
Input Voltage (V)
CP604040 PERFORMANCE (Th=50°C)
6A
24
4.8 A
3.6 A
18
2.4 A
12
1.2 A
6
Heat Pumped, Q (W)
6A
A
4.8
80
3.6 A
60
2.4
A
40
1.2 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 18 of 22
Input Voltage (V)
CP60546241 PERFORMANCE (Th=27°C)
6A
40
4.8 A
30
3.6 A
2.4 A
1.2 A
10
Heat Pumped, Q (W)
6A
A
4.8
120
3.6 A
2.4 A
80
1.2 A
40
60
50
40
ΔT=Th-Tc (°C)
30
CP60546241 PERFORMANCE (Th=50°C)
Input Voltage (V)
6A
40
4.8 A
3.6 A
30
2.4 A
1.2 A
10
Heat Pumped, Q (W)
6A
120
2.4
80
A
1.2 A
40
4.8 A
3.6 A
70
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 19 of 22
Input Voltage (V)
CP6055354 PERFORMANCE (Th=27°C)
40
6A
4.8 A
30
3.6 A
2.4 A
1.2 A
10
Heat Pumped, Q (W)
6A
A
8
4
120
3.6 A
90
2.4 A
60
1.2 A
30
60
50
30
40
ΔT=Th-Tc (°C)
Input Voltage (V)
CP6055354 PERFORMANCE (Th=50°C)
40
6A
4.8 A
30
3.6 A
2.4 A
1.2 A
10
Heat Pumped, Q (W)
6A
A
4.8
120
3.6 A
90
2.4 A
60
1.2 A
30
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 20 of 22
Input Voltage (V)
CP60555542 PERFORMANCE (Th=27°C)
32
6A
4.8 A
24
3.6 A
16
2.4 A
1.2 A
8
Heat Pumped, Q (W)
6A
100
4.8
80
A
3.6 A
60
2.4 A
40
1.2 A
60
50
30
40
ΔT=Th-Tc (°C)
Input Voltage (V)
CP60555542 PERFORMANCE (Th=50°C)
32
6A
6A
4.8
A
4.8 A
24
3.6 A
3.6 A
2.4 A
16
2.4 A
1.21.2
A A
8
6A
6 AA
4.8
Heat Pumped, Q (W)
100
A
4.8 3.6 A
80
3.6 A
60
2.4 A
2.4 A
40
1.2 A
1.2 A
60
40
50
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 21 of 22
Input Voltage (V)
CP604060395 PERFORMANCE (Th=27°C)
24
6A
4.8 A
18
3.6 A
12
2.4 A
1.2 A
6
Heat Pumped, Q (W)
6A
60
3.6 A
40
A
2.4 A
1.2 A
70
60
30
40
50
ΔT=Th-Tc (°C)
Input Voltage (V)
CP604060395 PERFORMANCE (Th=50°C)
24
6A
4.8 A
18
3.6 A
12
2.4 A
1.2 A
6
Heat Pumped, Q (W)
6A
60
3.6 A
40
A
2.4 A
1.2 A
70
60
40
50
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 11/12/2020 │ page 22 of 22
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
updated datasheet
09/25/2017
1.02
added new models
05/21/2018
1.03
added models CP604060395, CP60555542, CP6030395, CP604040,
CP6055354, CP60546241, brand update
10/22/2019
1.04
added model CP60302031H
11/12/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
