Copper & Aluminum Skived Fin Heat Sink
SKV Series
Skived Fin heat sinks can be an alternative to
extruded heat sinks when looking for a fin density
which can’t be achieved by extrusion technology.
Skived heat sinks can be manufactured from either
copper or aluminum and usually have 0.5 (0.020”)
thick fins.
Skived heat sinks are produced using a series of
sharp knives that, as they pass over the material,
curl up a small thickness of metal which is then
bent vertically to form the fin. Skived fins are
produced from a bar of material which is
approximately 16 feet in length and then cut to
length as required by the final application.
The final heat sink can be machined using normal
fabrication techniques. Because of the thin fins, care must
be taken in handling to prevent damage. It is suggested
that a shroud be placed over the fins to help prevent
damage. Wakefield- Vette SKV Series offers standard off
the shelf solutions for customer applications in addition
to custom solutions utilizing a plastic pin attachment.
Features:
• Plastic push pin attachment for easy insertion
• Plastic pins ensure integrity of the PCB Board
• High fin densities in comparison to extrusion
• No interface between fins and base
• Minimal tooling cost for non-standards
• Improved thermal performance
WKV Part
Height Off Base Thermal Resistance
Number
Description
Method
Length
Width
(Height of Fin)
@ Forced Air Flow
SKV38538514-CU COPPER HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.60°C/W @ 200 LFM
SKV38538514-AL ALUMINUM HEATSINK 38.5X37.6X14MM Plastic Push Pin 1.480" (37.59mm) 1.516" (38.50mm) 0.551" (14.00mm) 2.70°C/W @ 200 LFM
SKV4545225-CU
COPPER HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.65°C/W @ 200 LFM
SKV4545225-AL ALUMINUM HEATSINK 45X44X22.5MM Plastic Push Pin 1.732" (44.00mm) 1.772" (45.00mm) 0.886" (22.50mm) 1.75°C/W @ 200 LFM
SKV505014-CU
COPPER HEATSINK 50X50X14MM
Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.10°C/W @ 200 LFM
SKV505014-AL
ALUMINUM HEATSINK 50X50X14MM Plastic Push Pin 1.969" (50.00mm) 1.969" (50.00mm) 0.551" (14.00mm) 2.20°C/W @ 200 LFM
SKV585811-CU
COPPER HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 1.90°C/W @ 200 LFM
SKV585811-AL ALUMINUM HEATSINK 57.9X59X11MM Plastic Push Pin 2.323" (59.00mm) 2.280" (57.91mm) 0.433" (11.00mm) 2.00°C/W @ 200 LFM
SKV606014-CU
COPPER HEATSINK 60X60X14MM
Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.70°C/W @ 200 LFM
SKV606014-AL
ALUMINUM HEATSINK 60X60X14MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.80°C/W @ 200 LFM
SKV606021-CU
COPPER HEATSINK 60X60X21MM
Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.80°C/W @ 300 LFM
SKV606021-AL
ALUMINUM HEATSINK 60X60X21MM Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.866" (21.00mm) 0.90°C/W @ 200 LFM
SKV707014-CU
COPPER HEATSINK 70X70X14MM
Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.40°C/W @ 200 LFM
SKV707014_AL
ALUMINUM HEATSINK 70X70X14MM Plastic Push Pin 2.717" (69.00mm) 2.756" (70.00mm) 0.551" (14.00mm) 1.50°C/W @ 200 LFM
SKV808012-CU
COPPER HEATSINK 80X80X12MM
Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.20°C/W @ 200 LFM
SKV808012-AL
ALUMINUM HEATSINK 80X80X12MM Plastic Push Pin 3.150" (80.00mm) 3.150" (80.00mm) 0.472" (12.00mm) 1.30°C/W @ 200 LFM
SKV909010-CU
COPPER HEATSINK 90X90X10MM
Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.30°C/W @ 200 LFM
SKV909010-AL
ALUMINUM HEATSINK 90X90X10MM Plastic Push Pin 3.543" (90.00mm) 3.543" (90.00mm) 0.394" (10.00mm) 1.40°C/W @ 200 LFM
www.wakefield-vette.com
Thermal
Resistance @
Natural
15.90°C/W
17.20°C/W
8.00°C/W
8.70°C/W
8.90°C/W
9.90°C/W
7.70°C/W
8.40°C/W
7.00°C/W
7.60°C/W
7.20°C/W
7.90°C/W
5.60°C/W
6.30°C/W
5.10°C/W
5.70°C/W
4.50°C/W
5.00°C/W
Material
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
Copper
Aluminum
SKV Series
Height Off Base Thermal Resistance @ Thermal Resistance
WKV Part Number
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
SKV38538514-CU
15.90°C/W
17.20°C/W
WKV Part
Number
SKV4545225-CU
SKV4545225-AL
WKV Part
Number
SKV505014-CU
SKV505014-AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
8.00°C/W
Copper
8.70°C/W
Aluminum
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
8.90°C/W
Copper
9.90°C/W
Aluminum
SKV Series
WKV Part
Number
SKV585811-CU
SKV585811-AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
7.70°C/W
Copper
8.40°C/W
Aluminum
WKV Part
Number
SKV606014-CU
SKV606014-AL
WKV Part
Number
SKV606021-CU
SKV606021-AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.70°C/W @ 200 LFM 7.00°C/W
Copper
Plastic Push Pin 2.362" (60.00mm) 2.362" (60.00mm) 0.551" (14.00mm) 1.80°C/W @ 200 LFM 7.60°C/W
Aluminum
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
7.20°C/W
Copper
7.90°C/W
Aluminum
SKV Series
WKV Part
Number
SKV707014-CU
SKV707014_AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
5.60°C/W
Copper
6.30°C/W
Aluminum
WKV Part
Number
SKV808012-CU
SKV808012-AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
5.10°C/W
Copper
5.70°C/W
Aluminum
WKV Part
Number
SKV909010-CU
SKV909010-AL
Description
Method
Length
Width
(Height of Fin)
Forced Air Flow
@ Natural
Material
4.50°C/W
Copper
5.00°C/W
Aluminum
很抱歉,暂时无法提供与“SKV606021-CU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+297.885501+38.71098
