CX15818_GABRIELLA-45-M
    LEDIL(芬兰)
CX15818_GABRIELLA-45-M 数据手册
PRODUCT DATASHEET GABRIELLA-45-M GABRIELLA-45-M ~25° medium beam with holder and installation tape TECHNICAL SPECIFICATIONS: Dimensions Ø 45.0 mm Height 29.2 mm Fastening tape ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour C15810_GABRIELLA-45-M Single lens PMMA clear CA15928_GABRIELLA-45-HLD-T Assembly PC black Finish ORDERING INFORMATION: Quantities for one set: Single lens 1 Assembly 1 Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET GABRIELLA-45-M Component Qty in box MOQ MPQ Box weight (kg) C15810_GABRIELLA-45-M » Box size: 476 x 273 x 292 mm Single lens 405 90 45 11.3 CA15928_GABRIELLA-45-HLD-T » Box size: 476 x 273 x 292 mm Assembly 405 90 45 5.7 Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET GABRIELLA-45-M See also our general installation guide: www.ledil.com/installation_guide Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET GABRIELLA-45-M PHOTOMETRIC DATA (MEASURED): LED XM-L RGBW (XMLDCL HI) FWHM / FWTM 24.0° / 41.0° Efficiency 88 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour RGBW Required components: LED XQ-E HD FWHM / FWTM 24.0° / 43.0° Efficiency 86 % Peak intensity 4.3 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED LUXEON CZ FWHM / FWTM 24.0° / 44.0° Efficiency 87 % Peak intensity 4.1 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED SBM-40-RGBW FWHM / FWTM 24.0° / 40.0° Efficiency 89 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET GABRIELLA-45-M PHOTOMETRIC DATA (MEASURED): LED NCSxE17A FWHM / FWTM 23.0° / 43.0° Efficiency 90 % Peak intensity 4.4 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED NVSW219F FWHM / FWTM 24.0° / 40.0° Efficiency 89 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED SPF05F0A FWHM / FWTM 24.0° / 40.0° Efficiency 89 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour RGBW Required components: LED SPF05F0B FWHM / FWTM 23.5 + 24.0° / 41.0° Efficiency 88 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour RGBW Required components: Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET GABRIELLA-45-M PHOTOMETRIC DATA (MEASURED): LED SPF05F0C FWHM / FWTM 23.0° / 43.0° Efficiency 87 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour RGBW Required components: Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET GABRIELLA-45-M PHOTOMETRIC DATA (SIMULATED): LED XM-L RGBW (XMLCTW) FWHM / FWTM 23.0° Efficiency 85 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 24.0° Efficiency 86 % Peak intensity 4 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED OSTAR Stage (S2WN) FWHM / FWTM 23.0° / 40.0° Efficiency 93 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSTAR Stage (S2WP) FWHM / FWTM 25.0° Efficiency 86 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET GABRIELLA-45-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 17/03/2022 Subject to change without prior notice Published: 10/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
CX15818_GABRIELLA-45-M 价格&库存
很抱歉,暂时无法提供与“CX15818_GABRIELLA-45-M”相匹配的价格&库存,您可以联系我们找货
