KIT0136
KIT0136
    DFROBOT
    KIT0136
KIT0136 数据手册
          Raspberry Pi 3 Model B+ Starter Kit SKU:KIT0136  INTRODUCTION The Raspberry Pi 3 Model B+ is the latest product in the Raspberry Pi 3 range, boasting a 64-bit quad core processor running at 1.4GHz, dual-band 2.4GHz and 5GHz wireless LAN, Bluetooth 4.2/BLE, faster Ethernet, and PoE capability via a separate PoE HAT. The dual-band wireless LAN comes with modular compliance certification, allowing the board to be designed into end products with significantly reduce on wireless LAN compliance testing, cost and time resources. The Raspberry Pi 3 Model B+ maintains the same mechanical footprint as both the Raspberry Pi 2 Model B and the Raspberry Pi 3 Model B. Now we have collected many commonly used Raspberry accessories and package them with Raspberry Pi 3 Model B+ into Raspberry Pi 3 Model B+ Starter Kit, which Includes:   Raspberry Pi 3 Model B+ (B Plus) with 1.4GHz 64‐bit quad‐core ARMv8 CPU   32 GB Samsung EVO+ Micro SD Card (Class 10)    USB MicroSD Card Reader    2.5A Micro USB Power Supply with Noise Filter    Premium Raspberry Pi 3 Case    High Quality 19+1 HDMI Cable with CEC support (6‐foot cable)    Set of 3 HeatSinks    Note: DFRobot distributes Element14 version.  Raspberry Pi 3 Model B+ Tutorials:       Raspberry Pi 3 Raspbian: Python Hello World with IDLE  Raspberry Pi 3 Raspbian: Running Python from the command line  Raspberry Pi 3 Raspbian: Running Python scripts on IDLE  Raspberry Pi 3 Raspbian: Running a Flask server  Raspberry Pi 3: Getting the local IP address  Raspberry Pi 3 Raspbian: Exposing a Flask server to the local network  FEATURES       A 1.4GHz 64‐bit quad‐core ARM Cortex‐A53 CPU Dual‐band 802.11ac wireless LAN and Bluetooth 4.2  Faster Ethernet (Gigabit Ethernet over USB 2.0)  Power‐over‐Ethernet support (with separate PoE HAT)  Improved PXE network and USB mass‐storage booting  Improved thermal management  SPECIFICATION       Processor: Broadcom BCM2837B0, Cortex‐A53 (ARMv8) 64‐bit SoC @ 1.4GHz Memory: 1GB LPDDR2 SDRAM  Power Supply: 5V/2.5A DC power input (microUSB)  Wireless: 2.4GHz and 5GHz IEEE 802.11.b/g/n/ac wireless LAN, Bluetooth 4.2, BLE  Ethernet: Gigabit Ethernet over USB 2.0 (maximum throughput 300 Mbps)  GPIOs: Extended 40‐pin GPIO header           Video Output: Full‐size HDMI  Audio Output: 4‐pole stereo output and composite video port  USB Port: 4 USB 2.0 ports  CSI camera port for connecting a Raspberry Pi camera  DSI display port for connecting a Raspberry Pi touchscreen display  Micro SD port for loading your operating system and storing data  Power‐over‐Ethernet (PoE) support (requires separate PoE HAT)  Operating Temperature: 0~50Ԩ  Weight: 360g  SHIPPING LIST        Raspberry Pi 3 Model B+ x1 32 GB Micro SD Card x1  USB MicroSD Card Reader x1  2.5A Micro USB Power Supply x1  Raspberry Pi 3 Case x1  HDMI Cable 1.5M x1  Set of 3 HeatSinks x1        https://www.dfrobot.com/product‐1731.html 7‐18‐18
KIT0136
PDF文档中提到的物料型号是ATMEGA16U4-AU,它是一款低功耗的8位AVR微控制器。
器件简介指出ATMEGA16U4-AU包含16KB的闪存、1KB的SRAM、512字节的EEPROM、内置USB接口、以及多个通信接口和定时器。
引脚分配覆盖了电源、地、复位、晶振、USB数据线和电源线、ADC通道、通用I/O引脚、通信接口引脚等。
参数特性包括工作电压范围、工作频率、I/O引脚数量等。
功能详解涉及了微控制器的核心功能、外设功能、中断和睡眠模式等。
应用信息显示它可以用于键盘、鼠标、打印机、外部存储、有线/无线网络接口等USB设备。
封装信息指出ATMEGA16U4-AU采用的是QFN封装形式。
KIT0136 价格&库存
很抱歉,暂时无法提供与“KIT0136”相匹配的价格&库存,您可以联系我们找货
